Slave on Raspberry PI (Could not initialize class com.sun.jna.Native) [message #1032850] |
Wed, 03 April 2013 10:10  |
I have some problems with Raspberry PI running. I am using it with Raspian to run a slave.
I got following message, when the job is finished:
FATAL: Remote call on Raspberry failed
java.io.IOException: Remote call on Raspberry failed
at hudson.remoting.Channel.call(Channel.java:652)
at hudson.Launcher$RemoteLauncher.kill(Launcher.java:771)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:459)
at hudson.model.Run.run(Run.java:1390)
at hudson.matrix.MatrixRun.run(MatrixRun.java:142)
at hudson.model.ResourceController.execute(ResourceController.java:82)
at hudson.model.Executor.run(Executor.java:137)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class com.sun.jna.Native
at org.hudsonci.plugins.jna.JnaNativeMacSupport.<clinit>(JnaNativeMacSupport.java:74)
at java.io.ObjectStreamClass.hasStaticInitializer(Native Method)
at java.io.ObjectStreamClass.computeDefaultSUID(ObjectStreamClass.java:1723)
at java.io.ObjectStreamClass.access$100(ObjectStreamClass.java:69)
at java.io.ObjectStreamClass$1.run(ObjectStreamClass.java:247)
at java.io.ObjectStreamClass$1.run(ObjectStreamClass.java:245)
at java.io.ObjectStreamClass.getSerialVersionUID(ObjectStreamClass.java:244)
at java.io.ObjectStreamClass.initNonProxy(ObjectStreamClass.java:600)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1601)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1514)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1750)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1964)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1888)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
at hudson.remoting.UserRequest.deserialize(UserRequest.java:171)
at hudson.remoting.UserRequest.perform(UserRequest.java:91)
at hudson.remoting.UserRequest.perform(UserRequest.java:41)
at hudson.remoting.Request$2.run(Request.java:276)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Can anyone help me?
FUDForum. Page generated in 0.04671 seconds
