Problem creating VE/SWT class [message #103267] |
Wed, 24 August 2005 09:12  |
Originally posted by: none.nowhere.com
I am fairly new to Eclipse/VE but can manage VE/Swing OK. Works fine -
great product. But I am having a problem with SWT. When I create a
visual class, it compiles OK but shows nothing in the Design view. Any
components added give an error because they are generated with a no-arg
constructor. The generated code doesn't seem right to me - I include it
below. It doesn't have a constructor to add code too. Also there is no
@jve tag
package p1;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
public class Example1 {
private Shell sShell = null;
// TODO Auto-generated method stub
/* Before this is run, be sure to set up the launch
configuration (Arguments->VM Arguments)
* for the correct SWT library path in order to run with the SWT
dlls.
* The dlls are located in the SWT plugin jar.
* For example, on Windows the Eclipse SWT 3.1 plugin jar is:
* installation_directory\plugins\org.eclipse.swt.win32_
3.1.0.jar
Display display = Display.getDefault();
Example1 thisClass = new Example1();
thisClass.createSShell();
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
sShell.setSize(new Point(300, 200));
Also all the VE examples/tutorials I can find are for RCP or plugins,
which appear to me to be addons to Eclipse itself. Is VE/SWT not
intended to be used for stand alone programs?
Re: Problem creating VE/SWT class [message #610366 is a reply to message #103267] |
Wed, 24 August 2005 09:50  |
Ray,
VE development for SWT requires the use of a JRE version 1.4.2 or
greater. Please install a newer JRE and then clean your SWT project.
That should fix the problems you're seeing.
And yes, VE is meant to help you design stand alone SWT applications as
well as RCP apps.
Hope this helps,
- Jeff
Re: Problem creating VE/SWT class [message #610380 is a reply to message #103297] |
Wed, 24 August 2005 22:11  |
Jeff Myers <myersj@gmail.com> wrote in
news:dehu0v$ijt$1@news.eclipse.org:
> Ray,
> as well as RCP apps.
> Hope this helps,
> - Jeff
Thanks for the prompt reply. I might reiterate that I am very impressed
with eclipse and the VE (for swing). I think it is a brilliant product
for Java development.
I am using JRE 1.5.0_04. Is this a problem? (I have had another small
unrelated problem with 1.5 in my swing program - on some occasions it
doesn't repaint the screen correctly, running both within eclipse and
outside of it)
A manually written (not VE) SWT HelloWorld program runs OK in eclipse.
Ray
Re: Problem creating VE/SWT class [message #610389 is a reply to message #103470] |
Thu, 25 August 2005 10:14  |
Makre sure that there is a SWT Library container entry in your
classpath. There should not be a separate external jar entry for just
swt.jar. It should be a library.
When the editor comes up, are there SWT items on the pallete?
The example itself is fine. We don't use jvedoc tags that much anymore.
And for shell, you can create it with the default constructor. But for
any SWT entries selected from the palette should not use the default
constructor. Except if 1.4.1 is the java level. You said it was 1.5, but
are you sure that the project's jre is 1.5, and not just the Eclipse was
started with 1.5?
Rich Kulp
Re: Problem creating VE/SWT class [message #610396 is a reply to message #103610] |
Thu, 25 August 2005 23:35  |
Rich Kulp <richkulp@us.NO_SPAM.ibm.com> wrote in news:dekjn8$u0k$1
@news.eclipse.org:
I have "Standard Widget Toolkit(SWT)" library which includes
Access rules:No rules defined
org.eclipse.swt.win32.win32.x86_3.1.0.jar
There were some more when I ticked the include JFace button.
Yes
> But for any SWT entries selected from the palette should not use the
How do I do this?
I don't seem to have a container to add components too.
> started with 1.5?
Installed JRE in preferences is 1.5.0_04.
I cannot find any reference in the project properties.
Re: Problem creating VE/SWT class [message #610407 is a reply to message #103267] |
Fri, 26 August 2005 06:21  |
I've the same problem with SWT/JFace & the visual editor like ray.
I've installed:
- jdk 1.5
- eclipse sdk 3.1 (windows)
When I create a visual class with a swt shell I can see only a bean
symbol in the designerview.
public class TestShell extends Shell {
* @param args
I've imported the SWT-Library (Standard Widget Toolkit(SWT)) and it
works fine but I've no designer view...
could anybody help me/us
thanx
Thomas
Re: Problem creating VE/SWT class [message #610410 is a reply to message #103853] |
Fri, 26 August 2005 10:03  |
What you got there is invalid because Shell can't be extended. All I can
suggest is to make sure you a new configuration of
Eclipse SDK 3.1
GEF 3.1
EMF 2.1
VE 1.1
just by itself and a new workspace. If it still fails then there is
something strange about your system. If it doesn't fail, then there is
something strange about your previous configuration.
> * @param args
> public static void main(String[] args) {
I don't know what you mean by import. You don't import the SWT library.
I presume you mean you did "Add Library..." instead of import.
> thanx
> Thomas
Rich Kulp
Re: Problem creating VE/SWT class [message #610417 is a reply to message #103892] |
Sat, 27 August 2005 04:44  |
so I've update my system and now it's working.
I've install eclipse for some days and thought that I've the latest one,
but it seems it wasn't. I've to update EMF to the version 2.1 ...
many thanks for helping
bye
Tom
FUDForum. Page generated in 0.06858 seconds
