Home » Modeling » TMF (Xtext) » Issue generating a DSL grammar
Issue generating a DSL grammar [message #1016319] Tue, 05 March 2013 21:41 Go to next message
Hi all,
I am trying of create a grammar in order to define the method body and then generate code in some programming languaje. I want to do something like this :
package example {
import example.*
datatype String
datatype Numeric
datatype Boolean
datatype Date
entity Organization
country : String
userList : User
define op createUser (user: User){
precondition : user.name NOT IN userList
entity User
govId:String
country:String
entity Employee extends example.User{
fecha: Date
entity Dependency
I have a problem when i want to get the attributes of the input parameters of the Method as you can see in the image in red color . I dont know how i can modify my grammar with the purpose i can get the attributes of the objet used as input to the method. My grammar is as follows
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "MyDsl"
MyDsl:
(elements+=AbstractElement)*;
PackageDeclaration:
'package' name=QualifiedName '{'
AbstractElement:
PackageDeclaration | Type | Import;
QualifiedName:
ID ('.' ID)*;
Import:
'import' importedNamespace=QualifiedNameWithWildcard;
QualifiedNameWithWildcard:
QualifiedName '.*'?;
Type:
DataType | Entity;
DataType:
'datatype' name=ID;
Entity:
'entity' name=ID
('extends' superType=[Entity|QualifiedName])?
(attribute+=Attributes)*
/* (features += Feature)**/
(operation+=Operations)*
Attributes:
(many ?= 'many')? name = ID ':' type = [Type | QualifiedName];
Operations:
'define op ' name=ID '(' parameter = Parameters ')' '{' (precondition+=Preconditions)* '}';
Parameters:
name=ID ':' type=[Type|QualifiedName];
Preconditions:
'precondition :' param=[Parameters|QualifiedName] 'NOT IN' attribute=[Attributes|QualifiedName];
Thanks in Advance
Re: Issue generating a DSL grammar [message #1016499 is a reply to message #1016319] Wed, 06 March 2013 11:56 Go to previous messageGo to next message
i think this is basically a scoping issue never the less.
in your grammar you have
Preconditions:
so let us change it to
Preconditions:
'precondition :' param=[Attributes|QualifiedName] 'NOT IN' attribute=[Attributes|QualifiedName];
and use scoping like
class MyDslScopeProvider extends org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider {
	def IScope scope_Preconditions_param(Operations ctx, EReference ref) {
		if (ctx.parameter.type instanceof Entity) {
			Scopes::scopeFor((ctx.parameter.type as Entity).attribute, [Attributes a|QualifiedName::create(ctx.parameter.name, a.name)], IScope::NULLSCOPE)
		} else{
			IScope::NULLSCOPE
Re: Issue generating a DSL grammar [message #1016531 is a reply to message #1016499] Wed, 06 March 2013 14:16 Go to previous messageGo to next message
Thanks you so much for your help.
Although I do not really understand when i should use scoping.I will study a little about it.
I'm going to try to do you tell me and then i'll tell you the results.
Re: Issue generating a DSL grammar [message #1031015 is a reply to message #1016499] Mon, 01 April 2013 00:12 Go to previous messageGo to next message
Hi Christian,
I did what you recommended me and It Works partially.
I put your instrutions (red color) with some changes (blue color) in the Scope Class, but i have a problem trying to pass the arguments to the method named "scopeFor" when i translated the code "[Attributes a|QualifiedName::create(ctx.parameter.name, a.name)]" because an argument type function is mandatory. If I omit this parameter , i can get the attributes of the entity without a Qualified part.
public class MyDslScopeProvider extends AbstractDeclarativeScopeProvider {
// if (ctx.parameter.type instanceof Entity) {
// Scopes.scopeFor((ctx.parameter.type as Entity).attribute, [Attributes a|QualifiedName::create(ctx.parameter.name, a.name)], IScope::NULLSCOPE)
// } else{
// IScope :: NULLSCOPE
if(ctx.getParameter().getType() instanceof Entity) {
return Scopes.scopeFor (((Entity)(ctx.getParameter().getType())).getAttribute()/*,QualifiedName.create(ctx.getParameter().getName())*/, IScope.NULLSCOPE);
} else {
return IScope.NULLSCOPE;
Do you know how can i solve this issue?
Thanks in advance for your help.
Re: Issue generating a DSL grammar [message #1031110 is a reply to message #1031015] Mon, 01 April 2013 03:34 Go to previous messageGo to next message
Hi the op wants a function that turns an attribute to a qualified
name as second param so you have yo pass one. E.g. by using a closure
and xtends autoconversion from closure to single method interface. So
why did you change that from my code?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Issue generating a DSL grammar [message #1031667 is a reply to message #1031110] Mon, 01 April 2013 23:41 Go to previous messageGo to next message
I'm working with Eclipse framework in the class MyDslScopeProvider such as you can see in the attached image https://skydrive.live.com/redir?resid=505EBE8B3650C880!369&authkey=!AIyAxssJNCttJyc. If I put the code ([Attributes a|QualifiedName::create(ctx.parameter.name, a.name)]) in the class a compilation problem ocurrs. I'm having trouble translating this code by one who can understand the tool in Java.
Thanks for you help.
Re: Issue generating a DSL grammar [message #1031736 is a reply to message #1016319] Tue, 02 April 2013 02:16 Go to previous messageGo to next message
you could try this:
return Scopes.scopeFor (((Entity)(ctx.getParameter().getType())).getAttribute(),
  new com.google.common.base.Function<Attributes, QualifiedName>() {
    public QualifiedName apply(Attributes a) {
      return QualifiedName.create(ctx.getParameter().getName(), a.getName());
  ,IScope.NULLSCOPE);
and define the method args as final e.g. "final Operations ctx".
[Updated on: Tue, 02 April 2013 02:18] by Moderator
Re: Issue generating a DSL grammar [message #1031737 is a reply to message #1031667] Tue, 02 April 2013 02:17 Go to previous messageGo to next message
hmmmmm id thought you would find out that much yourself.
If your class is a java and not an xtend class you have of course to use a annonymous inner class of com.google.common.base.Function<T, QualifiedName>
Re: Issue generating a DSL grammar [message #1033190 is a reply to message #1031737] Wed, 03 April 2013 20:29 Go to previous message
Thank you very much for your help, I was looking for documentation about it but I hadn,t found.
I appreciate your help.
Previous Topic:Apply a quickfix from java class
Next Topic:How to insert non-existing fields into the scope
Current Time: Thu Oct 30 20:02:03 EDT 2025
Powered by FUDForum. Page generated in 0.07695 seconds
