Home » Language IDEs » Java Development Tools (JDT) » getting compiler error. I think its something to do with eclipse?
| getting compiler error. I think its something to do with eclipse? [message #1032987] |
Wed, 03 April 2013 14:22  |
I am getting the following compiler error on the package com.lynda.javatraining.db.tables;
Internal compiler error: java.lang.IllegalArgumentException: info cannot be null at org.eclipse.jdt.internal.compiler.codegen.StackMapFrame.addStackItem(StackMapFrame.java:81)
Not sure where to start. I do not think it is the code. I have supplied the code that I am using.
import java.sql.Connection;
import java.sql.PreparedStatement;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
import com.lynda.javatraining.db.DBType;
import com.lynda.javatraining.db.DBUtil;
import com.lynda.javatraining.db.beans.Admin;
public class AdminManager {
public static void displayAllRows() throws SQLException {
String sql = "SELECT adminId, userName, password FROM admin";
try (
Connection conn = DBUtil.getConnection(DBType.MYSQL);
Statement stmt = conn.createStatement();
ResultSet rs = stmt.executeQuery(sql);
System.out.println("Admin Table:");
while (rs.next()) {
StringBuffer bf = new StringBuffer();
bf.append(rs.getInt("adminId") + ": ");
bf.append(rs.getString("userName") +", ");
bf.append(rs.getString("password"));
System.out.println(bf.toString());
public static Admin getRow(int adminId) throws SQLException {
String sql = "SELECT * FROM admin WHERE adminId = ?";
ResultSet rs = null;
try (
PreparedStatement stmt = conn.prepareStatement(sql);
stmt.setInt(1, adminId);
rs = stmt.executeQuery();
if(rs.next()) { // if next means I got data
Admin bean = new Admin();
bean.setAdminId(adminId);
bean.setUserName(rs.getString("userName"));
bean.setPassword(rs.getString("password"));
return bean;
} else {
return null;
} catch (SQLException e) {
System.err.println(e);
return null;
} finally {
if (rs != null) {
rs.close();
| Re: getting compiler error. I think its something to do with eclipse? [message #1033177 is a reply to message #1033070] |
Wed, 03 April 2013 20:02   |
Still not sure I copied everything and pasted it in
*** Date: Wednesday, April 3, 2013 4:57:24 PM Pacific Daylight Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20120208-0800
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins\org.eclipse.platform_3.7.2.v201202080800\splash.bmp
-launcher
C:\Program Files\Eclipse JEE Indigo\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502\eclipse_1406.dll
-startup
C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.overrideVmargs
-product
org.eclipse.epp.package.jee.product
-vm
C:\Program Files\Java\jre7\bin\client\jvm.dll
eclipse.home.location=file:/C:/Program Files/Eclipse JEE Indigo/eclipse/
eclipse.launcher=C:\Program Files\Eclipse JEE Indigo\eclipse\eclipse.exe
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.jee
eclipse.product=org.eclipse.epp.package.jee.product
eclipse.startTime=1365033368299
eclipse.vm=C:\Program Files\Java\jre7\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=51.0
java.endorsed.dirs=C:\Program Files\Java\jre7\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre7\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre7
java.io.tmpdir=C:\Users\DEVELO~1\AppData\Local\Temp\
java.library.path=C:\Program Files\Eclipse JEE Indigo\eclipse;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;c:\oc4j\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Java\jdk1.7.0_05\bin;C:\ANT\bin;C:\Program Files\Eclipse JEE Indigo\eclipse;;.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0_05-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.7
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.7.0_05
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.7
java.vm.vendor=Oracle Corporation
java.vm.version=23.1-b03
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog
org.eclipse.equinox.launcher.splash.location=C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins\org.eclipse.platform_3.7.2.v201202080800\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.event,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.namespace,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=5071440f-ba9c-0012-1df6-ae9e2d74f2cd
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.6.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 7
os.version=6.1
osgi.arch=x86
osgi.bundles=reference:file:javax.transaction_1.1.1.v201105210645.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.0.200.v20110815-1438.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\Program Files\Eclipse JEE Indigo\eclipse\configuration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/Program Files/Eclipse JEE Indigo/eclipse/configuration/
osgi.framework=file:/c:/Program Files/Eclipse JEE Indigo/eclipse/plugins/org.eclipse.osgi_3.7.2.v20120110-1415.jar
osgi.framework.extensions=reference:file:javax.transaction_1.1.1.v201105210645.jar
osgi.framework.shape=jar
osgi.framework.version=3.7.2.v20120110-1415
osgi.frameworkClassPath=., file:c:/Program Files/Eclipse JEE Indigo/eclipse/plugins/javax.transaction_1.1.1.v201105210645.jar
osgi.install.area=file:/C:/Program Files/Eclipse JEE Indigo/eclipse/
osgi.instance.area=file:/C:/learningDB/
osgi.instance.area.default=file:/C:/Users/Developer/workspace/
osgi.logfile=C:\learningDB\.metadata\.log
osgi.manifest.cache=C:\Program Files\Eclipse JEE Indigo\eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins\org.eclipse.platform_3.7.2.v201202080800\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Program Files\Eclipse JEE Indigo\eclipse\plugins
osgi.tracefile=C:\learningDB\.metadata\trace.log
osgi.ws=win32
path.separator=;
product.home=/C:/Program Files/Eclipse JEE Indigo/eclipse/plugins/org.jboss.tools.common.model_3.3.1.v20130102-1651-H83-Final/
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre7\lib\resources.jar;C:\Program Files\Java\jre7\lib\rt.jar;C:\Program Files\Java\jre7\lib\sunrsasign.jar;C:\Program Files\Java\jre7\lib\jsse.jar;C:\Program Files\Java\jre7\lib\jce.jar;C:\Program Files\Java\jre7\lib\charsets.jar;C:\Program Files\Java\jre7\lib\jfr.jar;C:\Program Files\Java\jre7\classes
sun.boot.library.path=C:\Program Files\Java\jre7\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 1
user.country=US
user.dir=C:\Program Files\Eclipse JEE Indigo\eclipse
user.home=C:\Users\Developer
user.language=en
user.name=Developer
user.script=
user.timezone=America/Los_Angeles
user.variant=
*** Features:
org.eclipse.cvs (1.3.100.v20110520-0800-7B78FHl9VF7BD7KBM4GP9C) "Eclipse CVS Client"
org.eclipse.datatools.common.doc.user (1.9.2.v201109161655-26-311A16321A3557) "Data Tools Platform User Documentation"
org.eclipse.datatools.connectivity.doc.user (1.9.2.v201109161655-37D-7733L3D753L7BBF) "Data Tools Platform Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature (1.9.2.v201109161655-7C7e92Et1axl2OkbmSVP6fJgCpG) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.core.feature (1.9.2.v201109161655-7B7C7HCcNBGRDTHWF_Ri) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.9.2.v201109161655-4127w312312232267) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.9.2.v201109161655-7H7C7OCcNBHIEZHeFbLX) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.9.2.v201109161655-47C08w95FFAK89FHEC7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.9.2.v201109161655-77788hBmKDQ2MoTTLwdv9ILX) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.9.2.v201109161655-7J9B7UBWx_Q7338QL5SxTUtFvz0X) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.9.2.v201109161655-67D2AqGBM7KfNTHwKO9ILX) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.9.2.v201109161655-7F47SFC7sRdmSz0nz0bcci) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.9.2.v201109161655-540AkF78Z7UCRAQDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.9.2.v201109161655-4-29oB5885QBB8HKW) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.9.2.v201109161655-2-07w312218332612) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.9.2.v201109161655-544AkF7AL7MDMAOCS) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.9.2.v201109161655-546AkF7AJ7d8JEOFC) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.9.2.v201109161655-3358s7355573G57AI) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.9.2.v201109161655-7A7T7BDZRDKGGZFrGhOd) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.9.2.v201109161655-548eAkF7AK7SDKBQ9K) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.9.2.v201109161655-552AkF7AJ9KAT9SFN) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.9.2.v201109161655-540AkF7AJ7YEJBU7S) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.9.2.v201109161655-541AkF7AI7TCLBQ7L) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.9.2.v201109161655-7E46F9NiNc1QBgyT6T6) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.intro (1.9.2.v201109161655-26-7w312116392911) "Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.9.2.v201109161655-7707CCcNBHIEQJXHUNf) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.9.2.v201109161655-7A-77F7RZHQSImUlNvbu) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.9.2.v201109161655-7N847OFDsn3ivl-o7D-5qe3gjF1Q) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.9.2.v201109161655-623BgJ9EE9ZJRDZKE) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.datatools.sqltools.doc.user (1.9.2.v201109161655-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools User Documentation"
org.eclipse.dltk.core (3.0.0.v20101211-0331-7l-2ED-z0UkhYdtV3_LBO) "Eclipse Dynamic Languages Toolkit"
org.eclipse.dltk.core.index (3.0.0.v20101026-0553-79--9oA5885GAJ) "Eclipse Dynamic Languages Toolkit Index"
org.eclipse.draw2d (3.7.2.v20110927-2020-4617w3122212803131) "Graphical Editing Framework Draw2d"
org.eclipse.emf (2.7.2.v20120130-0943) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.codegen (2.7.0.v20120130-0943) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.7.0.v20120130-0943) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.7.0.v20120130-0943) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.7.0.v20120130-0943) "EMF Code Generation UI"
org.eclipse.emf.common (2.7.0.v20120127-1122) "EMF Common"
org.eclipse.emf.common.ui (2.7.0.v20120130-0943) "EMF Common UI"
org.eclipse.emf.converter (2.7.0.v20120130-0943) "EMF Model Converter"
org.eclipse.emf.databinding (1.2.0.v20120130-0943) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.2.0.v20120130-0943) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.7.1.v20120127-1122) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.7.1.v20120130-0943) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.7.0.v20120130-0943) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.7.2.v20120130-0943) "EMF Edit"
org.eclipse.emf.edit.ui (2.7.0.v20120130-0943) "EMF Edit UI"
org.eclipse.emf.mapping (2.7.0.v20120130-0943) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.7.0.v20120130-0943) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.7.0.v20120130-0943) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.7.0.v20120130-0943) "EMF Mapping UI"
org.eclipse.epp.mpc (1.1.1.I20110907-0947) "Marketplace Client"
org.eclipse.epp.package.jee.feature (1.4.2.20120213-0813) "Java EE IDE"
org.eclipse.gef (3.7.2.v20110927-2020-777D381B4Bz0755B465D34242) "Graphical Editing Framework GEF"
org.eclipse.graphiti.feature (0.8.2.v20120215-0845) "Graphiti UI (Incubation)"
org.eclipse.help (1.3.0.v20110530-0844-7i7uFFmFFl8nvqbDpEqTvx) "Help System Base"
org.eclipse.jdt (3.7.2.v20120120-1414-7z8gFcuFMP7BW5XTz0jLTnz0l9B1) "Eclipse Java Development Tools"
org.eclipse.jpt.common.eclipselink.feature (1.0.1.v201108080010-3-08s73553F3G3343) "Dali Java Persistence Tools - EclipseLink Common"
org.eclipse.jpt.common.feature (1.0.2.v201111103010-6-3AkF7BC9EBID797) "Dali Java Persistence Tools - Common"
org.eclipse.jpt.dbws.eclipselink.feature (1.0.2.v201202073020-797B5CcNBHGEQHTAwHJBF5) "Dali Java Persistence Tools - EclipseLink DBWS Support"
org.eclipse.jpt.jaxb.eclipselink.feature (1.0.2.v201202073020-7741BgJ9EEAREX8z0A9572) "Dali Java Persistence Tools - EclipseLink MOXy (JAXB) Support"
org.eclipse.jpt.jaxb.feature (1.0.2.v201111103010-508cAkF7BC8GBGA78A) "Dali Java Persistence Tools - JAXB Support"
org.eclipse.jpt.jpa.eclipselink.feature (3.0.2.v201202073020-7J7F7EF7RZHQQNYTz-KbSRNVB) "Dali Java Persistence Tools - EclipseLink JPA Support"
org.eclipse.jpt.jpa.feature (3.0.2.v201110193010-7S7B7HFC7sRdlV6fmbQaRBF5) "Dali Java Persistence Tools - JPA Support"
org.eclipse.jpt.jpadiagrameditor.feature (1.0.1.v201108100925-4-19oB5885P7C687B) "Dali Java Persistence Tools - JPA Diagram Editor"
org.eclipse.jst.common.fproj.enablement.jdt (3.3.0.v201102200555-377DF8s73543E5I5768) "Eclipse Faceted Project Framework JDT Enablement"
org.eclipse.jst.enterprise_ui.feature (3.3.2.v201111030500-7b7II1YFSK2WIuPRDEnExPV-RvTn) "Eclipse Java EE Developer Tools"
org.eclipse.jst.ws.axis2tools.feature (1.1.200.v201103022333-78-FF0DZRDKDDePSKwHj) "Axis2 Tools"
org.eclipse.jst.ws.cxf.feature (1.0.100.v201105171845-7H77DRFAKlZgjHCaHg65uE6I6I) "CXF Web Services Core"
org.eclipse.jst.ws.jaxws.feature (1.1.0.v201105171845-7E78BsF8NcJSWKvN1Rjcv) "JAX-WS Tools Core"
org.eclipse.mylyn_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.context_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.ide_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.java_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.team_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.5.5.v20120215-0100) "Mylyn"
org.eclipse.pde (3.7.2.v20120120-1420-7b7rFUOFEx2Xnqafnpz0E--0) "PDE"
org.eclipse.php (3.0.1.v201201110400-7V-79F8NcJTcJTTTJwJJ) "PDT Plug-in"
org.eclipse.platform (3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q) "Eclipse Platform"
org.eclipse.rcp (3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272) "Eclipse RCP"
org.eclipse.rse (3.3.2.R33x_v201110030150-7L7CFGH8wqio8s-qYtkPgn8qWd4T) "Remote System Explorer End-User Runtime"
org.eclipse.rse.core (3.3.2.R33x_v201110030150-7a7JFZ4F8Fz0vz03_qRujci-z-Mp) "RSE Core"
org.eclipse.rse.dstore (3.3.1.R33x_v201109141647-7L78FRAD2YR70wUHbQUplQ8LFC) "RSE DStore Services"
org.eclipse.rse.ftp (3.0.301.R33x_v201109141647-782F8O9KC92gz097E9EKF23225) "RSE FTP Service"
org.eclipse.rse.local (2.1.300.v201103142315-7B4FKsBgJ9EE9ICQIFYT) "RSE Local Services"
org.eclipse.rse.ssh (3.0.301.R33x_v201109141647-7A3F9xAGGB5k0C7KEATN92641) "RSE SSH Services"
org.eclipse.rse.telnet (2.2.200.v201106011538-775F8NAkF7BB7B9NEIPP) "RSE Telnet Service"
org.eclipse.rse.terminals (1.1.1.R33x_v201109141647-771Bh9uD7HbBF3u7DNO3293A3752) "RSE Terminals UI"
org.eclipse.rse.useractions (1.1.300.v201103142315-31F8N8s7355353B75DD) "Remote System Explorer User Actions"
org.eclipse.tm.terminal (3.1.1.R33x_v201106281309-4007S44yaw312218292641) "Target Management Terminal Widget"
org.eclipse.tm.terminal.ssh (2.1.0.v201103142315-30-7w312212153266) "Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.1.0.v201103142315-30-7w312213121A22) "Target Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.2.0.v201103142315-31-7w312214253426) "Target Management Terminal View"
org.eclipse.wst.common.fproj (3.3.2.v201201121600-377DH8s735735535DD9) "Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.3.2.v201201112313-7G78FZvFC7sRekSz-g-nAlz) "Eclipse JavaScript Development Tools"
org.eclipse.wst.web_ui.feature (3.3.2.v201111030500-7O7IFj6EMjB7yO1Xs_G1kMtQeOye6HTXFWve95_R) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.3.2.v201112072049-7H7EFZ7DxumTmce4khcSkIiqoD8eDMKlT8Oz011P) "Eclipse XML Editors and Tools"
org.eclipse.wst.xml.xpath2.processor.feature (2.0.0.v201103310043-7A7J-CcNBGOCUIWFYMf) "Eclipse XPath 2 Developers Tools"
org.eclipse.wst.xsl.feature (1.3.1.v201109012200-7T7YFRTFIqUoIrvbEtBlSIJXGZNg) "Eclipse XSL Developer Tools"
org.hibernate.eclipse.feature (3.5.1.v20130102-1835-H100-Final) "Hibernate Tools"
*** Plug-in Registry:
com.ibm.icu (4.4.2.v20110823) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.44.v201101211721) "JSch" [Resolved]
com.sun.syndication (0.9.0.v200803061811) "Rss and atOM utilitiEs (ROME)" [Resolved]
java_cup.runtime (0.10.0.v201005080400) "Java Cup" [Resolved]
javax.activation (1.1.0.v201105071233) "Apache Geronimo Activation Plug-in" [Resolved]
javax.jws (2.0.0.v201005080400) "Web Services Metadata" [Resolved]
javax.mail (1.4.0.v201005080615) "Javax Mail Plug-in" [Resolved]
javax.persistence (2.0.3.v201010191057) "Java Persistence API 2.0" [Resolved]
javax.servlet (2.5.0.v201103041518) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v201101211617) "Java Server Pages API Bundle" [Resolved]
javax.transaction (1.1.1.v201105210645) "geronimo Javax Transaction API 1.1.1 spec" [Resolved]
javax.wsdl (1.5.1.v201012040544) "WSDL4J" [Resolved]
javax.wsdl (1.6.2.v201012040545) "WSDL4J" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
javax.xml.bind (2.1.9.v201005080401) "XML Binding for Java" [Resolved]
javax.xml.rpc (1.1.0.v201005080400) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v201005080501) "SAAJ" [Resolved]
javax.xml.stream (1.0.1.v201004272200) "Java XML Streaming API" [Resolved]
javax.xml.ws (2.1.0.v200902101523) "Java API for XML Web Services (JAX-WS)" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v201004271650) "SourceForge LPG" [Resolved]
org.apache.ant (1.8.2.v20120109-1030) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v201005080400) "Apache Web Services" [Resolved]
org.apache.bcel (5.2.0.v201005080400) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v201101211617) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v201005080500) "Apache Commons Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v201004190315) "Jakarta-Commons Discovery" [Resolved]
org.apache.commons.el (1.0.0.v201101211617) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v201012070820) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.1.0.v201005080500) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.4.0.v201005080502) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v201101211617) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.net (2.2.0.v201101241833) "Apache Commons Net" [Resolved]
org.apache.derby.core (10.8.1.2) "Apache Derby Core Plug-in for Eclipse" [Resolved]
org.apache.derby.plugin.doc (1.1.3) "Apache Derby Plug-in Documentation for Eclipse" [Starting]
org.apache.derby.ui (1.1.3) "Apache Derby Ui Plug-in for Eclipse" [Starting]
org.apache.jasper (5.5.17.v201101211617) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.15.v201012070815) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v201101211617) "Apache Lucene" [Resolved]
org.apache.lucene (2.9.1.v201101211721) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (2.9.1.v201101211721) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (2.9.1.v201101211721) "Apache Lucene Core" [Resolved]
org.apache.lucene.highlighter (2.9.1.v20100421-0704) "Apache Lucene Highlighter" [Resolved]
org.apache.lucene.memory (2.9.1.v20100421-0704) "Apache Lucene Memory" [Resolved]
org.apache.lucene.misc (2.9.1.v20100421-0704) "Apache Lucene Misc" [Resolved]
org.apache.lucene.queries (2.9.1.v20100421-0704) "Apache Lucene Queries" [Resolved]
org.apache.lucene.snowball (2.9.1.v20100421-0704) "Apache Lucene Snowball" [Resolved]
org.apache.lucene.spellchecker (2.9.1.v20100421-0704) "Apache Lucene Spellchecker" [Resolved]
org.apache.oro (2.0.8.v201005080400) "Apache Jakarta ORO" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
org.apache.ws.commons.util (1.0.1.v20100518-1140) "WS Commons Util Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v201005080400) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v201101211617) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.302.v20120110-1739) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.101.v20120110-1739) "Ant Launching Support" [Starting]
org.eclipse.ant.ui (3.5.101.v20120110-1739) "Ant UI" [Starting]
org.eclipse.compare (3.5.202.R37x_v20111109-0800) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.200.I20110208-0800) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.200.I20110510-0800) "Compare Support for Word" [Starting]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20110111-0800) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20110423-0524) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.0.I20110111-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100824-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.0.I20110222-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.0.I20110222-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.300.v20110228) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.100.v20111007_r372) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.200.v20110928-1504) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.100.v20110423-0524) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.300.v20110423-0524) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.5.101.v20120113-1953) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20110511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86 (1.0.100.I20110331-0827) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.7.101.v20120125-1505) "Core Resource Management" [Active]
org.eclipse.core.resources.win32.x86 (3.5.100.v20110423-0524) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.7.0.v20110110) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20110110) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.0.v20110505) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.500.v20110928-1503) "Core Variables" [Active]
org.eclipse.cvs (1.1.100.v201202080800) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.7.0.20090521092446) "Data Tools Platform User Documentation" [Starting]
org.eclipse.datatools.connectivity (1.2.4.v201202041105) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.102.v201107221459) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v201107221459) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.3.v201107221459) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.10.v201109250955) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v201107221459) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v201107221459) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v201107221459) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation" [Starting]
org.eclipse.datatools.connectivity.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.connectivity.oda (3.3.3.v201110130935) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.5.v201109151100) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.3.4.v201109211529) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.6.v201112151316) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.2.v201112081200) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.2.v201201101437) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.7.v201112290953) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.3.v201201121156) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.2.4.v201201131116) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.2.1.v20110926045) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v201107221459) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.2.2.v201111190813) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.4.v201107221459) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v201107221502) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v201107221502) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v201108120600) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.2.v201107221502) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition (1.0.3.v201107221502) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.1.v201108130630) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.2.v201107221502) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.4.v201107221502) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.2.v201108130630) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.2.v201107221502) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition (1.0.4.v201107221502) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.1.v201108130630) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.1.v201107221502) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.4.v201107221502) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.2.v201108130630) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v201107221502) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v201105270214) "Ingres DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v201107221501) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201107221504) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.1.v201201240349) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.2.v201201131118) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v201109022323) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v201109022331) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v201109022331) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.3.v201112061438) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.3.v201112061438) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.3.v201112061438) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.3.v201112071047) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v201107221506) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.102.v201107221506) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.3.v201201131121) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.1.0.v201110070445) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.2.v201110070445) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v201107221506) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v201107221507) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v201107221507) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v201107221507) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041100) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201107221507) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v201107221507) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v201107221507) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v201107221507) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v201107221507) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111204) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.2.v201201131122) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v201107221507) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v201010140307) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v201010140307) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090452) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.intro (1.7.0.v201005281800) "Eclipse Data Tools Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.2.v201107221519) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v201107221519) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.5.v201110151330) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.1.v201107221519) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.1.2.v201110151315) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.1.v201110151245) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.2.v201201131123) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.1.v201107221500) "DTP ODA Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.2.1.v201110050500) "Data Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.2.1.v201010270945) "Data UI Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v201107221520) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.2.v201201131129) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.1.v201107221520) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation" [Starting]
org.eclipse.datatools.sqltools.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.1.v201201131129) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.2.v201107221520) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v201107221520) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.2.1.v201201250505) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.1.2.v201201131129) "Eclipse Data Tools Platform SQL Results View Plug-ins" [Starting]
org.eclipse.datatools.sqltools.result.ui (1.1.2.v201110010535) "Eclipse Data Tools Platform SQL Results View UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor.ui (1.0.2.v201111230714) "Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302) "Schema Object Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.1.200810071) "Schema Object Editor Framework" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages (1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.1.v201110050515) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql.ui (1.0.1.v201201270743) "Eclipse Data Tools Platform SQL Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.3.v201107221520) "SQL Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.2.v201107221520) "Eclipse Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.1.v201107221520) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.1.v201005250945) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.debug.core (3.7.1.v20111129-2031) "Debug Core" [Active]
org.eclipse.debug.ui (3.7.102.v20111129-1423_r372) "Debug UI" [Starting]
org.eclipse.dltk (3.0.0.v20101209) "Eclipse Dynamic Languages Toolkit" [Resolved]
org.eclipse.dltk.console (3.0.0.v20101211-0412) "Dynamic Languages Toolkit Console Core" [Starting]
org.eclipse.dltk.console.ui (3.0.0.v20101212-1106) "Dynamic Languages Toolkit Console UI" [Starting]
org.eclipse.dltk.core (3.0.1.v20110823) "Dynamic Languages Toolkit Core" [Active]
org.eclipse.dltk.core.index (3.0.0.v20110429) "Eclipse Dynamic Languages Toolkit Index" [Resolved]
org.eclipse.dltk.core.index.sql (3.0.0.v20110423) "DLTK Abstract SQL-based Indexer" [Starting]
org.eclipse.dltk.core.index.sql.h2 (3.0.0.v20110423) "DLTK H2-based Indexer" [Starting]
org.eclipse.dltk.core.manipulation (3.0.0.v20110609-1525) "pluginName" [Starting]
org.eclipse.dltk.debug (3.0.1.v20110824) "Dynamic Languages Toolkit Debug Core" [Starting]
org.eclipse.dltk.debug.ui (3.0.0.v20110423) "Dynamic Languages Toolkit Debug UI" [Starting]
org.eclipse.dltk.formatter (3.0.0.v20110609-1525) "Dynamic Languages Toolkit Formatter" [Starting]
org.eclipse.dltk.launching (3.0.0.v20110423) "Dynamic Languages Toolkit Launching Core" [Active]
org.eclipse.dltk.logconsole (3.0.0.v20110424) "Dynamic Languages Toolkit LogConsole" [Starting]
org.eclipse.dltk.logconsole.ui (3.0.0.v20110424) "Dynamic Languages Toolkit LogConsole UI" [Resolved]
org.eclipse.dltk.testing (3.0.0.v20110423) "Dynamic Languages Toolkit Testing Frameworks Support" [Starting]
org.eclipse.dltk.ui (3.0.1.v20110823) "Dynamic Languages Toolkit Core UI" [Active]
org.eclipse.dltk.validators.core (3.0.0.v20110423) "Dynamic Languages Toolkit Validators Core" [Starting]
org.eclipse.dltk.validators.externalchecker (3.0.0.v20110423) "Dynamic Languages Toolkit Validators UI" [Starting]
org.eclipse.dltk.validators.ui (3.0.0.v20110423) "Dynamic Languages Toolkit Validators UI" [Starting]
org.eclipse.draw2d (3.7.2.v20111017-2020) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.dstore.core (3.3.1.R33x_v201107181530) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.300.v201101042155) "RSE DStore Platform Support" [Starting]
org.eclipse.ecf (3.1.300.v20110531-2218) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (5.0.0.v20110531-2218) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.1.100.v20110531-2218) "ECF Core Identity API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.2.0.v20110531-2218) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20110531-2218) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.100.v20110531-2218) "ECF Core API" [Resolved]
org.eclipse.emf (2.6.0.v20120130-0943) "EMF - Eclipse Modeling Framework Runtime and Tools" [Starting]
org.eclipse.emf.ant (2.7.0.v20120130-0943) "EMF Ant Tasks" [Starting]
org.eclipse.emf.codegen (2.6.0.v20120130-0943) "EMF Code Generation" [Starting]
org.eclipse.emf.codegen.ecore (2.7.0.v20120130-0943) "EMF Ecore Code Generator" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.7.0.v20120130-0943) "EMF Ecore Code Generator UI" [Starting]
org.eclipse.emf.codegen.ui (2.6.0.v20120130-0943) "EMF Code Generation UI" [Starting]
org.eclipse.emf.common (2.7.0.v20120127-1122) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.7.0.v20120130-0943) "EMF Common UI" [Active]
org.eclipse.emf.converter (2.5.0.v20120130-0943) "EMF Model Converter" [Starting]
org.eclipse.emf.databinding (1.2.0.v20120130-0943) "EMF Data Binding" [Starting]
org.eclipse.emf.databinding.edit (1.2.0.v20120130-0943) "EMF Edit Data Binding" [Starting]
org.eclipse.emf.ecore (2.7.0.v20120127-1122) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.7.1.v20120127-1122) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.5.0.v20120130-0943) "EMF Change Edit" [Starting]
org.eclipse.emf.ecore.edit (2.7.1.v20120130-0943) "EMF Ecore Edit" [Starting]
org.eclipse.emf.ecore.editor (2.7.0.v20120130-0943) "EMF Sample Ecore Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.7.0.v20120127-1122) "EMF XML/XMI Persistence" [Active]
org.eclipse.emf.edit (2.7.2.v20120130-0943) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.7.0.v20120130-0943) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.6.0.v20120130-0943) "EMF Model Exporter" [Starting]
org.eclipse.emf.importer (2.6.0.v20120130-0943) "EMF Model Importer" [Starting]
org.eclipse.emf.importer.ecore (2.6.0.v20120130-0943) "EMF Ecore Importer" [Starting]
org.eclipse.emf.importer.java (2.6.0.v20120130-0943) "EMF Annotated Java Importer" [Starting]
org.eclipse.emf.importer.rose (2.6.0.v20120130-0943) "EMF Rose Importer" [Starting]
org.eclipse.emf.mapping (2.7.0.v20120130-0943) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.6.0.v20120130-0943) "EMF Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20120130-0943) "EMF Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.7.0.v20120130-0943) "EMF Ecore to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.5.0.v20120130-0943) "EMF Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.7.0.v20120130-0943) "EMF Ecore to XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.6.0.v20120130-0943) "EMF Ecore to XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.6.0.v20120130-0943) "EMF Mapping UI" [Starting]
org.eclipse.emf.transaction (1.4.0.v20100331-1738) "EMF Model Transaction Core" [Starting]
org.eclipse.emf.validation (1.4.0.v20100428-2315) "EMF Validation Framework Core" [Starting]
org.eclipse.emf.workspace (1.5.1.v20110823-1800) "EMF Model Transaction Workbench Integration Core" [Starting]
org.eclipse.epp.mpc.core (1.1.1.I20110907-0947) "Marketplace Client" [Starting]
org.eclipse.epp.mpc.help.ui (1.1.1.I20110907-0947) "Marketplace Client" [Resolved]
org.eclipse.epp.mpc.ui (1.1.1.I20110907-0947) "Marketplace Client" [Active]
org.eclipse.epp.package.jee (1.4.2.20120131-1457) "Java EE IDE" [Resolved]
org.eclipse.epp.usagedata.gathering (1.3.1.R201106061540) "Usage Data Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.3.1.R201106061540) "Usage Data Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.3.1.R201106061540) "Usage Data UI Plug-in" [Starting]
org.eclipse.equinox.app (1.3.100.v20110321) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20110523) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.200.v20110502) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.3.1.R37x_v20110701) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.100.v20110502) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.0.v20110815-1438) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.300.v20110815-1438) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.100.v20110502) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.100.v20110502) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.200.v20110502) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.300.v20110502) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.200.v20100503) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.2.0.v20110502) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.1.100.v20110502) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.101.v20110815-1419) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20110815-1419) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.1.1.v20120113-1346) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.1.1.v20111126-0211) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20111126-0153) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.300.v20110815-1419) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.discovery (1.0.100.v20110502-1955) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.discovery.compatibility (1.0.1.v20110502-1955) "Equinox Provisioning Discovery" [Starting]
org.eclipse.equinox.p2.engine (2.1.1.R37x_v20111003) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20110815-1419) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20110815-1419) "Equinox Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20110815-1438) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.1.0.v20110815-1419) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.0.v20110815-1419) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.1.1.R37x_v20111111) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.2.0.v20110815-1419) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.0.0.v20110815-1438) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20110815-1419) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.100.v20110815-1419) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.1.1.v20120113-1346) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.0.100.v20110815-1438) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.1.v20110815-1419) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.300.v20110815-1419) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.0.0.v20111128-0624) "Equinox Provisioning ECF based Transport" [Starting]
org.eclipse.equinox.p2.ui (2.1.1.v20120113-1346) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.discovery (1.0.0.v20110502-1955) "Equinox Provisioning Discovery UI" [Resolved]
org.eclipse.equinox.p2.ui.importexport (1.0.1.R37x_v20111103) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.200.v20110815-1419) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.100.v20110815-1419) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20110815-1419) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.300.v20110815-1419) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.4.2.v20120111-2020) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.101.R37x_v20110810-1611) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.1.1.R37x_v20110822-1018) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.0.v20101004) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.200.v20100503) "Windows Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20110815-1438) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20110815-1438) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.300.v20110502) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.7.2.v20111106-2020) "Graphical Editing Framework GEF" [Starting]
org.eclipse.graphiti (0.8.2.v20120215-0845) "Graphiti (Incubation)" [Starting]
org.eclipse.graphiti.mm (0.8.2.v20120215-0845) "Graphiti Notational Model (Incubation)" [Starting]
org.eclipse.graphiti.pattern (0.8.2.v20120215-0845) "Graphiti Pattern (Incubation)" [Starting]
org.eclipse.graphiti.ui (0.8.2.v20120215-0845) "Graphiti UI (Incubation)" [Starting]
org.eclipse.help (3.5.100.v20110426) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20110425) "Help Application Server" [Starting]
org.eclipse.help.base (3.6.2.v201202080800) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.101.r37_20110819) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.1.r37_20110929) "Help System Webapp" [Starting]
org.eclipse.jdt (3.7.2.v201202080800) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.500.v20110420-1015) "Java Annotation Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.400.v20110305-1450) "Java Compiler Apt IDE" [Acti
Current Time: Sat Nov 08 09:23:39 EST 2025
Powered by FUDForum. Page generated in 0.06587 seconds
