| Eclipse, BIRT, Oracle data set exception [message #103223] | Mon, 02 January 2006 15:33  |  |
| Eclipse User  |  |  |  |  | Originally posted by: segoetz.sbcglobal.net
 I have installed Eclipse 3.1.1 Win 32, and BIRT 1.0.1
 Doing a tutorial, I was able to create a new report using the sample
 database, Classic Models, for my data source. I can preview the data set I
 created, and can see the data in the report when I preview it.
 I have set up two data sources to Oracle databases and get successful
 connection when I click test connection. When I set up a data set for
 either and try to open it, I get the error An unexpected internal
 exception occurred. Please see log for detail. The log says
 Plug-in Provider:Eclipse.org
 Plug-in Name:BIRT Designer UI
 Plug-in ID  rg.eclipse.birt.report.designer.ui
 Version:1.0.1
 Error Code:Error.GUIException.invokedByUnexpectedException
 Error Message:Caused by java.lang.NullPointerException
 Ive tried to set up my paths correctly. Can anyone help? Thanks.
| Re: Eclipse, BIRT, Oracle data set exception [message #118418 is a reply to message #117080] | Fri, 27 January 2006 03:16  |  |
| Eclipse User  |  |  |  |  | Originally posted by: redhuanoon.yahoo.com
 After some clue from Paul Reeves, i rechecked my extra 3rd party downloads
 and notice that i misplaced the ApacheAxis' 6 files. It should be placed
 exactly in
 D:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib
 And voila! it worked on the MySQL.
 (I was trying MySQL thinking that will eliminate me that its just oracle and
 not others, but MySQL had returned the same Http 500.)
 So finally i tried back on Oracle (accessing Compiere DB) and it works like
 magic!
 Have a nice day Paul!
 red1
 "red1" <redhuanoon@yahoo.com> wrote in message
 news:dra1b2$fcg$1@utils.eclipse.org...
 >I do get the same HTTP Status 500 error too. Been trying all sorts of
 >tricks .. even a blank review gives the same error.
 > If i do crack this, i will post here :D
FUDForum. Page generated in 0.23761 seconds
