Home » Modeling » EMF » Problems try to use Offline example code(Problems try to use Offline example code)
Problems try to use Offline example code [message #1021840] |
Wed, 20 March 2013 15:21  |
I am in the process of trying to figure out the correct way to set up CDO Server/Client connectivity in a way that allows my project to use the CDO Offline functionality. I have started looking at the org.eclipse.emf.cdo.examples.client.offline example because it is what Eike seems to recommend.
I am working on a project that already has an RCP GUI so I am trying to figure out how to separate the offline example GUI code from the server/client code that deals with the store/session/transaction stuff. I am trying to figure out how to do this by creating a main() method that creates a NodeManager, a Node that is of type NodeType.NormalRepository, and a node that is of type NodeType.Client. This is just an exercise to help me separate out the GUI stuff in the example. At this point, if I can do all that and then have the client node save something to the H2 database that the example uses then I will consider that success.
Where I'm crashing is in trying to save the first record. As I said, I am not using the GUI. In the example you are pulling data out of properties for the various fields of the CompanyPackage. How you add these records to a CDOTransaction is kind of lost to me in the example. I see that in org.eclipse.emf.cdo.examples.client.offline.ClientView we are commiting data in the CommitAction class, but I'm not sure how the data gets associated with the transaction.
I have substituted the LibraryPackage of the Library model that is used in the EMF tutorials. Other than that most of the code from the Offline example hasn't changed. The things I changed involved changing the access privileges for a couple of methods (to public) so I can call them directly in the main(). Below is the method doing the saving.
I added saveData to org.eclipse.emf.cdo.examples.client.offline.nodes.Node to add a record to the database. The exception shown at the bottom of this post is caused by the line transaction.getOrCreateResource(type.REPOSITORY_NAME). I'm really not sure how else to add data to the transaction.
I used both the name of the repository ("repository") and "/repo1" and got the same result (Exception is "RootResourceID is null; is the repository not yet initialized?").
public void saveData(Library library)
CDOTransaction transaction = getObject(CDOTransaction.class);
if (transaction == null)
throw new IllegalArgumentException("No CDOTransaction is set.");
try
if ((CDOObject)library.cdoView() == null)
//This breaks with "/repo1" and type.REPOSITORY_NAME
//which equals "repository".
CDOResource resource = transaction.getOrCreateResource(type.REPOSITORY_NAME);
resource.getContents().add(library);
transaction.commit();
else
((CDOTransaction)library.cdoView()).commit();
catch (Exception e)
throw new IllegalStateException("Could not save data.", e);
Below is the main.
public class TestCDOOffline {
private static final String ROOT_PROPERTY = "node.manager.root";
OMPlatform.INSTANCE.setDebugging(true);
OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
NodeManager nodeManager = createNodeManager();
Net4jUtil.prepareContainer(IPluginContainer.INSTANCE);
TCPUtil.prepareContainer(IPluginContainer.INSTANCE);
JVMUtil.prepareContainer(IPluginContainer.INSTANCE); //ditto JVM support
CDONet4jUtil.prepareContainer(IPluginContainer.INSTANCE);
CDONet4jServerUtil.prepareContainer(IPluginContainer.INSTANCE);
IPluginContainer.INSTANCE.registerFactory(new CDOServerBrowser.ContainerBased.Factory());
IPluginContainer.INSTANCE.addPostProcessor(new Net4jConnectorInjector());
String normalRepositoryName = "normal-repository-1";
String normalClient1 = "normal-client-1";
//createNormalRepository is a separate method below this main()
NodeType.NormalRepository repository = createNormalRepository(
normalRepositoryName, nodeManager);
nodeManager.createNode(repository);
Node normal1 = nodeManager.getNode(normalRepositoryName);
//Start the normal repository.
normal1.start();
System.out.println("Starting the normal repository");
// createClient is a separate method below this main()
NodeType.Client client1 = createClient(normalClient1,
nodeManager, "7778", normalRepositoryName);
nodeManager.createNode(client1);
Node c1 = nodeManager.getNode(normalClient1);
c1.start();
System.out.println("Started the client");
//editData is a separate method below this main()
editData(c1);
System.out.println("Edited data in the client");
c1.stop();
System.out.println("Stopped the client");
try {
Thread.sleep(5000);
} catch (Exception e) {
e.printStackTrace();
normal1.stop();
System.out.println("Stopped the normal repository");
//This creates Library data and calls the saveData method
//shown above.
private static void editData(Node client)
Library library = LibraryFactory.eINSTANCE.createLibrary();
library.setName("Public Library");
Book book = LibraryFactory.eINSTANCE.createBook();
book.setTitle("book1");
library.getBooks().add(book);
Writer writer = LibraryFactory.eINSTANCE.createWriter();
writer.setName("author 1");
library.getWriters().add(writer);
book.setAuthor(writer);
Book book2 = LibraryFactory.eINSTANCE.createBook();
book2.setTitle("book2");
Writer writer2 = LibraryFactory.eINSTANCE.createWriter();
writer2.setName("author 2");
library.getWriters().add(writer2);
book2.setAuthor(writer2);
library.getBooks().add(book2);
//This is the saveData method,which was the first snippet of code shown above.
client.saveData(library);
public static NodeManager createNodeManager() {
File f = new File(ROOT_PROPERTY);
System.out.println("root path: " + f.getAbsolutePath());
return new NodeManager(f);
public static NodeType.NormalRepository createNormalRepository(String name,
NodeManager nodeManager) {
NodeType.NormalRepository repository = new NodeType.NormalRepository(
nodeManager);
repository.getSettings().setProperty(NodeType.NAME_PROPERTY, name);
repository.getSettings().setProperty(NodeType.BROWSER_PROPERTY, "7777");
repository.getSettings().setProperty(NodeType.PORT_PROPERTY, "2036");
return repository;
public static NodeType.Client createClient(String name,
NodeManager nodeManager, String browserPort, String server) {
NodeType.Client client = new NodeType.Client(nodeManager);
client.getSettings().setProperty(NodeType.NAME_PROPERTY, name);
.setProperty(NodeType.BROWSER_PROPERTY, browserPort);
client.getSettings().setProperty(NodeType.SERVER_PROPERTY, server);
return client;
Can someone give me an Idea what I might be missing? Following is the Exeption stack trace
Caused by: java.lang.IllegalStateException: RootResourceID is null; is the repository not yet initialized?
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getRootResource(AbstractCDOView.java:242)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.attachNewResourceNode(CDOTransactionImpl.java:1010)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.attachNewResource(CDOTransactionImpl.java:940)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.attachResource(CDOTransactionImpl.java:929)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.basicSetResourceSet(CDOResourceImpl.java:1511)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$ResourcesEList.inverseAdd(ResourceSetImpl.java:586)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:286)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:435)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:423)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.createResource(CDOTransactionImpl.java:840)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getOrCreateResource(CDOTransactionImpl.java:860)
at org.eclipse.emf.cdo.examples.client.offline.nodes.Node.saveData(Node.java:161)
... 2 more
Re: Problems try to use Offline example code [message #1021855 is a reply to message #1021840] |
Wed, 20 March 2013 16:00   |
Am 20.03.2013 20:21, schrieb Andrew Whelan:
> Hello,
Sorry, what's this "pulling data out of ..."? Can you point me to the code?
By "records" you mean EObjects?
In org.eclipse.emf.cdo.examples.client.offline.nodes.NodeType.Client.createTransaction(Node) is remember the transaction:
node.setObject(CDOTransaction.class, transaction);
In org.eclipse.emf.cdo.examples.client.offline.ClientView.CommitAction.run() is retrieve it from there:
CDOTransaction transaction = Application.NODE.getObject(CDOTransaction.class);
In org.eclipse.emf.cdo.examples.client.offline.ClientView.hookDoubleClick().new IDoubleClickListener()
{...}.doubleClick(DoubleClickEvent) i open the editor:
CDOEditorUtil.openEditor(getSite().getPage(), resource);
That resource is the selection of org.eclipse.emf.cdo.examples.client.offline.ClientView.treeViewer, which uses
CDOItemProvider with the transaction (as a child of the session). So the selected resource object and all the contained
EObjects are already managed by the correct transaction.
I don't have that in my target platform, so I can't run your main() ;-(
Note that your client will have to enable CDO's legacy mode if you don't regenerate the LibraryPackagefor CDO native use
(that's not needed anymore as of 4.2 M6).
If you submit a patch I can review and eventually apply it ;-)
> transaction.getOrCreateResource(type.REPOSITORY_NAME). I'm really not sure how else to add data to the transaction. I
You're expected to pass the name (actually the repository-relative path) of a Resource, some String that all clients
agree upon to enter the persistent graph.
I remember that formerly that was a result of connecting a client to a clone repository that has never been synchronized
with its master. I thought these days the exception should be more concise.
> try
> //This breaks with "/repo1" and type.REPOSITORY_NAME //which equals "repository". CDOResource resource =
> else
> catch (Exception e)
> Below is the main.
> public static void main(String[] args) {
> CDONet4jServerUtil.prepareContainer(IPluginContainer.INSTANCE); IPluginContainer.INSTANCE.registerFactory(new
> normal1.start();
> c1.start();
> editData(c1);
> c1.stop();
> try {
> Thread.sleep(5000);
> normal1.stop();
> //shown above.
> nodeManager);
> return repository;
> return client;
Sorry, I can't run your main() because it uses a package that I don't have.
Cheers
/Eike
http://www.esc-net.de
> ... 2 more
Current Time: Wed Jul 23 05:45:09 EDT 2025
Powered by FUDForum. Page generated in 0.76589 seconds
