Home » Modeling » TMF (Xtext) » DSLs targetting non-Java languages
DSLs targetting non-Java languages [message #1033417] Thu, 04 April 2013 04:03 Go to next message
Are there any Xtext-based DSLs (tutorials, examples, etc.) which cover targeting non-Java environments? I have a DSL which needs to translated to code which is to run in a C/C++ application with no JVM present, and I was hoping to avoid having to embed a JVM.
The DSL typically looks like this:
entity MyEntity {
    name SomeName
    handler {
        <insert some code here>
I've been looking at using Xbase, but it seems very heavily tied to JVM execution, and I'm not sure how much work it would be to get it to generate C/C++ code instead.
Worst case I can embed C/C++ code inside a string, but if there is a more elegant solution which allows the user to leverage Xtext features in the embedded code, it would be very nice.
Any ideas?
Re: DSLs targetting non-Java languages [message #1033433 is a reply to message #1033417] Thu, 04 April 2013 04:11 Go to previous message
Am 04.04.13 10:03, schrieb Jesper Eskilson:
> Hello,
> entity MyEntity {
> name SomeName
> handler {
> Any ideas?
You can always use Xtext without Xbase and implement the expressions
manually. That's actually a very common usecase. The docs are pretty
clear about the cases where Xbase is applicable. Also, Jan wrote a blog
on that topic recently:
http://koehnlein.blogspot.de/2013/04/x-is-for-abstraction.html
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Previous Topic:How to insert non-existing fields into the scope
Next Topic:Xtext: Trying to check for cross references but get ambiguous grammar
Current Time: Fri Jul 18 09:13:40 EDT 2025
Powered by FUDForum. Page generated in 0.04686 seconds
