Home » Eclipse Projects » GEF » KeyHandler and CTRL-Z
KeyHandler and CTRL-Z [message #102982] Fri, 31 October 2003 05:48 Go to next message
Originally posted by: arnaud.siminski.infotel.com
Hi all !
In a GEF editor I would like to run the UNDO action when the user press on
CTRL-Z. To do so I implement something like that :
keyhandler.put(KeyStroke.getPressed(SWT.CONTROL | 'z', 0),
getActionRegistry().getAction(GEFActionConstants.UNDO));
It seems to me that the system catchs only the CONTROL key when I press
CTRL Z. I also tried several others ways like telling that the keycode was
SWT.CONTROL|'z' and the statemask was SWT.CONTROL and so... but none has
worked.
I have to add that the action UNDO do run when I link it to the SHIFT-Z or
any other key... so i think the problem should come only from the
keyhandler setup.
Could someone explain to me please how do to that?
Arnaud Siminski
Re: KeyHandler and CTRL-Z [message #103009 is a reply to message #102982] Fri, 31 October 2003 09:58 Go to previous message
That's right. CTRL+Z is an accelerator defined in the Shell. This means
you must use a global action handler to hook into the workbench's handling
of CTRL+Z. See how the logic example does this.
"Arnaud Siminski" <arnaud.siminski@infotel.com> wrote in message
news:bnteld$nbd$1@eclipse.org...
> Hi all !
> worked.
> keyhandler setup.
> Arnaud Siminski
Previous Topic:GEF takes on Visio?
Next Topic:"not a dibseciton"
Current Time: Wed Nov 05 02:30:22 EST 2025
Powered by FUDForum. Page generated in 0.04042 seconds
