Home » Modeling » EMF » Loading an encrypted emf resource(Need help in how to load an emf resource that was encrypted)
Loading an encrypted emf resource [message #1036619] Mon, 08 April 2013 12:05 Go to next message
I'v created EMF resources and saved them to the file system. I used the options to encrypt them. The caveat is that the package name is dynamically created when saved, so I need to open the file in order to find the package name. Now, I'm trying to load the EMF as an XMIResource, but since I do not have the package I get an IOException because the package cannot be found.
I only need to access the resource so that I can get some basic attributes for indexing purposes. My question is:
1. How can I decrypt the file and read it without creating an EMF resource (ie since I used encryption options at save, can I load a file or inputstream some other way)?
or
2. Is there a way to get the XMIResource to not look for the package name when loading?
Thanks in advance for any help I can get.
Roshan
Re: Loading an encrypted emf resource [message #1036629 is a reply to message #1036619] Mon, 08 April 2013 12:15 Go to previous messageGo to next message
Roshan,
Comments below.
What do you mean by this?
Are you talking about package nsURIs?
> found.
Where is the package? You'll always need one to read a resource?
I suppose you can always decrypt it and use a SAX parser.
> or
> name when loading?
If you don't want to create a model, you can just use SAX.
> Roshan
Re: Loading an encrypted emf resource [message #1036724 is a reply to message #1036629] Mon, 08 April 2013 14:32 Go to previous messageGo to next message
Hi Ed,
Thanks for replying.
After looking at your response I took a look at the AESCipherImpl source, and it seems pretty straight forward in decrypting an input stream. That was the main issue I was having, because I didn't know how to decrypt it using the options Map and then load it into a file.
What do you mean by this? - The xmlns is different for every type, because it extends the domain model.
Are you talking about package nsURIs? -Is xmlns the same thing? If so, then yes.
> found.
Where is the package? You'll always need one to read a resource? If I know the package name then I can create it in memory and dynamically register it, but since I can't load it when it's encrypted I cannot find out the package.
I suppose you can always decrypt it and use a SAX parser. -I think this is my best bet.
> or
> name when loading?
Re: Loading an encrypted emf resource [message #1036734 is a reply to message #1036724] Mon, 08 April 2013 14:42 Go to previous message
Roshan,
Yes, looking at the implementations is always a good idea. :-)
On 08/04/2013 8:32 PM, Roshan S. wrote:
> Hi Ed, Thanks for replying.
> Quote:
>> > dynamically created when saved, What do you mean by this? - The
>> so, then yes.
>> not > have the package I get an IOException because the package
>> cannot be > found.
>> > I only need to access the resource so that I can get some basic >
>> > 1. How can I decrypt the file and read it without creating an EMF >
>> resource (ie since I used encryption options at save, can I load a >
>> > or
>> package > name when loading?
Previous Topic:Create File Browser
Next Topic:[CDO] CDORevisionData.NIL in revision deltas - not supported?
Current Time: Fri Jul 25 21:10:52 EDT 2025
Powered by FUDForum. Page generated in 0.05363 seconds
