Home » Archived » M2M (model-to-model transformation) » [ATL] Help with helpers needed -work-around for unsupported registration
[ATL] Help with helpers needed -work-around for unsupported registration [message #102925] Mon, 06 April 2009 10:39 Go to next message
I am trying to make a transformation that recursively splits a list using
helpers.
I tried to make a helper with a collection as context. I got an
"Unsupported registration..." warning. I read that it is impossible to use
( http://www.sciences.univ-nantes.fr/lina/atl/www/atl_discussi on_archive/0324.html)
Therefore I rewrote my helper in such a way that it takes a collection as
a parameter. Now it looks like this:
helper def: getStatementsThroughFirstSend(s: Sequence(slco!Statement)):
Sequence(slco!Statement) =
let i: Integer = s.getIndexOfFirstSend()
in s->asSequence()->subSequence(0, i);
The problem is now that I want to call this helper from another helper as
follows:
helper context slco!Transition def: splitStatementList():
Sequence(Sequence(slco!Statement)) =
if self.hasEffectSendStatements()
then getStatementsThroughFirstSend(self.effect->asSequence())
else Sequence{}
endif;
This results in a syntax error at the point where I try to invoke the
function in the then clause.
In the slco metamodel, on the transition metaclass "effect" is an ordered
reference.
Re: [ATL] Help with helpers needed -work-around for unsupported registration [message #102947 is a reply to message #102925] Mon, 06 April 2009 16:49 Go to previous messageGo to next message
Originally posted by: lwrage.sei.cmu.edu
Marcel,
When you use a helper that has no context you must prefix it with
"thisModule." In your example, write
thisModule.getStatementsThroughFirstSend(self.effect... in helper
splitStatementList.
Lutz
Marcel van Amstel wrote, on 4/6/2009 10:39 AM:
> Hello,
> using helpers.
> use a collection as context.
> as a parameter. Now it looks like this:
> as follows:
> else Sequence{}
> endif;
> ordered reference.
Re: [ATL] Help with helpers needed -work-around for unsupported registration [message #102992 is a reply to message #102947] Tue, 07 April 2009 07:38 Go to previous message
Thank you, that worked just fine.
Previous Topic:M2M Workflow
Next Topic:[ATL] Where is the "Apply" profile or stereotype example
Current Time: Fri Jul 18 23:49:39 EDT 2025
Powered by FUDForum. Page generated in 0.04511 seconds
