Home » Modeling » Papyrus » problem in using Duration constraint( "duration constraint" to specify a communication delay constraint on a message)
problem in using Duration constraint [message #1023528] Sun, 24 March 2013 09:17 Go to next message
i am trying to add "duration constraint" to specify a communication delay constraint on a message?
As i know that a Duration constraints apply on interval between two events .
first of all,i should specify the two events?
the first event is (Message send) on the lifelineA and
the second event is (MessageRecv)on the lifelineB.
So i drag from the first event to the second one but duration constraint still not appear ?why?
PS: it is work when drag and drop two events on the same lifeline .
How can i solve this problem?
Re: problem in using Duration constraint [message #1024018 is a reply to message #1023528] Mon, 25 March 2013 12:46 Go to previous messageGo to next message
Any advice?
Re: problem in using Duration constraint [message #1028412 is a reply to message #1024018] Thu, 28 March 2013 04:07 Go to previous messageGo to next message
On 25-03-13 17:46, Ann barry wrote:
> Any advice?
Nope, just a "me too", sorry.
I really would like to specify a duration constraint between a Message
Receive Event (the request) and a Message Send event ( the response).
TIA
Joost
Re: problem in using Duration constraint [message #1028441 is a reply to message #1023528] Thu, 28 March 2013 04:57 Go to previous messageGo to next message
Hi Ann,
I seem to notice that if:
1. the end of a send message and the top of an InteractionCompartiment
are "the same",
2. the start of a reply message and the bottom of an
InteractionCompartiment are "the same",
and
3. one tries to connect the send message end and the
InteractionCompartiment bottom
the duration constraint does not appear. However if I manage to connect
either both the message send and message reply (which has a great luck
factor because of a lack of drag and drop skills) or the top/bottom of
the InteractionCompartiment (which is rather easy to do with drag and
drop) the duration constraint appears.
In my case I managed to first create the constraint by dragging and
dropping the InteractionCompartiment and then reconnect the constraint
to my messages by using the property editors.
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
tel: 024-3888063 / 06-51855277
fax: 024-3608416
web: www.askesis.nl
Re: problem in using Duration constraint [message #1029525 is a reply to message #1028441] Fri, 29 March 2013 16:37 Go to previous messageGo to next message
Thank you Joost ,
Could you please clarify these steps a bit ?
because until now the problem not solved
Re: problem in using Duration constraint [message #1031954 is a reply to message #1029525] Tue, 02 April 2013 08:00 Go to previous message
On 29-03-13 21:37, Ann barry wrote:
> Thank you Joost ,
Attached is an example project with a Duration Constraint.
I created the constraint by (it may not be the best way to do it, but at
least this worked):
1. Select the Duration Constraint in the palette
2. Move the mouse over the sequence diagram to the top of the
InteractionCompartiment until the mouse cursor changes from a cross to
some undefined figure and an open circle appears.
3.Click and drag the mouse to the end of the InteractionCompartiment and
release the mous in the appearing open circle.
4. This should create a Duration Constraint for the InteractionCompartiment.
5. Change the constraint elements through the properties editor if needed.
Hope this helps
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
fax: 024-3608416
web: www.askesis.nl
Re: problem in using Duration constraint [message #1031959 is a reply to message #1029525] Tue, 02 April 2013 08:00 Go to previous message
> Thank you Joost ,
least this worked):
Hope this helps
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
fax: 024-3608416
web: www.askesis.nl
Re: problem in using Duration constraint [message #1031963 is a reply to message #1029525] Tue, 02 April 2013 08:00 Go to previous message
> Thank you Joost ,
least this worked):
Hope this helps
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
fax: 024-3608416
web: www.askesis.nl
Previous Topic:Papyrus vs eUML2
Next Topic:How to assign a value for a slot of type NFP_Duration
Current Time: Wed Jul 23 12:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.30335 seconds
