BundleException in GMF editor [message #1037862] |
Wed, 10 April 2013 01:14  |
Can someone help me?
I'm a newbee of GMF and I followed the dashboard to create a GMF editor. But a buddle exception appeared in the code which was not in my project. I even don't know what the exception will cause to my project.
environment:
Eclipse for RCP and RAP Developers
Version: Juno Service Release 2
Build id: 20130225-0426
With only a plug-in of GMF
The following is the exception discription.
!ENTRY org.eclipse.osgi 2 0 2013-04-10 12:42:48.469
!MESSAGE The activator org.eclipse.gmf.examples.runtime.diagram.layout.LayoutPlugin for bundle org.eclipse.gmf.examples.runtime.diagram.layout is invalid
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.gmf.examples.runtime.diagram.layout.LayoutPlugin for bundle org.eclipse.gmf.examples.runtime.diagram.layout is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:236)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.gmf.runtime.common.core.service.Service$ProviderDescriptor.getProvider(Service.java:158)
at org.eclipse.gmf.runtime.common.core.service.Service$ProviderDescriptor.provides(Service.java:265)
at org.eclipse.gmf.runtime.common.core.service.Service.safeProvides(Service.java:859)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy$1.getUncachedProviders(ExecutionStrategy.java:88)
at org.eclipse.gmf.runtime.common.core.service.Service.getProviders(Service.java:537)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy$1.execute(ExecutionStrategy.java:67)
at org.eclipse.gmf.runtime.common.core.service.Service.execute(Service.java:651)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.LayoutService.execute(LayoutService.java:66)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.LayoutService.canLayoutNodes(LayoutService.java:308)
at org.eclipse.gmf.runtime.diagram.ui.commands.ArrangeCommand.canExecute(ArrangeCommand.java:149)
at org.eclipse.emf.workspace.CompositeEMFOperation.canExecute(CompositeEMFOperation.java:325)
at org.eclipse.gmf.runtime.emf.commands.core.command.CompositeTransactionalCommand.canExecute(CompositeTransactionalCommand.java:302)
at org.eclipse.gmf.runtime.diagram.ui.commands.ICommandProxy.canExecute(ICommandProxy.java:59)
at org.eclipse.gef.commands.CompoundCommand.canExecute(CompoundCommand.java:72)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.calculateEnabled(DiagramAction.java:125)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.refresh(DiagramAction.java:114)
at org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler$2.partActivated(AbstractActionHandler.java:158)
at org.eclipse.ui.internal.WorkbenchPage$11.run(WorkbenchPage.java:4454)
at org.eclipse.ui.internal.WorkbenchPage.firePartActivated(WorkbenchPage.java:4452)
at org.eclipse.ui.internal.WorkbenchPage.access$16(WorkbenchPage.java:4440)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:173)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:193)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:191)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:596)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:538)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3052)
at org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:2969)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2951)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2947)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2911)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2902)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:360)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:167)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:50)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.ClassNotFoundException: org.eclipse.gmf.examples.runtime.diagram.layout.LayoutPlugin
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:165)
... 95 more
Root exception:
!ENTRY org.eclipse.gmf.runtime.common.core 4 5 2013-04-10 12:42:48.485
!MESSAGE The service provider org.eclipse.gmf.examples.runtime.diagram.layout.provider.SquareLayoutProvider could not be activated.
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.gmf.examples.runtime.diagram.layout.provider.SquareLayoutProvider
FUDForum. Page generated in 0.27140 seconds
