Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling Jboss 4.0.3SP1 with TPTP 4.4 from europe build
Profiling Jboss 4.0.3SP1 with TPTP 4.4 from europe build [message #103842] Mon, 09 July 2007 12:26 Go to next message
Originally posted by: Thomas.Wiesner.ebcot.de
i've different problems to profile our application in described jboss
environment with jdk 1.5.0_11 and 1.5.0_12 (both from sun). i've tried
both, starting (profile) jboss with a serverdefinition in WTP and attaching
to a installed agentcontroller.
Machine 1 (Linux 2.6.18.8-0.1-default, intel core duo, 2GB RAM):
First jboss profiling within WTP doesn't start appserver successfully. I've
to kill the process in background.
Second starting the appserver with agentcontroller (server=enabled) seems to
be ok, but if i start to attach to the agent from eclipse 3.3 the appserver
hangs after a few minutes without any errors or exceptions. So i didn't
reach the interessting part of my application for profiling. It doesn't
matter if i switch the agentcontroller to server=standalone and filter the
only interessting packages.
Machine 2 (Linux 2.6.16.21-0.8-smp, intel quad core 64bit, 4GB RAM):
On this machine the jvm crashes directly at the beginning of starting the
jboss.
Any ideas to profile my application with TPTP in jboss on one of those
machines ?
Thanks in advance,
Thomas
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00002aaaaf3c5bd9, pid=9136, tid=1098389824
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_12-b04 mixed mode)
# Problematic frame:
# J java.util.Properties$LineReader.readLine()I
--------------- T H R E A D ---------------
Current thread (0x00002aaad81d9260): JavaThread "main" [_thread_in_Java,
id=9151]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x00002aaa89883000
Stack: [0x0000000041681000,0x0000000041782000), sp=0x0000000041780370,
free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
code)
[error occurred during error reporting, step 120, id 0xb]
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00002aaad81e27e0 JavaThread "DestroyJavaVM" [_thread_blocked, id=9136]
=>0x00002aaad81d9260 JavaThread "main" [_thread_in_Java, id=9151]
0x00002aaad80f6920 JavaThread "Low Memory Detector" daemon
[_thread_blocked, id=9149]
0x00002aaad80f7d10 JavaThread "CompilerThread1" daemon [_thread_blocked,
id=9148]
0x00002aaad80954d0 JavaThread "CompilerThread0" daemon [_thread_blocked,
id=9147]
0x00002aaad7ffc000 JavaThread "AdapterThread" daemon [_thread_blocked,
id=9146]
0x00002aaad8096730 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
id=9145]
0x00002aaad7c41b60 JavaThread "Finalizer" daemon [_thread_in_native,
id=9144]
0x00002aaad7c772d0 JavaThread "Reference Handler" daemon
[_thread_in_native, id=9143]
Other Threads:
0x00002aaad7ce78f0 VMThread [id=9142]
0x00002aaad80f2490 WatcherThread [id=9150]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 76480K, used 3936K [0x00002aaaccd90000,
0x00002aaad22e0000, 0x00002aaad7830000)
eden space 65600K, 6% used
[0x00002aaaccd90000,0x00002aaacd1680f0,0x00002aaad0da0000)
from space 10880K, 0% used
[0x00002aaad1840000,0x00002aaad1840000,0x00002aaad22e0000)
to space 10880K, 0% used
[0x00002aaad0da0000,0x00002aaad0da0000,0x00002aaad1840000)
PSOldGen total 174784K, used 0K [0x00002aaab7830000,
0x00002aaac22e0000, 0x00002aaaccd90000)
object space 174784K, 0% used
[0x00002aaab7830000,0x00002aaab7830000,0x00002aaac22e0000)
PSPermGen total 21248K, used 2999K [0x00002aaab2430000,
0x00002aaab38f0000, 0x00002aaab7830000)
object space 21248K, 14% used
[0x00002aaab2430000,0x00002aaab271dc50,0x00002aaab38f0000)
Dynamic libraries:
40000000-4000e000 r-xp 00000000 09:01
1167379 /usr/local/jdk1.5.0_12/bin/java
4010d000-40110000 rwxp 0000d000 09:01
40110000-40173000 rwxp 40110000 00:00 0
92268 /srv/appserver/jboss-4.0.3SP1/client/getopt.jar
2aaaaaad4000-2aaaaaade000 r-xp 00000000 09:01
1198609 /srv/agent-controller/plugins/org.eclipse.tptp.javaprofiler/ libHeapAdaptor.so
2aaaaaade000-2aaaaabdd000 ---p 0000a000 09:01
2aaaaabdd000-2aaaaabde000 rwxp 00009000 09:01
2aaaaabde000-2aaaaac54000 r-xp 00000000 09:01
1198613 /srv/agent-controller/plugins/org.eclipse.tptp.javaprofiler/ libJIE.so
2aaaaac54000-2aaaaad54000 ---p 00076000 09:01
2aaaaad54000-2aaaaad5a000 rwxp 00076000 09:01
[stack]
ffffffffff600000-ffffffffffe00000 ---p 00000000 00:00 0
[vdso]
VM Arguments:
jvm_args: -Xms256m -Xmx512m -Xss1024k -agentlib:JPIBootLoader=JPIAgent:server=enabled;HeapProf -Dlisa.appserver.vendor=jboss -Dlisa.appserver.url=localhost:1999 -Dprogram.name=lisa-4_3-profile.sh -Djava.endorsed.dirs=/srv/appserver/jboss-4.0.3SP1/lib/endor sed
java_command: org.jboss.Main
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/usr/local/jdk1.5.0_12
JRE_HOME=/usr/lib/jvm/java/jre
PATH=/sbin:/usr/sbin:/usr/local/sbin:/opt/gnome/sbin:/root/b in:/usr/local/bin:/usr/bin:/usr/X11R6/bin:/bin:/usr/games:/o pt/gnome/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
LD_LIBRARY_PATH=/usr/local/jdk1.5.0_12/jre/lib/amd64/server: /usr/local/jdk1.5.0_12/jre/lib/amd64:/usr/local/jdk1.5.0_12/ jre/../lib/amd64::/srv/agent-controller/plugins/org.eclipse. tptp.javaprofiler:/srv/agent-controller/lib
SHELL=/bin/bash
HOSTTYPE=x86_64
OSTYPE=linux
MACHTYPE=x86_64-suse-linux
Signal Handlers:
SIGSEGV: [libjvm.so+0x661c00], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGBUS: [libjvm.so+0x661c00], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGFPE: [libjvm.so+0x568b50], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGPIPE: [libjvm.so+0x568b50], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGILL: [libjvm.so+0x568b50], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x56aa00], sa_mask[0]=0x00000000, sa_flags=0x14000004
SIGHUP: [libjvm.so+0x56a4d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGINT: [libjvm.so+0x56a4d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGQUIT: [libjvm.so+0x56a4d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGTERM: [libjvm.so+0x56a4d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
--------------- S Y S T E M ---------------
OS:SUSE Linux Enterprise Server 10 (x86_64)
VERSION = 10
uname:Linux 2.6.16.21-0.8-smp #1 SMP Mon Jul 3 18:25:39 UTC 2006 x86_64
libc:glibc 2.4 NPTL 2.4
rlimit: STACK 8192k, CORE 0k, NPROC 49152, NOFILE 1024, AS infinity
load average:0.11 0.19 0.30
CPU:total 4 em64t ht
Memory: 4k page, physical 4031312k(781340k free), swap 2072056k(2071912k
free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (1.5.0_12-b04) for linux-amd64,
built on May 2 2007 01:49:59 by java_re with gcc 3.2.2 (SuSE Linux)
Re: Profiling Jboss 4.0.3SP1 with TPTP 4.4 from europe build [message #103901 is a reply to message #103842] Mon, 09 July 2007 15:15 Go to previous messageGo to next message
Thomas,
When running in "standalone" mode, is a file named trace.trcxml file
created in the working directory (probably the JBoss directory)? Does it
keep growing? Any data in there? Note that you can specify the trace
output file name by using the "file=" argument
(-agentlib:JPIBootLoader=JPIAgent:server=standalone,file=/tm p/trace.trcxml;HeapProf
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Profiling Jboss 4.0.3SP1 with TPTP 4.4 from europe build [message #103980 is a reply to message #103901] Tue, 10 July 2007 05:26 Go to previous messageGo to next message
Hi Asaf,
Asaf Yaffe wrote:
> Thomas,
>> to be ok, but if i start to attach to the agent from eclipse 3.3 the
>> appserver hangs after a few minutes without any errors or exceptions. So
>> i didn't reach the interessting part of my application for profiling. It
>> doesn't matter if i switch the agentcontroller to server=standalone and
>> filter the only interessting packages.
In "standalone" mode the file is created, but from the moment the jboss is
stucking the trace file doesn't grow. In each test run it grows to a size
of nearly 300 megs.
Any ideas ?
Thanks Thomas
> Asaf
Re: Profiling Jboss 4.0.3SP1 with TPTP 4.4 from europe build [message #105701 is a reply to message #103980] Thu, 19 July 2007 03:12 Go to previous message
Thomas,
Have you tried starting JBoss with the Heap Profiler, when all classes
are filtered out? Maybe the problem you see is related to the fact the
the profiler generates too much data...
Please try the following:
1. Define a filter text file (heapfilter.txt) with the following line:
* * EXCLUDE
2. Add the following line to the JBoss initialization options:
-agentlib:JPIBootLoader=JPIAgent:server=standalone,filters=h eapfilter.txt;HeapProf
3. Start JBoss.
Asaf
Asaf Yaffe
Previous Topic:Memory leak analysis
Next Topic:UnknownHostException when profiling URL.openStream()
Current Time: Fri Jul 25 19:44:31 EDT 2025
Powered by FUDForum. Page generated in 0.03800 seconds
