Home » Archived » BIRT » Change oda-data-source FILELIST property at runtime
Change oda-data-source FILELIST property at runtime [message #102230] Fri, 23 December 2005 17:37 Go to next message
Originally posted by: doug_porter.dailyaccess.nospam.com
I am trying to change the FILELIST property inside the oda-data-source property at runtime. I was trying to get a
ReportDesignHandle using the design engine and then iterate the datasources, but I can't seem to find the right call to change the
existing property. I'm sure it can be done. Anyone got a pointer to the right method call?
Doug Porter
DailyAccess Corporation
Re: Change oda-data-source FILELIST property at runtime [message #103031 is a reply to message #102230] Fri, 30 December 2005 00:00 Go to previous messageGo to next message
Originally posted by: rvedre.hotmail.com
Doug -
If you haven't already figured it out, following is code snippet I am
using to change the FILELIST property at runtime.
ReportDesignHandle reportDesignHandle = session.openDesign(reportPath);
SlotHandle datasourceSlotHandle = reportDesignHandle.getDataSources();
OdaDataSourceHandle dataSource = null;
if (datasourceSlotHandle.getCount() > 0) {
dataSource = (OdaDataSourceHandle) (datasourceSlotHandle.get(0));
dataSource.setStringProperty( "FILELIST", dataSourceFileList);
Did you have sucess using "InputStream as input to XML DataSource" ?
-Rana.
"Doug Porter" <doug_porter@dailyaccess.nospam.com> wrote in message
news:dohtui$hjr$1@utils.eclipse.org...
> right method call?
> Doug Porter
Re: Change oda-data-source FILELIST property at runtime [message #103099 is a reply to message #103031] Fri, 30 December 2005 09:55 Go to previous messageGo to next message
Thanks Rana.
No, not yet. Once I get this version up and working I'll work on integrating in an InputStream versus a file or URL.
Doug Porter
"Rana" <rvedre@hotmail.com> wrote in message news:dp2eq4$277$1@utils.eclipse.org...
> Doug -
> -Rana.
> > right method call?
> > Doug Porter
Re: Change oda-data-source FILELIST property at runtime [message #103112 is a reply to message #103031] Fri, 30 December 2005 11:14 Go to previous message
After making the changes to the report design is it possible to convert it to an IReportRunnable object without saving it to disk
and using the ReportEngine's openReportDesign( ) methods.
Doug Porter
> Doug -
> -Rana.
> > right method call?
> > Doug Porter
Previous Topic:Happy new year!
Next Topic:Get Report ResultSet in Runtime
Current Time: Wed Sep 17 16:55:02 EDT 2025
Powered by FUDForum. Page generated in 0.03310 seconds
