Home » Modeling » TMF (Xtext) » mismatched input '<EOF>' expecting
mismatched input '<EOF>' expecting [message #1038053] Wed, 10 April 2013 06:47 Go to next message
Hi All,
My grammar is below .I receive an error all time in the program.error :mismatched input '<EOF>' expecting RULE_NL. I do not solved this problem.I did several tests without success Sad Could anybody of you give me a hint? How can I solved Sad
Best Regards
Model :
elements += Elements*
Elements:
('abstract')? name =ID (':' inheritance= [Elements|ID] )? NL
( children += Child (':' compartment =[Elements|ID])? NL ( (NL children += Child NL)*)? )?
Child:
(name =ID)
terminal NL:
(('\r' '\n')? ('\t')? )
[Updated on: Wed, 10 April 2013 07:18] by Moderator
Re: mismatched input '<EOF>' expecting [message #1038107 is a reply to message #1038053] Wed, 10 April 2013 08:12 Go to previous messageGo to next message
as you should notice on running the Workflow, the language has ambiguities and thus, the terminal NL is ignored completely.
The main problem here is the terminal rule which, honestly, I can't make anything of. It's supposed to represent a new line, but can also be nothing or only a tab?
In any case, rules that could be built easily on terminals should be done with Datatype rules, as is nicely expressed here: [1].
That's just some general pointers from me, I suppose someone more experienced like Christian will deliver a more precise answer shortly.
[1] http://zarnekow.blogspot.de/2012/11/xtext-corner-6-data-types-terminals-why.html
Re: mismatched input '<EOF>' expecting [message #1038129 is a reply to message #1038053] Wed, 10 April 2013 08:44 Go to previous messageGo to next message
could you explain why you need the NL terminal at all?
Alex
Re: mismatched input '<EOF>' expecting [message #1038153 is a reply to message #1038129] Wed, 10 April 2013 09:23 Go to previous messageGo to next message
I can try indentation based grammar. load program and you can see outline view.I can try to providing this for NL rule.
Re: mismatched input '<EOF>' expecting [message #1038159 is a reply to message #1038153] Wed, 10 April 2013 09:32 Go to previous messageGo to next message
I don't think that your grammar approach will work for an indentation sensitive language. You may want to have a look at the following projects
http://code.google.com/p/arcas/source/browse/trunk/congen.xtext/?r=21#congen.xtext or https://github.com/sebastianbenz/eclipse-task-editor.
Alex
Re: mismatched input '<EOF>' expecting [message #1038170 is a reply to message #1038159] Wed, 10 April 2013 09:51 Go to previous messageGo to next message
Hi Alex,
I can try only .I must look at example again.I will try example's method.thank you for help
Best Regards,
Re: mismatched input '<EOF>' expecting [message #1038642 is a reply to message #1038159] Thu, 11 April 2013 01:49 Go to previous messageGo to next message
Hi Alex ,
I can not reach this example : https://github.com/sebastianbenz/eclipse-task-editor.
Password and user name are wanted for download.You could share ?
Best regards
Re: mismatched input '&lt;EOF&gt;' expecting [message #1038645 is a reply to message #1038642] Thu, 11 April 2013 01:52 Go to previous messageGo to next message
A simple git clone doesn't work?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: mismatched input '&lt;EOF&gt;' expecting [message #1038656 is a reply to message #1038645] Thu, 11 April 2013 02:19 Go to previous messageGo to next message
Hi Christian,
Yes,authentication is required Sad
Best regards
Re: mismatched input '&lt;EOF&gt;' expecting [message #1038660 is a reply to message #1038656] Thu, 11 April 2013 02:24 Go to previous messageGo to next message
I am sute it goes without username and password if you use the anon url
git://github.com/sebastianbenz/eclipse-task-editor.git
Re: mismatched input '&lt;EOF&gt;' expecting [message #1038684 is a reply to message #1038660] Thu, 11 April 2013 03:08 Go to previous message
Hi Christian ,
I reach Project ,thank you very much for help.
Best regards
Previous Topic:Possible move coloring after opening?
Next Topic:eclipse 4 DI
Current Time: Tue Jul 22 22:23:14 EDT 2025
Powered by FUDForum. Page generated in 0.10259 seconds
