Creating XExpressions Manually [message #1027895] |
Wed, 27 March 2013 11:04  |
It seems like it should be possible to create a method body by defining an XExpression, but while this will compile and run without error, it does not generate a method body:
body = XbaseFactory::eINSTANCE.createXBlockExpression => [
expressions += XbaseFactory::eINSTANCE.createXReturnExpression => [
expression = XbaseFactory::eINSTANCE.createXStringLiteral => [
value = 'String'
While it is useful to generate method bodies using the string-based template approach, it would sometimes be better to avoid the parsing required by that approach and directly generate the necessary AST elements.
What is missing from this example that is necessary to generate code?
Re: Creating XExpressions Manually [message #1028724 is a reply to message #1027895] |
Thu, 28 March 2013 12:50  |
I've also tried something similer, but couldn't make it work. I would
very much like to be able to create a complex method body containing
sub-expressions from several places in the original DSL text. But I
think too much is happening in the linking process to make it easy to do
by manually creating Xbase objects. It would be great to have an
XbaseExpressionBuilder with toXExpression methods (toIf, toReturn,
toBlock, ...) that make this possible.
Hallvard
There's to much happening during linking
> value = 'String'
FUDForum. Page generated in 0.04188 seconds
