Home » Modeling » Epsilon » [Flock] UnresolvedReference
[Flock] UnresolvedReference [message #1029358] Fri, 29 March 2013 11:09 Go to next message
Tring to migrate a model (XMI size: 774KB), I get an UnresolvedReferenceException.
When looking into the XMI file and manually counting elements indexes, I can definitely assert that referenced element does exist.
Someone has an idea ?
Thanks !
Exception :
Internal error: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Unresolved reference '/17/@data.0/@etudes.0'
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors[XMLLoadImpl.java:83]
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load[XMLLoadImpl.java:191]
Internal error: java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
	at java.util.ArrayList.RangeCheck[Unknown Source]
	at java.util.ArrayList.get[Unknown Source]
	at org.eclipse.epsilon.flock.FlockContext.getModelFromRepositoryByIndex[FlockContext.java:76]
	at org.eclipse.epsilon.flock.FlockContext.setMigratedModel[FlockContext.java:72]
Model sample :
<fr.bull.indus.model_1:Utilisateur matricule="ADMIN" nom="ADMIN" prenom="ADMIN" roles="/2 /3 /4" password="ADMIN" sessionID="-1">
    <data xsi:type="fr.bull.ec.etm.model:ProjetEtude" nom="Projet Reference" createur="/17">
      <etudes nom="Reference" elements="/17/@data.1 /17/@data.2 /17/@data.3 /17/@data.4 /17/@data.5 /17/@data.6 /17/@data.7 /17/@data.8 /17/@data.9 /17/@data.10 /17/@data.11 /17/@data.12 /17/@data.13 /17/@data.14 /17/@data.15 /17/@data.16 /17/@data.17 /17/@data.18 /17/@data.19 /17/@data.20 /17/@data.21 /17/@data.22 /17/@data.23 /17/@data.24 /17/@data.25 /17/@data.26 /17/@data.27 /17/@data.28 /17/@data.29 /17/@data.30 /17/@data.31 /17/@data.32 /17/@data.33 /17/@data.34 /17/@data.35 /17/@data.36 /17/@data.37 /17/@data.38" partage="true" type="REFERENCE" createur="/17"/>
    </data>
[Updated on: Fri, 29 March 2013 11:10] by Moderator
Re: [Flock] UnresolvedReference [message #1031343 is a reply to message #1029358] Mon, 01 April 2013 11:49 Go to previous messageGo to next message
Have you tried to open the model with Exeed or the sample EMF reflective model editor? Please follow these steps:
1. Register your .ecore metamodel by right-clicking on it and selecting "Register EPackages" on the Project Manager view.
2. Open your .xmi file with "Open with..." -> "Sample Reflective EMF Model Editor" or "Exeed editor" (they're quite similar).
Flock loads .xmi models using plain old EMF facilities, so if EMF can't load the model it won't be able to do much :-/.
Re: [Flock] UnresolvedReference [message #1031780 is a reply to message #1031343] Tue, 02 April 2013 03:20 Go to previous messageGo to next message
Thanks for your reply Antonio.
After registering all EPackages (my metamodel is defined by several Ecore files), I can open XMI with both editors but it takes a very long time (10 min or more for each editor).
I get no error but it seems I can't expand some nodes, it's weird because in properties view node's children are displayed ...
Have I to consider memory issues ? It's worrying me because my XMI file size is only 774KB ...
[Updated on: Tue, 02 April 2013 03:22] by Moderator
Re: [Flock] UnresolvedReference [message #1031787 is a reply to message #1031780] Tue, 02 April 2013 03:32 Go to previous messageGo to next message
I'm going forward ....
Succeeded in converting XMI with Flock Launcher without no error by removing opposite reference which causes error
But output XMI does not contain all input elements ....
774KB -> 153KB
Always the same contents if I repeat operation.
Output file seems to be consistent ...
Really weird ....
[Updated on: Tue, 02 April 2013 04:32] by Moderator
Re: [Flock] UnresolvedReference [message #1032842 is a reply to message #1031787] Wed, 03 April 2013 09:57 Go to previous messageGo to next message
Hi ben ben,
How did you obtain the original model, if I may ask? It looks as if the original inter-model references were broken.
Have you tried loading the original model from a Java program using EMF and checking all the cross references? We have Concordance [1] for checking inter-model references, but I think it doesn't work for internal references within the same model.
[1]: http://www.eclipse.org/epsilon/doc/concordance/
[Updated on: Wed, 03 April 2013 09:58] by Moderator
Re: [Flock] UnresolvedReference [message #1034451 is a reply to message #1029358] Fri, 05 April 2013 08:52 Go to previous message
I think I've located the problem.
My metamodel consists of several ECore files.
In migration process, all references between 2 differents Ecore metamodels are skipped (not migrated).
But, if I specify a migration rule like this :
migrated.<feature> = original.<feature>;
or
migrated.<feature> = original.<feature>.equivalent();
then reference is migrated well.
I managed to get around this issue by automatically generating a Migration strategy file for all features, but it does not wotk for Enums (ClassCastException).
So if there's a way to solve original problem I would appreciate Wink
If not, do you know how I can explicitly copy enum values ?
Thanks !
Last question: Is Flock fully compliant with multiple ECore use ?
[Updated on: Fri, 05 April 2013 08:54] by Moderator
Previous Topic:[EOL] Change Nodes Resize Constraint
Next Topic:Test EGL Templates using EUnit
Current Time: Thu Jul 24 22:22:30 EDT 2025
Powered by FUDForum. Page generated in 0.08257 seconds
