Home » Archived » BIRT » jdbc connection profile problem(Connection profile doesn't word in birt viewer in tomcat)
jdbc connection profile problem [message #1034125] Thu, 04 April 2013 23:18 Go to next message
Hi, I created a report using the eclipse plugin.
The data source type is "JDBC Database connection for query builder", and it works great if I run the report from eclipse!
When I run my report on a Birt Viewer deployed under Tomcat 6, I received an error.
I understood that my problem is that the runtime enviroment doesn't find the connection profile, but my questions are: Ho to do it?Which files do I have to copy from my Eclipse test platform to my production tomcat platform? thank you!
this is the error I receive from my report:
org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.dbprofile.
org.eclipse.datatools.connectivity.oda.OdaException: Unable to open a connection with the database connection profile. (Element ID:1205)
K028
Re: jdbc connection profile problem [message #1036968 is a reply to message #1034125] Mon, 08 April 2013 22:57 Go to previous messageGo to next message
You might check the path in your datasource to the profile store. Also, you might take a look at this if using 3.7 and above:
http://wiki.eclipse.org/Birt_3.7_Migration_Guide#Connection_Profiles
Re: jdbc connection profile problem [message #1689379 is a reply to message #1036968] Mon, 23 March 2015 08:50 Go to previous message
Have you find any solution @kappa zeroventotto
I'm also facing the same issue. Can you please check the following link.https://www.eclipse.org/forums/index.php/m/1689369/#msg_1689369
Previous Topic:Getting Data to read from left to right
Next Topic:DataCube Primary DataSet
Current Time: Fri Jul 25 16:50:46 EDT 2025
Powered by FUDForum. Page generated in 0.04461 seconds
