Re: [TENEO] Support for Dynamic-Update Attribute [message #1038028 is a reply to message #1037811] |
Wed, 10 April 2013 06:01  |
Hi Kenny,
In this case I guess you can also generate annotations inside the model.
If that does not work then you can replace the EntityMapper class used by teneo to generate an class tag in the hbm.
Override this class with your own implementation, override one of the protected methods for example processFeatures
Inside this method do something like this:
getHbmContext().getCurrent().setAttribute("dynamic-update", "true");
super.processFeatures();
I typed this directly here, so check the exact contents of getHbmContext().getCurrent(), if it is indeed the tag you
want and also if dynamic-update is correct.
To tell Teneo to use your specific EntityMapper check out this wiki page:
http://wiki.eclipse.org/Teneo/Hibernate/Extensions
gr. Martin
On 04/10/2013 05:14 AM, Kenny Lee wrote:
> Our models are generated dynamically. So there is no way to put the annotation beforehand.
> I wonder if other than annotations, can we use any Teneo configuration to achieve this dynamicUpdate during HBM file
> generation.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.47648 seconds
