Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Ecore Tools] Inconsistencies building from CVS
[Ecore Tools] Inconsistencies building from CVS [message #103191] Tue, 20 November 2007 05:10 Go to next message
I'm trying to shift my usage of the GMF Ecore Diagram to the Ecore Tools variant.
Perhaps I'm just too quick off the mark.
I was using Eclipse 3.3.1 and hit problems with WrapLabel/WrappingLabel and so
upgraded to 3.4M3, which fixes the compilation problems but when I
regenerate I find that WrapLabel is used rather than WrappingLabel and that there
are minor differences in the generated files. For instance the wizard category
in plugin.xml changes from org.eclipse.ui.Examples to org.eclipse.emf.ecoretools.diagram.
Is there a preferred mechanism/plug-in versions for dashboard building at present?
Could you please include your Java formatter preferences in CVS so that
regenerated code can match CVS. The dashboard.prefs is also missing from CVS.
Ed Willink
Re: [Ecore Tools] Inconsistencies building from CVS [message #103237 is a reply to message #103191] Tue, 20 November 2007 09:41 Go to previous messageGo to next message
Hi Ed,
Yes, you are probably a little too impatient, but this is very promising
for us : this means that people do not hesitate to try it before its
first release ! :-)
Anyway, as you noticed, CVS source code requires GMF 3.4M3 and its new
WrappingLabel implementation. However, as codegen templates have not
been fully updated, if you try to regenerate, you will get some old
references. I expect it will be soon fixed in the templates.
Then, there are probably some customized code, that we have not reported
at the gmfgen level : we will update this soon.
The Java formatter we are using is the GMF one
( http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/rel eng/org.eclipse.gmf.releng/eclipseSettings/GMF%20Formatter%2 0profile.xml?root=Modeling_Project&content-type=text%2Fx ml&revision=HEAD).
Otherwise, we have not used the Dashboard view to generate the editor.
But I can change this and include it in the CVS if you really need it.
Jacques
Ed Willink a écrit :
> Hi
> variant.
> and so
> that there
> category
> at present?
> CVS.
> Regards
> Ed Willink
Re: [Ecore Tools] Inconsistencies building from CVS [message #103316 is a reply to message #103237] Tue, 20 November 2007 13:54 Go to previous messageGo to next message
--------------010803050302030501060808
Hi Jacques
I presume you had to do a manual replace of all WrapLabel to WrappingLabel
since TextAware.xpt still (CVS one hour ago) uses
protected String getLabelTextHelper(org.eclipse.draw2d.IFigure figure) {
if (figure instanceof org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel) {
return ((org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel) figure).getText();
} else {
return ((org.eclipse.draw2d.Label) figure).getText();
to distinguish figure types. This fails horribly for WrappingLabel which
is not a WrapLabel and cannot be cast to Label. Attempting to open a generated
..ecorediag fails with a CCE.
Ta. That is close to what I deduced. But I seem to need to manually reformat to
match line breaks in comments.
I think you just need to include the attached. At present I know no other
way to activate gmfgen.
Ed
name="org.eclipse.gmf.bridge.ui.dashboard.prefs"
Content-Disposition: inline;
filename="org.eclipse.gmf.bridge.ui.dashboard.prefs"
#Tue Nov 20 09:07:02 GMT 2007
eclipse.preferences.version=1
gmf_dashboard/domainGenerationModel=platform\:/resource/org. eclipse.emf.ecore/model/Ecore.genmodel
gmf_dashboard/domainModel=platform\:/resource/org.eclipse.em f.ecore/model/Ecore.ecore
gmf_dashboard/generationModel=platform\:/resource/org.eclips e.emf.ecoretools.diagram/models/ecore.gmfgen
gmf_dashboard/graphicalDefinitionModel=platform\:/resource/o rg.eclipse.emf.ecoretools.diagram/models/ecore.gmfgraph
gmf_dashboard/mappingModel=platform\:/resource/org.eclipse.e mf.ecoretools.diagram/models/ecore.gmfmap
gmf_dashboard/toolingDefinitionModel=platform\:/resource/org .eclipse.emf.ecoretools.diagram/models/ecore.gmftool
--------------010803050302030501060808--
Re: [Ecore Tools] Inconsistencies building from CVS [message #103456 is a reply to message #103316] Wed, 21 November 2007 11:06 Go to previous message
see my comments below,
> Hi Jacques
> figure) {
> return
> } else {
> generated
In fact, I checked out the GMF source code from CVS, and using
refactoring capabilities on the renaming of a class, it updated all my
old references : this is really better than replacing all the deprecated
references in all my projects using GMF. Refactoring is really powerful!
> reformat to
In fact, after each generation, I manually perform a global "Reformat"
on the whole project : however I noticed, that I behaves strangely on
inlined comments while applying several "Reformat" action. If I have
time, I will try to figure out what is happening and open a bug if
necessary.
I have just committed it on the CVS.
Jacques
> Ed
Re: [Ecore Tools] Inconsistencies building from CVS [message #612605 is a reply to message #103191] Tue, 20 November 2007 09:41 Go to previous message
Hi Ed,
first release ! :-)
Jacques
> Hi
> variant.
> and so
> that there
> category
> at present?
> CVS.
> Regards
> Ed Willink
Re: [Ecore Tools] Inconsistencies building from CVS [message #612618 is a reply to message #103237] Tue, 20 November 2007 13:54 Go to previous message
Hi Jacques
} else {
Ed
Re: [Ecore Tools] Inconsistencies building from CVS [message #612636 is a reply to message #103316] Wed, 21 November 2007 11:06 Go to previous message
> Hi Jacques
> figure) {
> return
> } else {
> generated
> reformat to
necessary.
Jacques
> Ed
Previous Topic:Large objects (BLOB)
Next Topic:[EMF4Net] Proposal
Current Time: Fri Jun 06 22:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.03293 seconds
