Home » Modeling » Epsilon » [EOL] Change Nodes Resize Constraint
[EOL] Change Nodes Resize Constraint [message #1032971] Wed, 03 April 2013 13:49 Go to next message
I would liek to set the node Resize Constraint to none via an eol transformation.
I tried this so far, but have not really clue what is the right way:
operation customizeResize(){
	var fmFigure = findNode('FeatureModel');
	fmFigure.resizeConstraint := GmfGraph!Direction#None;
operation findNode(name : String) {
  return GmfGraph!Node.all.selectOne(s|s.name = name);
Can someone tell how to do this?
Re: [EOL] Change Nodes Resize Constraint [message #1032976 is a reply to message #1032971] Wed, 03 April 2013 13:59 Go to previous messageGo to next message
If you want to make the node not resizable, we have recently added an Eugenia annotation for just that:
@gmf.node(..., resizable="false")
class X {
It's only available on a very recent interim release. We haven't had much time to try it before making it the official interim release, but you might want to try it out. It is available at this update site for now (we'll move it to the proper interim URL in a few weeks if all goes well):
http://download.eclipse.org/epsilon/interim-very-new/
If you want to stay with Epsilon 1.0, you may want to adapt the EOL code that we use to implement this annotation:
var figureClass = node.name + 'Figure';
var figure_viewmaps = GmfGen!InnerClassViewmap.all.select(r|r.className = figureClass);
for (figure_viewmap in figure_viewmaps) {
  -- Resize constraint which forbids resizing
  -- NORTH (1), SOUTH (4), EAST (8) and WEST (16): all handles are not resizable
  var resizeconstraint_not_resizable = new GmfGen!ResizeConstraints;
  resizeconstraint_not_resizable.nonResizeHandles := 31;
  figure_viewmap.attributes.add(resizeconstraint_not_resizable);
[Updated on: Wed, 03 April 2013 14:00] by Moderator
Re: [EOL] Change Nodes Resize Constraint [message #1033098 is a reply to message #1032976] Wed, 03 April 2013 17:15 Go to previous messageGo to next message
Thanks for the quick response !! I tried out the new release and it's working with Juno Service Release 2 Wink
Is there an overview about the new annotations?
Phil
Re: [EOL] Change Nodes Resize Constraint [message #1033913 is a reply to message #1033098] Thu, 04 April 2013 16:00 Go to previous message
Glad it worked Smile.
All annotations should be listed in the official GMF tutorial [1], but if you want to see only the new ones, they're in the bug report at [2].
[1]: http://eclipse.org/epsilon/doc/articles/eugenia-gmf-tutorial/
[2]: https://bugs.eclipse.org/bugs/show_bug.cgi?id=400569
Previous Topic:[EGL] Interfaces and Generalizations
Next Topic:[Flock] UnresolvedReference
Current Time: Fri Jul 25 23:01:30 EDT 2025
Powered by FUDForum. Page generated in 0.06780 seconds
