Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP 4.4 profiling timeout on launch
TPTP 4.4 profiling timeout on launch [message #102906] Tue, 03 July 2007 18:33 Go to next message
When starting a profile session for TPTP 4.4, for a large-ish app
(~2500 classes w/lots of Threads), I get the following:
org.eclipse.core.runtime.CoreException
A time-out occurred while attempting to launch the process
org.eclipse.core.runtime.CoreException: A time-out occurred while attempting to launch the process
at org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
at org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:131)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:570)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:518)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:311)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
at org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
at org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
at java.lang.Thread.run(Thread.java:595)
Per a couple of posts I found on Google, I've trimmed back the class filter
to about 120 of those 2500 classes. However, the error persists.
App being profile runs and debugs just fine.
Any thoughts?
Thanks.
-=< tom >=-
Re: TPTP 4.4 profiling timeout on launch [message #102919 is a reply to message #102906] Wed, 04 July 2007 03:29 Go to previous messageGo to next message
Tom,
Please provide the following information:
1. Exact Eclipse and TPTP versions
2. JVM Version (use java -version)
3. Are you using the Integrated Agent Controller or a standalone AC? If
standalone, which version?
4. O/S version and architecture
Can you successfully profiler a simple "hello world" application?
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: TPTP 4.4 profiling timeout on launch [message #103025 is a reply to message #102919] Wed, 04 July 2007 16:09 Go to previous messageGo to next message
Hi, Asaf,
Eclipse 3.3, TPTP 4.4. TPTP is the only plugin currently installed. The
installation went to a new directory and to a new workspace. The project
of interest was imported from an Eclipse 3.2.1 installation.
java version "1.5.0_11"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_11-b03)
Java HotSpot(TM) Client VM (build 1.5.0_11-b03, mixed mode, sharing)
Integrated
Kubuntu 7.4 32-bit Intel
Yes
I recently worked with Joe on a number of issues with this installation.
If you'd like to see the history to date, please refer to the thread
on this group entitled "Major issues with Eclipse 3.3 and TPTP 4.4."
Thanks for the assist.
-=< tom >=-
Re: TPTP 4.4 profiling timeout on launch [message #103073 is a reply to message #103025] Thu, 05 July 2007 03:37 Go to previous messageGo to next message
Tom,
Do all profiling types (CPU, Heap, Thread) fail on your application, or
just specific ones? Can you please test this? It can help us determine
whether this is a general Agent Controller issue or a timeout specific
to the overhead generated by some of our data collectors.
Have you tried using the standalone Agent Controller?
Asaf Yaffe
Re: TPTP 4.4 profiling timeout on launch [message #103127 is a reply to message #103073] Thu, 05 July 2007 07:26 Go to previous messageGo to next message
> Tom,
I've only tried to profile; I can test the others.
No, I've only used the IAC.
-=< tom >=-
Re: TPTP 4.4 profiling timeout on launch [message #103142 is a reply to message #103073] Thu, 05 July 2007 07:48 Go to previous messageGo to next message
> Tom,
Memory Analysis and Thread Analysis both failed as well.
Re: TPTP 4.4 profiling timeout on launch [message #104149 is a reply to message #103073] Tue, 10 July 2007 14:10 Go to previous messageGo to next message
Hi, Asaf,
I've answered all of the questions you've asked in this thread, including
this one (I've used only the IAC).
However, since it seems that this thread has died, perhaps I need to
clarify the above question.
Was this question actually a request for me to install and attempt the same
steps using the SAC, or was it the simple yes/no question I assumed it to
be?
Thanks.
-=< tom >=-
Re: TPTP 4.4 profiling timeout on launch [message #104233 is a reply to message #104149] Wed, 11 July 2007 06:03 Go to previous messageGo to next message
Tom Funk wrote:
> Hi, Asaf,
> be?
> Thanks.
> -=< tom >=-
Well... it was a polite way of asking you to try the standalone AC and
see if you get better results. This can greatly help us in determining
the root-cause of your problem.
Asaf
Asaf Yaffe
Re: TPTP 4.4 profiling timeout on launch [message #107181 is a reply to message #102906] Thu, 02 August 2007 05:46 Go to previous messageGo to next message
> Any thoughts?
I have the exact same problem using Windows 2000, Eclipse 3.3, TPTP4.4,
JDK 1.5.0_12.
I hadn't seen your message, so I posted a new one for this problem...
I'm going to try to install a stand-alone agent controller...
Mauro.
Re: TPTP 4.4 profiling timeout on launch [message #107194 is a reply to message #107181] Thu, 02 August 2007 05:57 Go to previous message
By the way, using the default configuration (with IAC), I can't even
profile an Hello World application... :-(
Mauro.
Previous Topic:Agent Controller hell
Next Topic:download site down?
Current Time: Wed Jul 23 10:42:24 EDT 2025
Powered by FUDForum. Page generated in 0.30074 seconds
