Home » Modeling » EMF » [CDO] CDO server throws exception after migrating to M6 (MySQL)
[CDO] CDO server throws exception after migrating to M6 (MySQL) [message #1031596] Mon, 01 April 2013 21:00 Go to next message
After upgrading to M6 the CDO server prints exceptions to the log / console and I can no longer access the data stored in CDO
!ENTRY org.eclipse.equinox.app 4 0 2013-04-01 17:02:52.112
!MESSAGE Index field is nullable: ID
!STACK 0
org.eclipse.net4j.db.DBException: Index field is nullable: ID
        at org.eclipse.net4j.internal.db.ddl.DBIndex.addIndexField(DBIndex.java:118)
        at org.eclipse.net4j.internal.db.ddl.DBIndex.<init>(DBIndex.java:56)
        at org.eclipse.net4j.internal.db.ddl.DBTable.addIndex(DBTable.java:209)
        at org.eclipse.net4j.spi.db.DBAdapter.addIndex(DBAdapter.java:303)
        at org.eclipse.net4j.spi.db.DBAdapter.readIndices(DBAdapter.java:271)
        at org.eclipse.net4j.spi.db.DBAdapter.readIndices(DBAdapter.java:227)
        at org.eclipse.net4j.spi.db.DBAdapter.readSchema(DBAdapter.java:168)
        at org.eclipse.net4j.db.DBUtil.readSchema(DBUtil.java:240)
        at org.eclipse.net4j.db.DBUtil.readSchema(DBUtil.java:231)
        at org.eclipse.net4j.spi.db.DBAdapter.readSchema(DBAdapter.java:141)
        at org.eclipse.net4j.internal.db.DBDatabase$1.run(DBDatabase.java:59)
        at org.eclipse.net4j.internal.db.DBDatabase$1.run(DBDatabase.java:1)
        at org.eclipse.net4j.db.DBUtil.execute(DBUtil.java:651)
        at org.eclipse.net4j.internal.db.DBDatabase.<init>(DBDatabase.java:55)
        at org.eclipse.net4j.db.DBUtil.openDatabase(DBUtil.java:173)
        at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:621)
        at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
        at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
        at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
        at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
        at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1874)
        at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
        at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:291)
        at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:116)
        at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
        at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
        at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
        at java.lang.Thread.run(Thread.java:679)
Caused by: java.lang.Exception: The field ID has been constructed here:
        at org.eclipse.net4j.internal.db.ddl.DBField.<init>(DBField.java:88)
        at org.eclipse.net4j.internal.db.ddl.DBTable.addField(DBTable.java:112)
        at org.eclipse.net4j.spi.db.DBAdapter.readFields(DBAdapter.java:205)
        at org.eclipse.net4j.spi.db.DBAdapter.readSchema(DBAdapter.java:167)
        ... 26 more
I think it stems from the fact that CDO used to create the table for cdo_branches and cdo_external_refs with a NULLABLE id. cdo_commit_infos has a NULLABLE commit_time
Here's a snippet from mysqdump:
CREATE TABLE `cdo_branches` (
  `id` int(11) DEFAULT NULL,
  `name` longtext COLLATE utf8_unicode_ci,
  `base_id` int(11) DEFAULT NULL,
  `base_time` bigint(20) DEFAULT NULL,
  UNIQUE KEY `cdo_branches_idx0` (`id`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;
CREATE TABLE `cdo_external_refs` (
  `id` bigint(20) DEFAULT NULL,
  `uri` longtext COLLATE utf8_unicode_ci,
  `committime` bigint(20) DEFAULT NULL,
  UNIQUE KEY `cdo_external_refs_idx0` (`id`),
  KEY `cdo_external_refs_idx1` (`uri`(255))
CREATE TABLE `cdo_commit_infos` (
  `commit_time` bigint(20) DEFAULT NULL,
  `previous_time` bigint(20) DEFAULT NULL,
  `branch_id` int(11) DEFAULT NULL,
  `user_id` longtext COLLATE utf8_unicode_ci,
  `commit_comment` longtext COLLATE utf8_unicode_ci,
  UNIQUE KEY `cdo_commit_infos_idx0` (`commit_time`),
  KEY `cdo_commit_infos_idx1` (`branch_id`),
  KEY `cdo_commit_infos_idx2` (`user_id`(255))
I tried to patch my mysqdump files and restore the DB, but it did not get rid of the error for me so far.
It would be nice if CDO handled the schema upgrade that was introduced in M6 gracefully.
Re: [CDO] CDO server throws exception after migrating to M6 (MySQL) [message #1034328 is a reply to message #1031596] Fri, 05 April 2013 05:58 Go to previous messageGo to next message
Hi Lothar,
I fear that a DB-specific, automatic migration of the nullable attribute of the column definitions is too much effort
for me. But it seems that most DBs have never complained about the indexes on nullable columns, so I've added the
runtime option "org.eclipse.net4j.db.DisableNullableCheck", which you can set to "true" to skip the new check.
The easiest way to adjust your schema is to use CDOServerExporter / Importer. Is that okay for you?
Cheers
/Eike
http://www.esc-net.de
Am 02.04.2013 03:00, schrieb Lothar Werzinger:
> in CDO
> !STACK 0
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> ... 26 more
Re: [CDO] CDO server throws exception after migrating to M6 (MySQL) [message #1034613 is a reply to message #1034328] Fri, 05 April 2013 13:05 Go to previous messageGo to next message
I found a way to fix-up my sql backups with the script below.
#!/bin/bash
cat >sedscript << @@@END@@@
/CREATE TABLE/{
N
s|\(CREATE TABLE.*\n.*\`id\`.*\),|\1 NOT NULL,|
s|\(CREATE TABLE.*\n.*\`cdo_id\`.*\),|\1 NOT NULL,|
s|\(CREATE TABLE.*\n.*\`area_id\`.*\),|\1 NOT NULL,|
s|\(CREATE TABLE.*\n.*\`commit_time\`.*\),|\1 NOT NULL,|
s|\(CREATE TABLE.*\n.*\`cdo_source\`.*\),|\1 NOT NULL,|
s|\(CREATE TABLE.*\n.*\`name\`.*\),|\1 NOT NULL,|
s|\(CREATE TABLE.*\n.*\`uri\`.*\),|\1 NOT NULL,|
s|DEFAULT NULL NOT NULL|NOT NULL|
s|NOT NULL NOT NULL|NOT NULL|
/object_id/{
s|\(\`object_id\`.*\) DEFAULT NULL,|\1 NOT NULL,|
@@@END@@@
for f in *.sql ; do
  echo $f
  sed -i -f sedscript $f
done
P.S.
We use the lowercase names feature of MySQL, so that we can transfer backups between Windows and Linux systems.
Re: [CDO] CDO server throws exception after migrating to M6 (MySQL) [message #1035019 is a reply to message #1034328] Sat, 06 April 2013 03:19 Go to previous message
Am 05.04.2013 11:58, schrieb Eike Stepper:
> Hi Lothar,
> for me.
Update: I reopened this bug and want to find a way to migrate automatically:
404047: DB-Migration from 4.1 to 4.2 failed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=404047
Cheers
/Eike
Previous Topic:Update Site for EMF Validation
Next Topic:CDO MappingStrategy example and CDO Questions.
Current Time: Wed Jul 23 11:55:15 EDT 2025
Powered by FUDForum. Page generated in 0.59168 seconds
