Home » Eclipse Projects » NatTable » Filter multiple items in a dropdown.
Filter multiple items in a dropdown. [message #1001255] Wed, 16 January 2013 05:30 Go to next message
I am working on filters in NatTable and I need a filter where I can select multiple items in a drop down to use in the filter.
Does anyone has an (example) implementation for that?
Re: Filter multiple items in a dropdown. [message #1001285 is a reply to message #1001255] Wed, 16 January 2013 06:54 Go to previous messageGo to next message
well in fact this addresses two things:
1. Having a combo box in NatTable that supports multiple selection
2. A filter that can handle this
Currently NatTable doesn't support such a combo box. I worked on that a few months ago, but haven't got time to merge this into NatTable core yet. I will do this in the next few weeks.
After that we can have a look on how filters are able to react on that.
So I am only able to tell you that you have to wait some time to get that feature. At least this is what I can tell you.
Greez,
Dirk
Re: Filter multiple items in a dropdown. [message #1001294 is a reply to message #1001285] Wed, 16 January 2013 07:16 Go to previous messageGo to next message
Hi Dirk,
Thanks for your quick reply. That is correct.
Is it possible you post what you have till so far or maybe send me the code. Because I need to build such a thing at this moment.
Re: Filter multiple items in a dropdown. [message #1001319 is a reply to message #1001294] Wed, 16 January 2013 08:32 Go to previous messageGo to next message
as I'm planning to adjust and commit it to the NatTable, I can send you what I have. Posting here would be too much, as I reimplemented the whole NatCombo and ComboBoxCellEditor. The main deal is to merge what currently exists with the one I implemented to have one control that can be configured for single/multi selection.
Where to send those files?
Re: Filter multiple items in a dropdown. [message #1001332 is a reply to message #1001319] Wed, 16 January 2013 09:03 Go to previous messageGo to next message
I just sent you an e-mail with my address. Thanks!
Re: Filter multiple items in a dropdown. [message #1005885 is a reply to message #1001332] Tue, 29 January 2013 03:36 Go to previous messageGo to next message
with the major edit refactoring I committed a ComboBoxCellEditor that supports multi selection. Feel free to check if it is working for you. It should also cover the cases on rendering like you wrote me by email.
Greez,
Dirk
Re: Filter multiple items in a dropdown. [message #1007059 is a reply to message #1005885] Mon, 04 February 2013 04:36 Go to previous messageGo to next message
Great. I will check it out as soon as version 1.0.0 is released
Re: Filter multiple items in a dropdown. [message #1033491 is a reply to message #1001255] Thu, 04 April 2013 05:30 Go to previous messageGo to next message
Is ComboBoxCellEditor that supports multi selection available in the latest snapshot build for 1.0.0? If so what control needs to be configured to toggle single/multi selection
Re: Filter multiple items in a dropdown. [message #1033503 is a reply to message #1033491] Thu, 04 April 2013 05:38 Go to previous messageGo to next message
Yes it is. Look at the ComboBoxCellEditor. There should be a constructor parameter for enabling multiselect. But I plan to push a change to that so it is not set by constructor but by setter instead soon.
Re: Filter multiple items in a dropdown. [message #1068905 is a reply to message #1033503] Sun, 14 July 2013 13:54 Go to previous messageGo to next message
Hi Dirk,
"well in fact this addresses two things:
2. A filter that can handle this"
The combobox with multiple selection works great.
Is it supported in the filter row? I'm trying to use it but it keeps filtering out all the rows.
Arye
Re: Filter multiple items in a dropdown. [message #1069107 is a reply to message #1068905] Mon, 15 July 2013 03:16 Go to previous message
Yes it is supported in the filter row. As stated in the New & Noteworthy page of 1.0.0, there is even a new filter row that works like Excel.
The reason why it might not work if you simply it to the filter row with further adjustments is that the logic is reverse to the usual filter row. On multiple selection you want to only SHOW the selected ones and FILTER all not selected, while with the usual filter row you FILTER everything that is not included.
Previous Topic:Greater than (>) does not work at filter using regular expression?
Next Topic:Update Java compiler settings
Current Time: Sun Nov 09 09:52:13 EST 2025
Powered by FUDForum. Page generated in 0.05429 seconds
