Home » Modeling » EMF » CDO MappingStrategy example and CDO Questions.
CDO MappingStrategy example and CDO Questions. [message #428087] Mon, 09 March 2009 17:43 Go to next message
I'm trying to find out if CDO will work for what I'm doing. Essentially, I
have a database already built, and it has data that maps to an EMF model.
Via CDO, using a class that implements IMappingStrategy, will I be able to
specify how the model maps to the various fields/tables in the db (MySQL)?
If so, does anyone have any examples/documentation of how to use
IMappingStrategy properly for a custom mapping?
Finally, if all of this works, I'm primarily using the mapping to read
data from the db into the model, and would like to be able to perform a
variety of filtering to filter which data actually gets into the model. Is
this possible?
Thanks.
Re: CDO MappingStrategy example and CDO Questions. [message #428089 is a reply to message #428087] Tue, 10 March 2009 01:16 Go to previous messageGo to next message
Brian,
There are several kinds of backend integrations available for CDO. For
the integration of relational database systems we offer the proprietary
DBStore (which delegates most of the actaul mapping job to
IMappingStrategy, IClassMapping and IFeatureMapping) and a
HibernateStore (which uses Teneo to generate Hibernate mappings). Have
you already looked at the HibernateStore?
If you really plan to implement a custom IMappingStrategy for the
DBStore, that should be possible although there is no documentation
available. The shipped HorizontalMappingStrategy is probably the only
example we can offer. If possible I recommend to subclass
MappingStrategy and ClassMapping. If it turns out that they are
generally useful we can make them public as SPI.
Cheers
/Eike
> Essentially, I have a database already built, and it has data that
> maps to an EMF model. Via CDO, using a class that implements
> IMappingStrategy, will I be able to specify how the model maps to the
> a variety of filtering to filter which data actually gets into the
> model. Is this possible?
> Thanks.
Re: CDO MappingStrategy example and CDO Questions. [message #1035072 is a reply to message #428089] Sat, 06 April 2013 05:12 Go to previous messageGo to next message
Hello everybody,
I was just wondering if there was any update on that lately ? Did somebody worked on a custom mapping ?
I wonder if this mapping is efficient with [0..*] relation, since for each add (for exemple to a relation from A to B), it modifies the container A table to modify the cardinality, then it adds a A_B_list entry, and finally an entry in the B table: wouldn't be simpler to put all this logic in B table ?
I actually don't know very well about DB optimization (I'm not a DB admin Smile ), but I was just wondering if somebody believes that there would be a mapping "much" more efficient than the default one, and maybe alreay start working on it ?
Thanks in advance,
Christophe.
Re: CDO MappingStrategy example and CDO Questions. [message #1035106 is a reply to message #1035072] Sat, 06 April 2013 06:26 Go to previous messageGo to next message
Hi Christophe,
The cdo hibernate store provides this type of mapping flexibility where you can choose to use join tables or foreign
keys columns directly in the 'child' table. This can be set globally using options or by annotations in the model. But
the hibernate store does not support all cdo features (as the dbstore which does support all features). Noteably,
branching is not supported nor is chunked reading of large collections. This last topic will be solved if someone needs
it though.
gr. Martin
On 04/06/2013 11:12 AM, Christophe MOINE wrote:
> Hello everybody,
> I actually don't know very well about DB optimization (I'm not a DB admin :) ), but I was just wondering if somebody
> Thanks in advance,
> Cheers,
> Christophe.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: CDO MappingStrategy example and CDO Questions. [message #1035140 is a reply to message #1035072] Sat, 06 April 2013 07:27 Go to previous message
Am 06.04.2013 11:12, schrieb Christophe MOINE:
> Hello everybody,
I don't know.
Simpler yes, but how would you maintain the cdo_version column in the container table?
Not that I know of.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:[CDO] CDO server throws exception after migrating to M6 (MySQL)
Next Topic:How to set duplicates at EList
Current Time: Fri Jul 25 17:30:41 EDT 2025
Powered by FUDForum. Page generated in 0.06508 seconds
