Home » Eclipse Projects » EclipseLink » JPA/DCN - working for INSERT; trouble with UPDATE(Not getting updated record when DCN received after update in DB)
JPA/DCN - working for INSERT; trouble with UPDATE [message #1028088] Wed, 27 March 2013 16:27 Go to next message
I have the JPA/DCN set up and working in my application. Any time there is a change in the Oracle 11g DB, my application receives a notification and fires a property change event, sending the table name in the "new value" argument.
When I attempt to re-read the values from the table upon receiving the property change notification, I always get a new record if there was an INSERT performed however I do NOT get an updated record if there was an UPDATE performed.
S, I receive the change notification from the DB but it seems like the cache isn't invalidated for the update like it is for the insert.
Do I have to do something special to make that work? It seems like it works in the JPA/DCN example: http://wiki.eclipse.org/EclipseLink/Examples/JPA/DCN
Re: JPA/DCN - working for INSERT; trouble with UPDATE [message #1028754 is a reply to message #1028088] Thu, 28 March 2013 13:40 Go to previous messageGo to next message
How are you reading the existing updated entities? Be sure you are either getting a new EntityManager or clearing it occasionally, as the managed entities it references are meant to operate like a transaction - once read in, they are cached by the EM and will not see external changes.
Re: JPA/DCN - working for INSERT; trouble with UPDATE [message #1032256 is a reply to message #1028754] Tue, 02 April 2013 15:28 Go to previous message
Thank you. I had not been doing either. I now retrieve a new EntityManager when the DCN is due to an UPDATE operation and so far it seems to be working.
Really appreciate the reply.
Previous Topic:Inheritance and TYPE
Next Topic:Commit object with ID
Current Time: Mon Jul 21 01:22:58 EDT 2025
Powered by FUDForum. Page generated in 0.05956 seconds
