Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Large objects (BLOB)
Large objects (BLOB) [message #103414] Wed, 21 November 2007 05:32 Go to next message
Originally posted by: akarypid.yahoo.gr
I'm trying to persist binary objects using Teneo. What's the suggested
method of doing that? I tried using the EByteArray data type, as it was
the closest one to a BLOB I could find. Here's an example model:
<eClassifiers xsi:type="ecore:EClass" name="Document">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="filename"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="content"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EByteArray"/>
</eClassifiers>
Teneo creates a table "document_content" and creates a row each byte in
the array.
The only relevant documentation I found was:
http://www.elver.org/hibernate/ejb3_features.html#lob_notes
My model is not written as an XML schema. How does this map to a .ecore
specification?
P.S. I use hibernate 3.2.5 and Derby as the database backend.
Re: Large objects (BLOB) [message #103430 is a reply to message #103414] Wed, 21 November 2007 05:39 Go to previous messageGo to next message
Hi Alexandros,
You can set an @Lob annotation in ecore also. See a post on this a few days back with the title:
[Teneo] Text mapping instead of VarChar
(although this post talks about the text sql type it also applies to your binary blob case).
gr. Martin
Alexandros Karypidis wrote:
> </eClassifiers>
> the array.
> specification?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Large objects (BLOB) [message #103473 is a reply to message #103430] Wed, 21 November 2007 11:34 Go to previous messageGo to next message
Ok, I added:
<eAnnotations source="teneo.jpa">
<details key="value" value="@Lob"/>
</eAnnotations>
<details key="value" value="@Column(length=1048576)"/>
</eAnnotations>
Now the database schema creation fails because hibernate tries to create
a column of type "VARCHAR FOR BITDATA" whose maximum length is 32768
bytes. Derby has CLOB / BLOB fields. Does Teneo have any control over
this or is it a hibernate issue?
P.S. the runtime log fails to create table "document" as follows:
2140 [main] DEBUG org.hibernate.tool.hbm2ddl.SchemaUpdate - create
table "document" (e_id bigint not null, "dtype" varchar(255) not null,
e_version integer not null, "description" varchar(255), "entrydate"
timestamp, "fileextension" varchar(255), "content" varchar(1048576) for
bit data, "case_documents_e_id" bigint, "case_documents_idx" integer,
econtainer_class varchar(255), e_container varchar(255),
e_container_featureid integer, primary key (e_id))
2156 [main] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate -
Unsuccessful: create table "document" (e_id bigint not null, "dtype"
varchar(255) not null, e_version integer not null, "description"
varchar(255), "entrydate" timestamp, "fileextension" varchar(255),
"content" varchar(1048576) for bit data, "case_documents_e_id" bigint,
"case_documents_idx" integer, econtainer_class varchar(255), e_container
varchar(255), e_container_featureid integer, primary key (e_id))
Martin Taal wrote:
> Hi Alexandros,
> days back with the title: [Teneo] Text mapping instead of VarChar
> gr. Martin
>> Hi,
>> was the closest one to a BLOB I could find. Here's an example model:
>> </eClassifiers>
>> in the array.
>> .ecore specification?
Re: Large objects (BLOB) [message #103488 is a reply to message #103473] Wed, 21 November 2007 11:50 Go to previous messageGo to next message
How does the hbm mapping look like for the content feature? You can see the mapping by doing
getMappingXML on the datastore, you can call this method also when the initialize fails.
gr. Martin
> Ok, I added:
> </eAnnotations>
> </eAnnotations>
> Martin Taal wrote:
>> Hi Alexandros,
>> gr. Martin
>>> Hi,
>>> suggested method of doing that? I tried using the EByteArray data
>>> type, as it was the closest one to a BLOB I could find. Here's an
>>> example model:
>>> </eClassifiers>
>>> in the array.
The Netherlands
Re: Large objects (BLOB) [message #103501 is a reply to message #103488] Wed, 21 November 2007 15:58 Go to previous messageGo to next message
This is it:
<property name="content" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="binary">
<column not-null="false" unique="false" name="`content`"
length="1048576"/>
</property>
</class>
type="binary" and length="1048576"
I believe hibernate accepts type="blob" and type="clob", which would
probably do what I'd like.
> the mapping by doing getMappingXML on the datastore, you can call this
> gr. Martin
>> Ok, I added:
>> </eAnnotations>
>> </eAnnotations>
>> create a column of type "VARCHAR FOR BITDATA" whose maximum length is
>> 32768 bytes. Derby has CLOB / BLOB fields. Does Teneo have any control
>> over this or is it a hibernate issue?
>> for bit data, "case_documents_e_id" bigint, "case_documents_idx"
>> integer, econtainer_class varchar(255), e_container varchar(255),
>> e_container varchar(255), e_container_featureid integer, primary key
>> (e_id))
>> Martin Taal wrote:
>>> Hi Alexandros,
>>> few days back with the title: [Teneo] Text mapping instead of VarChar
>>> gr. Martin
>>>> Hi,
>>>> example model:
>>>> </eClassifiers>
>>>> in the array.
Re: Large objects (BLOB) [message #103534 is a reply to message #103501] Wed, 21 November 2007 17:09 Go to previous messageGo to next message
You can try the following annotation to set the type to blob:
@Type(type="blob")
the other two annotations (lob and column) should remain there.
Btw, you can enter multiple annotation in one eannotation (the value of the details is opened in a
multi-line editor).
gr. Martin
> This is it:
> length="1048576"/>
> </property>
> </class>
>> see the mapping by doing getMappingXML on the datastore, you can call
>> gr. Martin
>>> Ok, I added:
>>> </eAnnotations>
>>> </eAnnotations>
>>> control over this or is it a hibernate issue?
>>> null, e_version integer not null, "description" varchar(255),
>>> "entrydate" timestamp, "fileextension" varchar(255), "content"
>>> (e_id))
>>> bigint, "case_documents_idx" integer, econtainer_class varchar(255),
>>> (e_id))
>>> Martin Taal wrote:
>>>> Hi Alexandros,
>>>> gr. Martin
>>>>> Hi,
>>>>> example model:
>>>>> name="filename" eType="ecore:EDataType
>>>>> </eClassifiers>
>>>>> byte in the array.
The Netherlands
Re: Large objects (BLOB) [message #103593 is a reply to message #103534] Thu, 22 November 2007 07:41 Go to previous messageGo to next message
Yep, works like a charm! :-)
P.S. If you've been searching the archives, the summary is:
1) Add an EDataType for java.sql.Blob in your ecore:
<eClassifiers xsi:type="ecore:EDataType" name="Blob"
instanceClassName="java.sql.Blob"/>
2) In the attribute of type Blob, add "teneo.jpa" annotations as follows
in your ecore:
eType="#//Blob">
value=" @Lob&#xD;&#xA;@Column(length=1048576)&#xD;&# xA;@Type(type=&quot;blob&quot;) "/>
</eAnnotations>
</eStructuralFeatures>
Notice the 1MB column length if you copy-paste. Change it to what you need.
3) Use the blob as you would with hibernate. For instance:
Document doc = SolonFactory.eINSTANCE.createDocument();
Blob blob = Hibernate.createBlob(new byte[] { 1, 2, 3, 4 });
doc.setContent(blob);
> @Type(type="blob")
> the details is opened in a multi-line editor).
> gr. Martin
>> This is it:
>> length="1048576"/>
>> </property>
>> </class>
>>> gr. Martin
>>>> Ok, I added:
>>>> </eAnnotations>
>>>> </eAnnotations>
>>>> is 32768 bytes. Derby has CLOB / BLOB fields. Does Teneo have any
>>>> (e_id))
>>>> (e_id))
>>>> Martin Taal wrote:
>>>>> Hi Alexandros,
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> example model:
>>>>>> name="content" eType="ecore:EDataType
>>>>>> </eClassifiers>
>>>>>> byte in the array.
Re: Large objects (BLOB) [message #103619 is a reply to message #103593] Thu, 22 November 2007 07:49 Go to previous message
Thanks for the summary I will add it to the docs in the next build.
gr. Martin
> in your ecore:
> eType="#//Blob">
> </eAnnotations>
>> @Type(type="blob")
>> of the details is opened in a multi-line editor).
>> gr. Martin
>>> This is it:
>>> length="1048576"/>
>>> </property>
>>> </class>
>>>> gr. Martin
>>>>> Ok, I added:
>>>>> </eAnnotations>
>>>>> </eAnnotations>
>>>>> key (e_id))
>>>>> "dtype" varchar(255) not null, e_version integer not null,
>>>>> "description" varchar(255), "entrydate" timestamp, "fileextension"
>>>>> varchar(255), "content" varchar(1048576) for bit data,
>>>>> Martin Taal wrote:
>>>>>> Hi Alexandros,
>>>>>> gr. Martin
>>>>>>> Hi,
>>>>>>> example model:
>>>>>>> </eClassifiers>
>>>>>>> byte in the array.
The Netherlands
Re: Large objects (BLOB) [message #612632 is a reply to message #103414] Wed, 21 November 2007 05:39 Go to previous message
Hi Alexandros,
gr. Martin
> </eClassifiers>
> the array.
> specification?
The Netherlands
Re: Large objects (BLOB) [message #612638 is a reply to message #103430] Wed, 21 November 2007 11:34 Go to previous message
Ok, I added:
</eAnnotations>
</eAnnotations>
Martin Taal wrote:
> Hi Alexandros,
> gr. Martin
>> Hi,
>> </eClassifiers>
>> in the array.
Re: Large objects (BLOB) [message #612639 is a reply to message #103473] Wed, 21 November 2007 11:50 Go to previous message
gr. Martin
> Ok, I added:
> </eAnnotations>
> </eAnnotations>
> Martin Taal wrote:
>> Hi Alexandros,
>> gr. Martin
>>> Hi,
>>> example model:
>>> </eClassifiers>
>>> in the array.
The Netherlands
Re: Large objects (BLOB) [message #612641 is a reply to message #103488] Wed, 21 November 2007 15:58 Go to previous message
This is it:
length="1048576"/>
</property>
</class>
> gr. Martin
>> Ok, I added:
>> </eAnnotations>
>> </eAnnotations>
>> (e_id))
>> Martin Taal wrote:
>>> Hi Alexandros,
>>> gr. Martin
>>>> Hi,
>>>> example model:
>>>> </eClassifiers>
>>>> in the array.
Re: Large objects (BLOB) [message #612645 is a reply to message #103501] Wed, 21 November 2007 17:09 Go to previous message
@Type(type="blob")
multi-line editor).
gr. Martin
> This is it:
> length="1048576"/>
> </property>
> </class>
>> gr. Martin
>>> Ok, I added:
>>> </eAnnotations>
>>> </eAnnotations>
>>> (e_id))
>>> (e_id))
>>> Martin Taal wrote:
>>>> Hi Alexandros,
>>>> gr. Martin
>>>>> Hi,
>>>>> example model:
>>>>> </eClassifiers>
>>>>> byte in the array.
The Netherlands
Re: Large objects (BLOB) [message #612650 is a reply to message #103534] Thu, 22 November 2007 07:41 Go to previous message
in your ecore:
eType="#//Blob">
</eAnnotations>
> @Type(type="blob")
> gr. Martin
>> This is it:
>> length="1048576"/>
>> </property>
>> </class>
>>> gr. Martin
>>>> Ok, I added:
>>>> </eAnnotations>
>>>> </eAnnotations>
>>>> (e_id))
>>>> (e_id))
>>>> Martin Taal wrote:
>>>>> Hi Alexandros,
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> example model:
>>>>>> </eClassifiers>
>>>>>> byte in the array.
Re: Large objects (BLOB) [message #612654 is a reply to message #103593] Thu, 22 November 2007 07:49 Go to previous message
gr. Martin
> in your ecore:
> eType="#//Blob">
> </eAnnotations>
>> @Type(type="blob")
>> gr. Martin
>>> This is it:
>>> length="1048576"/>
>>> </property>
>>> </class>
>>>> gr. Martin
>>>>> Ok, I added:
>>>>> </eAnnotations>
>>>>> </eAnnotations>
>>>>> key (e_id))
>>>>> Martin Taal wrote:
>>>>>> Hi Alexandros,
>>>>>> gr. Martin
>>>>>>> Hi,
>>>>>>> example model:
>>>>>>> </eClassifiers>
>>>>>>> byte in the array.
The Netherlands
Previous Topic:[Teneo] Build update
Next Topic:[CDO 0.8.0] StoreAccessor could return less or more element than the reference Chunk ask for.
Current Time: Fri Sep 19 01:21:08 EDT 2025
Powered by FUDForum. Page generated in 0.52332 seconds
