Home » Language IDEs » Java Development Tools (JDT) » Run Dialog - Filter not showing anything(Whenever I open the run dialog, this happens. Any way to fix?)
Run Dialog - Filter not showing anything [message #1035085] Sat, 06 April 2013 05:43 Go to next message
I'm new to eclipse so this is probably a relatively easy problem.
Every time I go to the run dialog, the filter does not show any items,
not sure if its supposed to be like this, I have no filters running, and even when I do its the same result.
I do already have items for the run, I just need to change things like the arguments in command-line programs.
All help appreciated;
index.php/fa/14267/0/
Re: Run Dialog - Filter not showing anything [message #1037358 is a reply to message #1035085] Tue, 09 April 2013 09:06 Go to previous message
All of the configurations have been filtered - noticed the 'Filter matched 10 of 10 items' in the bottom of the tree viewer.
By default the launch dialog filters configurations that reference closed projects or missing / deleted projects. If you press the filters button in the tree viewer (the three arrows pointing right) and un-check all the options your configurations should show again.
If this means you have turned off the filters as I mentioned above, then that would likely be a bug, which you could file here: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform - choosing the Debug component.
Previous Topic:Call traces
Next Topic:Returning web browser errors/feedback/trace in console
Current Time: Wed Jul 23 18:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.03658 seconds
