Home » Eclipse Projects » Eclipse Scout » Tabs at bottom instead of top
Tabs at bottom instead of top [message #1022100] Thu, 21 March 2013 05:20 Go to next message
Is it possible to have the tabs of a TabBox shown at the bottom instead of at the top?
To illustrate the effect I'm looking for, see this screen shot:
index.php/fa/13960/0/
[Updated on: Thu, 21 March 2013 05:21] by Moderator
Re: Tabs at bottom instead of top [message #1022144 is a reply to message #1022100] Thu, 21 March 2013 06:52 Go to previous messageGo to next message
Currently it is not part of the API. Nevertheless it is possible to get there:
Create a SWT field extension e.g. SwtScoutBottomAlignedTabBox extends SwtScoutTabBox. Override the initializeSwt method like:
  protected void initializeSwt(Composite parent) {
    super.initializeSwt(parent);
    getSwtField().setTabPosition(SWT.BOTTOM);
There we are.
I would appreciate to see an API request in bugzilla.
Re: Tabs at bottom instead of top [message #1033631 is a reply to message #1022144] Thu, 04 April 2013 09:05 Go to previous messageGo to next message
Andi, thanks for your help with this. For anyone else interested in how to do this, I'll summarise the solution we came up with to make this configurable.
First, we created an interface IBottomAlignedTabBox:
import org.eclipse.scout.rt.client.ui.form.fields.tabbox.ITabBox;
public interface IBottomAlignedTabBox extends ITabBox {
  static String PROP_TAB_ALIGNED_BOTTOM = "alignedBottom";
  boolean isTabBottomAligned();
  void setTabBottomAligned(boolean tabBottomAligned);
Next, we created an abstract class AbstractBottomAlignedTabBox:
import org.eclipse.scout.commons.annotations.ConfigProperty;
import org.eclipse.scout.commons.annotations.Order;
import org.eclipse.scout.rt.client.ui.form.fields.tabbox.AbstractTabBox;
public abstract class AbstractBottomAlignedTabBox extends AbstractTabBox implements IBottomAlignedTabBox {
  public boolean isTabBottomAligned() {
    return propertySupport.getPropertyBool(PROP_TAB_ALIGNED_BOTTOM);
  public void setTabBottomAligned(boolean tabAtBottomAligned) {
    propertySupport.setPropertyBool(PROP_TAB_ALIGNED_BOTTOM, tabAtBottomAligned);
  @ConfigProperty(ConfigProperty.BOOLEAN)
  @Order(1000)
  protected boolean getConfiguredTabBottomAligned() {
    return false;
  protected void initConfig() {
    super.initConfig();
    setTabBottomAligned((getConfiguredTabBottomAligned()));
Next, we created the Swt class SwtScoutBottomAlignedTabBox
import org.eclipse.scout.rt.ui.swt.form.fields.tabbox.SwtScoutTabBox;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Composite;
import com.bsiag.minicrm.client.ui.form.fields.ext.IBottomAlignedTabBox;
public class SwtScoutBottomAlignedTabBox extends SwtScoutTabBox {
  protected void attachScout() {
    super.attachScout();
    updateAlignmentFromScout();
  public IBottomAlignedTabBox getScoutObject() {
    return (IBottomAlignedTabBox) super.getScoutObject();
  protected void updateAlignmentFromScout() {
    getSwtField().setTabPosition(getScoutObject().isTabBottomAligned() ? SWT.BOTTOM : SWT.TOP);
    getSwtContainer().layout(true);
  protected void handleScoutPropertyChange(String name, Object newValue) {
    super.handleScoutPropertyChange(name, newValue);
    if (name.equals(IBottomAlignedTabBox.PROP_TAB_ALIGNED_BOTTOM)) {
Finally, in the SWT plugin.xml we added an entry to the extension point formfields
   <extension point="org.eclipse.scout.rt.ui.swt.formfields">
     <formField
           active="true"
           modelClass="org.eclipse.minicrm.client.ui.form.fields.ext.AbstractBottomAlignedTabBox"
           name="Bottom Aligned Tab Box"
           scope="default">
        <uiClass
              class="org.eclipse.minicrm.ui.swt.form.fields.ext.SwtScoutBottomAlignedTabBox">
        </uiClass>
     </formField>
   </extension>
This gives us SDK support for the new property when using a "BottomAlignedTabBox" instead of a "TabBox":
index.php/fa/14242/0/
And in our client, this looks as follows:
index.php/fa/14244/0/
If we were adventurous, we could even swap the position of the tabs at runtime by calling
setTabBottomAligned(!isTabBottomAligned());
[Updated on: Thu, 04 April 2013 09:06] by Moderator
Re: Tabs at bottom instead of top [message #1037086 is a reply to message #1022144] Tue, 09 April 2013 02:50 Go to previous messageGo to next message
Andreas Hoegger wrote on Thu, 21 March 2013 11:52
Here we go: https://bugs.eclipse.org/bugs/show_bug.cgi?id=405234
Re: Tabs at bottom instead of top [message #1037131 is a reply to message #1037086] Tue, 09 April 2013 03:49 Go to previous messageGo to next message
Can you attach a patch to your bug?
=> If you need help with setup (Git checkout, Gerrit Push...) we will be happy to help.
Re: Tabs at bottom instead of top [message #1037281 is a reply to message #1037131] Tue, 09 April 2013 07:24 Go to previous messageGo to next message
I'd be happy to do that. However I have no clue where I would need to start to create a patch, so I'll probably need some pretty detailed help to get me going.
Re: Tabs at bottom instead of top [message #1037375 is a reply to message #1037281] Tue, 09 April 2013 09:23 Go to previous messageGo to next message
Nice, as you might have noticed we are moving to gerrit (a code review tool based on git). Stephan will update our contribution guide.
I suggest that you follow the steps described there when Stephan has written them.
This will provide us a great feedback: the goal should be that every scout developer (without previous knowledge of git, egit, gerrit) is able to open a change to contribute something to Eclipse Scout.
Re: Tabs at bottom instead of top [message #1037411 is a reply to message #1037375] Tue, 09 April 2013 10:21 Go to previous messageGo to next message
Thanks Jeremie
I'll keep an eye on the contribution guide to see when it's adapted to gerrit.
Cheers
/urs
Re: Tabs at bottom instead of top [message #1059651 is a reply to message #1037281] Tue, 21 May 2013 02:13 Go to previous message
Urs Beeli wrote on Tue, 09 April 2013 13:24
While I'm still willing to put together a patch for this, I simply don't have time at the moment. It might be a while until I get around to it...
Previous Topic:Eclipse Scout on OS X Java 7
Next Topic:How to customize the Rayo Look&Feel?
Current Time: Thu Jul 24 17:59:15 EDT 2025
Powered by FUDForum. Page generated in 0.03598 seconds
