Home » Eclipse Projects » Remote Application Platform (RAP) » Virtual Table page size.
Virtual Table page size. [message #103207] Wed, 27 August 2008 07:43 Go to next message
I'm using a TableViewer with a VIRTUAL table, currently everything works
fine, just when I scroll down the "..." appear stating that the next
batch of data is loading.
My question is, can I define a "page" size so I can force that the
viewer loads more than the visible number of records?
Tiago
Re: Virtual Table page size. [message #103217 is a reply to message #103207] Wed, 27 August 2008 08:44 Go to previous messageGo to next message
Hi Tiago,
you can set a "virtual" size at first using setItemCount(), e.g. 100. If
you get close to this item count in LazyContentProvider#updateElement(),
you can then increase the itemCount by your page size, e.g. to 200.
Is this what you mean?
Stefan.
Tiago schrieb:
> Thanks
> Tiago
Re: Virtual Table page size. [message #103254 is a reply to message #103217] Thu, 28 August 2008 05:39 Go to previous messageGo to next message
Hi Stefan,
Something like that, can you give me a small example?
Thanks.
Tiago
Stefan Roeck wrote:
> Hi Tiago,
> Regards,
> Stefan.
> Tiago schrieb:
>> Hi,
>> works fine, just when I scroll down the "..." appear stating that the
>> next batch of data is loading.
>> Thanks
>> Tiago
Re: Virtual Table page size. [message #103277 is a reply to message #103254] Thu, 28 August 2008 09:06 Go to previous messageGo to next message
Hi Tiago,
you can find an example attached to RAP-Bug 241049 in bugzilla:
https://bugs.eclipse.org/bugs/attachment.cgi?id=107576
There is a model which grows when the user scrolls down near to the end
of the list.
Stefan.
Tiago schrieb:
> Hi Stefan,
> Thanks.
> Tiago
> Stefan Roeck wrote:
>> Hi Tiago,
>> If you get close to this item count in
>> LazyContentProvider#updateElement(), you can then increase the
>> Regards,
>> Stefan.
>> Tiago schrieb:
>>> Hi,
>>> Thanks
>>> Tiago
Re: Virtual Table page size. [message #103450 is a reply to message #103277] Fri, 29 August 2008 05:37 Go to previous message
That's exactly what I want. Thanks a lot.
Tiago
Stefan Roeck wrote:
> Hi Tiago,
> of the list.
> Regards,
> Stefan.
> Tiago schrieb:
>> Hi Stefan,
>> Thanks.
>> Tiago
>> Stefan Roeck wrote:
>>> Hi Tiago,
>>> Regards,
>>> Stefan.
>>> Tiago schrieb:
>>>> Hi,
>>>> the next batch of data is loading.
>>>> Thanks
>>>> Tiago
Previous Topic:Window Unload Event
Next Topic:size of a StandaloneView
Current Time: Sat Jul 19 01:29:28 EDT 2025
Powered by FUDForum. Page generated in 0.07273 seconds
