Expected behaviour when removing from a Combo widget [message #1037546] |
Tue, 09 April 2013 13:39  |
I'm not sure if this is expected behaviour for the Combo Drop Down list so don't yell if it is.
When I programmatically remove an item by index from the possible values, the selected item gets changed.
i.e.
String[] options = new String[] {"One", "Two", "Three"};
Combo c = new Combo(...);
c.setItems(options);
c.select(1); // Set to "Two"
c.remove(0); // Remove "One"
System.out.println(c.getText()); // Will print out "Three"???
c.remove(0); // Remove "Two"
System.out.println(c.getText()); // Bad!
Why does removing an item from the list change the selection? That doesn't seem to make sense to me. I haven't tested this in an RCP so I don't know if it is the same there.
I'm using RAP 2.0
Re: Expected behaviour when removing from a Combo widget [message #1037957 is a reply to message #1037546] |
Wed, 10 April 2013 04:18  |
Hi Chris,
in SWT the first sysout prints "Two"... the second - empty string. Is
this what you expect? It seems that the behavior is different between
RAP and SWT. Please open a bugzilla and we will investigate it.
Ivan
> i.e.
> I'm using RAP 2.0
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03223 seconds
