Home » Archived » Visual Editor (VE) » How to VE with Eclipse 3.0.0
How to VE with Eclipse 3.0.0 [message #103522] Thu, 25 August 2005 04:03 Go to next message
Originally posted by: vinod.ramu.wipro.com
I have Eclipse 3.0 already installed and working version of the software.
I am trying to install Visual Editor. I have installed the following
1. eclipse-JDT-3.0.zip
2. eclipse-PDE-3.0.zip
3. emf-sdo-runtime-2.0.0.zip
4. GEF-runtime-3.0.zip
5. VE-runtime-1.0.1.1.zip
Inspite of these installations, I am getting an error saying
ClassNotFound. Could anyone please provide me steps to install VE for
3.0.0 version and also please let me know how to uninstall the once that I
have installed. Is it just delete the jar files or should I execute any
program?
Thank you,
VinodRamu
Re: How to VE with Eclipse 3.0.0 [message #103557 is a reply to message #103522] Thu, 25 August 2005 05:31 Go to previous messageGo to next message
Could some body help me please :-((
VinodRamu
Re: How to VE with Eclipse 3.0.0 [message #103584 is a reply to message #103522] Thu, 25 August 2005 07:50 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
I believe VE-runtime-1.0.1.1 requires Eclipse 3.0.1 or 3.0.2. There
were some minor fixes in 3.0.1 vs 3.0.0 that were needed to get VE to
run properly. What are the error messages you are receiving?
- Jeff
VinodRamu wrote:
> software. I am trying to install Visual Editor. I have installed the
> following 1. eclipse-JDT-3.0.zip
> I have installed. Is it just delete the jar files or should I execute
> any program?
> Thank you,
> VinodRamu
Re: How to VE with Eclipse 3.0.0 [message #103660 is a reply to message #103522] Thu, 25 August 2005 15:26 Go to previous messageGo to next message
VinodRamu wrote:
> any program?
The VE seems to be finicky regarding which versions of supporting
packages you have installed. I have the following installed, and the VE
seems to be running properly, although I am just starting to try it.
You probably don't need to install the WTP (Web Tools Project).
Install Eclipse SDK 3.1.0 (eclipse-SDK-3.1-win32.zip)
Install EMF: emf-sdo-xsd-SDK-2.1.0.zip
Install GEF: GEF-SDK-3.1.zip
Install JEM: JEM-SDK-1.0.2.2.zip
Install WTP: wtp-1.0M5.zip
VE-runtime-1.0.2.2.zip
Launch: eclipse.exe -clean
Re: How to VE with Eclipse 3.0.0 [message #103687 is a reply to message #103660] Thu, 25 August 2005 18:21 Go to previous messageGo to next message
I don't see how this could work. VE/JEM 1.0.2.2 will not work on Eclipse
3.1 at all. That is a known not working configuration.
Rich Kulp
Re: How to VE with Eclipse 3.0.0 [message #103727 is a reply to message #103687] Fri, 26 August 2005 00:53 Go to previous messageGo to next message
Hi guys,
Thanks for all your reply. Finally, I resolved the problem by installing
Exadel Studio 2.5, which is compatible with Eclipse 3.0.
Now I am able to see the palette with all the components + code
generation. However, in this palette the LayourManager, which is the
basics for swing development is missing.
Does any one of you have any idea how to get the various layout
(specifically GridBagLayout) under the palette?
Thank you,
VinodRamu
Re: How to VE with Eclipse 3.0.0 [message #103867 is a reply to message #103727] Fri, 26 August 2005 06:34 Go to previous messageGo to next message
Hi VinodRamu,
The VE doesn't have layouts on the palette. There is a category of
Swing containers from which you can drop things like JPanel, JFrame and
others. These will have the default layout manager that the code
specifies (null for JPanel, Border for JFrame's content pane, etc...)
and to change layout manager use the Proerties viewer, select the layout
property and there is a drop down list of available layout managers to
switch to.
We have toyed with various ideas to make this more intuitive. One would
be to have a pop-up menu option called "Switch Layout" that showed a fly
out menu of available layouts. Another would be to have the layouts in
a list on the Customize Layout dialog. We have also thought about
having a preference so that the default layout manager could be changed
- a lot of Swing people use GridBag and SWT use Grid for example rather
than the null default which almost always gets changed.
Joe Winchester
Re: How to VE with Eclipse 3.0.0 [message #103948 is a reply to message #103687] Fri, 26 August 2005 15:55 Go to previous messageGo to next message
I don't know what to say. Here list of the requirements for the VE
Eclipse build eclipse-SDK-3.1: (build page) (download win32 zip)
EMF build 2.1.0: (build page) (download zip)
GEF Build 3.1: (build page) (download zip)
Here is a link to the page I got the requirements from:
http://download.eclipse.org/tools/ve/downloads/drops/R-1.1-2 00507221721/index.html
Please note that I used that I used SDKs. I wanted to get both the VE
and the WTP working from the same installation so I tried a couple of
combinations of versions. I hit on the one above and it worked. Next
time I will probably use separate installations for the VE and WTP.
Re: How to VE with Eclipse 3.0.0 [message #103962 is a reply to message #103948] Fri, 26 August 2005 17:14 Go to previous messageGo to next message
The list of requirements you wrote is correct, but the list of what you
had installed is not! They didn't match. You said you had
VE-runtime-1.0.2.2.zip and JEM-SDK-1.0.2.2.zip. Those are not compatible
with Eclipse 3.1.
However, WTP M5 probably conflicted with VE because it was released
before VE had released its final 1.1 driver. VE and WTP both share JEM.
There is no need for you to separately download JEM if you get VE, VE
will include JEM.
Robert J Emmons wrote:
>> Eclipse 3.1 at all. That is a known not working configuration.
****** >>> Install JEM: JEM-SDK-1.0.2.2.zip
******** >>> VE-runtime-1.0.2.2.zip
Rich Kulp
Re: How to VE with Eclipse 3.0.0 [message #104141 is a reply to message #103962] Mon, 29 August 2005 11:04 Go to previous messageGo to next message
> with Eclipse 3.1.
Prerequisites for VE Release Build 1.1:
I installed:
>> Install Eclipse SDK 3.1.0 (same as above)
>> Install EMF: emf-sdo-xsd-SDK-2.1.0.zip (same as above)
>> Install GEF: GEF-SDK-3.1.zip (same as above)
>> Install JEM: JEM-SDK-1.0.2.2.zip (additional)
>> Install WTP: wtp-1.0M5.zip (additional)
>> VE-runtime-1.0.2.2.zip (prerequisites same as above)
>> Launch: eclipse.exe -clean (launch command)
Where is the difference? I installed the exact specified prerequisites
for VE 1.1, plus JEM, and WTP. The additional items apparently did not
break the VE and prerequisites installation. I am not sure of the order
I installed the items. Perhaps, that matters. I believe I got the WTP
working first, then added the VE. Both are working.
I am definitely running the VE runtime 1.1M2 with Eclipse 3.1. You can
try it on your computer or buy an airline ticket to New Jersey, and I
will give you a demo.
Robert Emmons, Aurigen Inc.
remmons@aurigen.com, http://www.aurigen.com
Computer Programming and Consulting
Re: How to VE with Eclipse 3.0.0 [message #104186 is a reply to message #104141] Mon, 29 August 2005 11:56 Go to previous message
I'm trying to say VE 1.0.2.2 and JEM 1.0.2.2 ARE NOT VALID WITH ECLIPSE
3.1! THEY WILL NOT WORK WITH ECLIPSE 3.1!!!!
When you installed VE 1.1 you wiped out the 1.0.2.2 versions since those
are downlevel and VE 1.1 would replace them with the 1.1 versions.
Rich Kulp
Re: How to VE with Eclipse 3.0.0 [message #610385 is a reply to message #103522] Thu, 25 August 2005 05:31 Go to previous message
VinodRamu
Re: How to VE with Eclipse 3.0.0 [message #610387 is a reply to message #103522] Thu, 25 August 2005 07:50 Go to previous message
- Jeff
VinodRamu wrote:
> any program?
> Thank you,
> VinodRamu
Re: How to VE with Eclipse 3.0.0 [message #610393 is a reply to message #103522] Thu, 25 August 2005 15:26 Go to previous message
VinodRamu wrote:
> any program?
Re: How to VE with Eclipse 3.0.0 [message #610395 is a reply to message #103660] Thu, 25 August 2005 18:21 Go to previous message
Rich Kulp
Re: How to VE with Eclipse 3.0.0 [message #610398 is a reply to message #103687] Fri, 26 August 2005 00:53 Go to previous message
Hi guys,
Thank you,
VinodRamu
Re: How to VE with Eclipse 3.0.0 [message #610408 is a reply to message #103727] Fri, 26 August 2005 06:34 Go to previous message
Hi VinodRamu,
switch to.
Joe Winchester
Re: How to VE with Eclipse 3.0.0 [message #610414 is a reply to message #103687] Fri, 26 August 2005 15:55 Go to previous message
Re: How to VE with Eclipse 3.0.0 [message #610415 is a reply to message #103948] Fri, 26 August 2005 17:14 Go to previous message
with Eclipse 3.1.
will include JEM.
Rich Kulp
Re: How to VE with Eclipse 3.0.0 [message #610428 is a reply to message #103962] Mon, 29 August 2005 11:04 Go to previous message
> with Eclipse 3.1.
I installed:
Re: How to VE with Eclipse 3.0.0 [message #610431 is a reply to message #104141] Mon, 29 August 2005 11:56 Go to previous message
Rich Kulp
Previous Topic:problem to debug VE into eclipse 3.1.0 ?
Next Topic:Property check
Current Time: Fri Jul 18 07:34:55 EDT 2025
Powered by FUDForum. Page generated in 0.40989 seconds
