Home » Newcomers » Newcomers » Build Path error(Missing required library)
Build Path error [message #1035525] Sat, 06 April 2013 21:51 Go to next message
I'm attempting to recompile an old app. I've pulled it into Eclipse from my cvs repository without a problem, except that it's saying - "Project is missing required library: \resources\lib\servlet-2.3.jar"
I've located and downloaded servlet-2.3.jar, but where do I locate the \resources\lib folder? It wasn't created with the cvs download. I tried creating it in my Java folder and I've also tried creating folder c:\resources\lib\servlet-2.3.jar and repointing the build path in Eclipse to this location, but I still get the error. So, where should the \resources\lib folder be?
Re: Build Path error [message #1036667 is a reply to message #1035525] Mon, 08 April 2013 13:10 Go to previous messageGo to next message
The project should be a Dynamic Web Project and you simply locate the
JAR and drop it anywhere you like into your project. (I keep my
third-party JARs in a subdirectory, lib, off the project root.) Then,
using Build Path, you add the JAR to the classpath (what Build Java Path
does) AND you also add this JAR via Deployment Assembly (right-click on
project, choose Properties -> Deployment Assembly, click Add,
double-click Java Build Path Entries, etc.).
Re: Build Path error [message #1036686 is a reply to message #1036667] Mon, 08 April 2013 13:34 Go to previous message
I did what you suggested and it works. Thanks for the tip!
Previous Topic:Error reading PNG metadata
Next Topic:Trouble importing snippets
Current Time: Thu Jul 24 21:13:06 EDT 2025
Powered by FUDForum. Page generated in 0.49764 seconds
