Home » Archived » Visual Editor (VE) » NoSuchMethodError with swt.graphics
NoSuchMethodError with swt.graphics [message #103210] Tue, 23 August 2005 19:49 Go to next message
Originally posted by: gmurphy92.comcast.net
I am having problems with VE 1.1, using Eclipse 3.1 and Java 1.5_04.
Everything in the configuration appears to be installed and doesn't have
any conflicts (from the "Manage Configuration.." view. When I create a
Visual Class, I get the follwoing error:
!ENTRY org.eclipse.jface 4 2 2005-08-23 19:35:19.484
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.swt.graphics.GC.getAdvanced()Z
at org.eclipse.draw2d.SWTGraphics.init(SWTGraphics.java:707)
at org.eclipse.draw2d.SWTGraphics.<init>(SWTGraphics.java:258)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$RotatedTit leLabel.updateImage(FlyoutPaletteComposite.java:1051)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$RotatedTit leLabel.setFont(FlyoutPaletteComposite.java:1033)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s.setFont(FlyoutPaletteComposite.java:1321)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$FontManage r.register(FlyoutPaletteComposite.java:1422)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s.init(FlyoutPaletteComposite.java:1277)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s. <init>(FlyoutPaletteComposite.java:1244)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.createTitl e(FlyoutPaletteComposite.java:269)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.access$5(F lyoutPaletteComposite.java:268)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$Sash.<init >(FlyoutPaletteComposite.java:673)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.createSash (FlyoutPaletteComposite.java:265)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.<init>(FlyoutPaletteComposite.java:190)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createSplitpaneEditor(JavaVisualEditorPart.java:636 )
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createPartControl(JavaVisualEditorPart.java:574)
at
org.eclipse.ui.internal.EditorManager.busyRestoreEditorHelpe r(EditorManager.java:1237)
at
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:1102)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1064)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:1062)
at
org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1648)
at
org.eclipse.ui.internal.EditorManager$Editor.getPart(EditorM anager.java:1639)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:26 0)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
at
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.newapi.LeftToRightTabO rder.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.newapi.TabbedStackPres entation.selectPart(TabbedStackPresentation.java:391)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1070)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1019)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 23)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:406)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:267)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:829)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:809)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:697)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:660)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2236)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2165)
at org.eclipse.ui.internal.WorkbenchPage.access$7(WorkbenchPage .java:2157)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2143)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2138)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:231)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:129)
at
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 0)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:212)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:188)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:304)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:805)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:658)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:40)
This error gives me a tab that is entirely grey, with "Visual Editor" as
the tab label. When I close this tab, I get the following error:
!ENTRY org.eclipse.ui 4 0 2005-08-23 19:46:44.984
!MESSAGE org.eclipse.swt.graphics.GC.getAdvanced()Z
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:235)
at
org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:88)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:270)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 116)
at
org.eclipse.ui.internal.presentations.PresentablePart.setFoc us(PresentablePart.java:134)
at
org.eclipse.ui.internal.presentations.newapi.TabbedStackPres entation$1.handleEvent(TabbedStackPresentation.java:92)
at
org.eclipse.ui.internal.presentations.newapi.AbstractTabFold er.fireEvent(AbstractTabFolder.java:263)
at
org.eclipse.ui.internal.presentations.newapi.AbstractTabFold er.fireEvent(AbstractTabFolder.java:268)
at
org.eclipse.ui.internal.presentations.newapi.AbstractTabFold er.handleMouseDown(AbstractTabFolder.java:322)
at
org.eclipse.ui.internal.presentations.newapi.AbstractTabFold er$3.mouseDown(AbstractTabFolder.java:79)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:132)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
I have read all the current posts and looked at all the promising Google
hits, and so far none of the issues reported or recommendations provided
there have helped resolve this problem for me. I have reinstalled from
scratch twice now, and I'm really anxious to get on with my life. If
anyone has any input, thanks in advance.
Re: NoSuchMethodError with swt.graphics [message #103284 is a reply to message #103210] Wed, 24 August 2005 09:44 Go to previous messageGo to next message
GC.getAdvanced() was introduced in Eclipse 3.1. Could it be that you
have an older version of SWT plugin? Could you please try a new download
of the required plugins and try again.
Sri.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NoSuchMethodError with swt.graphics [message #103432 is a reply to message #103284] Wed, 24 August 2005 18:04 Go to previous messageGo to next message
Thanks for the input...I used the Update Manager to look for a
newer/current plugin, but it tells me I have the latest version of all the
plugins I'm running. I looked at the plug in list in the About Eclipse
window, and it tells me I have two SWT plugins. The first is
org.eclipse.swt v3.1.0, and the second is org.eclipse.swt.win32 v3.1.0.
My JFace plugins are org.eclipse.jface v3.1.0 and org.eclipse.jface.text
v3.1.0. I'm not sure what else to do. Thanks in advance for any
assistance.
G. Murphy
Re: NoSuchMethodError with swt.graphics [message #103457 is a reply to message #103432] Wed, 24 August 2005 18:13 Go to previous messageGo to next message
Try a clean installation. There may be old stuff laying around from the
development drivers.
> the plugins I'm running. I looked at the plug in list in the About
> Eclipse window, and it tells me I have two SWT plugins. The first is
> assistance.
> G. Murphy
Rich Kulp
Re: NoSuchMethodError with swt.graphics [message #103714 is a reply to message #103457] Fri, 26 August 2005 00:43 Go to previous message
After a fresh download of everything from the download site (for the third
time) it now works great. Thanks.
Re: NoSuchMethodError with swt.graphics [message #610365 is a reply to message #103210] Wed, 24 August 2005 09:44 Go to previous message
Sri.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NoSuchMethodError with swt.graphics [message #610377 is a reply to message #103284] Wed, 24 August 2005 18:04 Go to previous message
assistance.
G. Murphy
Re: NoSuchMethodError with swt.graphics [message #610379 is a reply to message #103432] Wed, 24 August 2005 18:13 Go to previous message
> assistance.
> G. Murphy
Rich Kulp
Re: NoSuchMethodError with swt.graphics [message #610397 is a reply to message #103457] Fri, 26 August 2005 00:43 Go to previous message
Previous Topic:Reviewing / editing VE
Next Topic:report
Current Time: Sun Jun 15 16:38:26 EDT 2025
Powered by FUDForum. Page generated in 0.04228 seconds
