Home » Eclipse Projects » DSDP - Target Management » RCP status
| RCP status [message #10285] |
Mon, 28 May 2007 13:53  |
Hello all.
Can somebody give quick review on how many components are RCP-ready in TM ?
In other words when I want to write application that will manage some
devices (custom activities with some job) and want to use all that RSE cool
stuff: view, registry...and so on - can I do this as RCP application ?
| Re: RCP status [message #10418 is a reply to message #10383] |
Thu, 31 May 2007 13:42   |
Originally posted by: udaykabe.hotmail.com
Hello Martin, Dimitry,
Sorry, I have not responded sooner, but I have not visited this group for a
while.
I am using the following RSE plugins in my RCP application:
org.eclipse.rse.connectorservice.local v20070328
org.eclipse.rse.connectorservice.ssh v20070328
org.eclipse.rse.core v20070401
org.eclipse.rse.files.ui v20070401
org.eclipse.rse.services v20070221
org.eclipse.rse.services.files.ftp v20070402
org.eclipse.rse.services.local v20070402
org.eclipse.rse.services.ssh v20070224
org.eclipse.rse.subsystems.files.core v20070401
org.eclipse.rse.subsystems.files.ftp v20070401
org.eclipse.rse.subsystems.files.local v20070401
org.eclipse.rse.subsystems.files.ssh v20070401
org.eclipse.rse.subsystems.shells.core v20070328
org.eclipse.rse.ui v20070401
By using RSE, my RCP application is probably not a "pure" RCP application
any more because many of the above plugins depend (directly or indirectly)
upon org.eclipse.ui.ide which adds its own menus, perspectives, preferences,
etc., thereby "polluting" my RCP application. Because of this, I have had
to re-structure my Application and Advisor classes to handle menus and
preferences the same way that the IDE does.
Of the above plugins, only the following are independent of the IDE:
org.eclipse.rse.services.*
I use RSE to provide FTP/SFTP filesystems as drop targets/destinations for
export of Lotus Notes data. I have made minimal modifications (5 lines of
code to SystemViewDataDropAdapter.java) to the RSE plugins, so I don't
really have any sample code to provide. Here is what I have added to handle
drop data of type IStructuredSelection:
private ArrayList getSourceObjects(Object data) {
/***added code show below***/
+ else if (data instanceof IStructuredSelection) {
+ // return a list of filepaths
+ RseDragAndDropExportOperation op = new RseDragAndDropExportOperation();
+ srcObjects.addAll(op.getExportFileList((IStructuredSelection )data));
+ _sourceType = SystemDNDTransferRunnable.SRC_TYPE_OS_RESOURCE;
I should mention that I have to fix an RSE problem which occurs when I start
my RCP app, add an FTP connection in the SystemView, save the user ID and
password, and exit and restart my app. The following happens:
1. I see two sets of "My Home" and "Root" nodes under the "Files" subnode
2. Occasionally, I have to re-enter and re-save the password. It's as if
the password has been forgotten after some time.
3. The FTP node's auto-expand behavior is not alway exhibited.
I hope I have been of some help.
Uday
"Dmitry Tomko" <dtomko@iba.by> wrote in message
news:f3hmol$1f9$1@build.eclipse.org...
> Hello Martin.
> Thanks for your feedback. That would be great if I can use all this cool
> stuff in RCP apps. At least I want to ask Uday to provide any sample code
> if that's possible. Terminal component is not what I need, but rather all
> this file operations stuff(copy/paste) and remote command execution.
> "Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
> news:465C58DD.8010406@windriver.com...
>> Hello Dimtry,
>> Uday Kabe posted on this newsgroup earlier
>> that he was developing an RCP with RSE.
>> (subject: Operation failed. File system input
>> or output error).
>> I know for sure that the Terminal is RCP ready,
>> and it looks like Uday also got it working for
>> RSE. Though rse.ui will need eclipse.core.resources,
>> not sure if that would be a problem for you.
>> Uday can you give any hints?
>> Thanks,
>> Martin Oberhuber
>> Target Management Project Lead, DSDP PMC Member
>> http://www.eclipse.org/dsdp/tm
>> Dmitry Tomko wrote:
>>> Hello all.
>>> TM ?
>>> cool stuff: view, registry...and so on - can I do this as RCP
>>> application ?
| Re: RCP status [message #10450 is a reply to message #10418] |
Wed, 06 June 2007 07:08   |
Thanks Uday.
If you can, please test your app with TM 2.0RC2 -- the
filter issue should be gone thanks to new persistence
providers and avoiding duplicate queries.
Would you consider the code you have added to the drag&drop
generic enough so it should go into the original distro?
for a
> while.
application
indirectly)
preferences,
have had
lines of
handle
I start
and
as if
> Uday
Martin Oberhuber
Wind River Systems, Inc.
| Re: RCP status [message #10547 is a reply to message #10450] |
Thu, 07 June 2007 09:24   |
Martin,
I cannot see the 2.0RC2 tag in CVS. If you can add this tag, I will check
out RC2 from CVS and test it out. I did install S2_0M6a into my Eclipse
installation (i.e., not in my RCP product), and I did not see the problem 1
I mentioned in my last post, however problem 3 seems to still exist. I am
keeping a eye on problem 2. The ultimate test for me will be when I get the
RSE code into my product but I still need to complete my migration to 3.3
before I can do that.
As far as generalizing the DND code, the issue is that I have modified
SystemView to use LocalTransfer as one of its transfer types. This is an
EMF (Eclipse Modeling Framework) specific class which handles DND with
IStructuredSelection data. RSE would end up with a dependency on the EMF
plugins, probably not what you want at this point.
Eclipse's "official" general mechanism is the use of PluginTransferData,
but I had trouble getting RSE's implementation to work in combination with
my code. That's why I had to add the LocalTransfer to the SystemView's
transfer types. The problem was that PluginTransferData's callback was not
being activated as expected. I had already spent a day or two on this
problem, after which I decided I didn't have time to troubleshoot the issue
further so I took the route of using LocalTransfer which works just fine for
me. My suggestion would be to get the PluginTransferData mechanism to work.
Per Eclipse docs, the use of PluginTransferData should generalize DND for
use with other views whose implementors would provide the necessary
callback.
Uday
news:466695C9.8050207@windriver.com...
> Thanks Uday.
> for a
> > while.
> application
> indirectly)
> preferences,
> have had
> lines of
> handle
> I start
> and
> > subnode
> as if
> > Uday
> Martin Oberhuber
| Re: RCP status [message #10646 is a reply to message #10547] |
Tue, 12 June 2007 06:42   |
Hello Uday,
Thanks for the info. I agree that PluginTransfer should be the preferred
method -- for the next release we're going to file bugs also against
Platform / Common Navigator, Project Explorer to support PluginTransfer.
For the 2.0RC2 tag - we're not tagging the entire repository for
milestones, we're only tagging the Mapfiles (in the
org.eclipse.rse.build project). So I'd recommend you just get HEAD,
it's not going to change much until we release 2.0 (which will have
a tag on the entire repository again).
If you want 2.0RC2 exactly, you need to
* Sync the Mapfile project to 2.0RC2
* Get the Releng.Tools plugin from the Eclipse platform Download Page
* Create a project 'org.eclipse.releng' with a linked resource folder
'maps' pointing to org.eclipse.rse.build/maps
* Select all projects, Team -> Replace with released
Or, you just get the RSE-SDK-2.0RC2 download and import the plugins
and features from the target platform (then you work on the sources
that we ship as part of our SDK).
Cheers
Martin
Uday Kabe schrieb:
> Martin,
> callback.
> Uday
Martin Oberhuber
| Re: RCP status [message #10678 is a reply to message #10646] |
Tue, 12 June 2007 09:27   |
Hi Martin,
As you know, I am using RSE in a Lotus Notes product I am developing. A
little while ago, I downloaded Lotus Notes 8 beta 3 which is an RCP based
application that uses Eclipse 3.2 as its foundation. It's possible that IBM
may move to 3.3 by the time LN8 is released, but who knows.
Because of LN8, I may have to stick with releasing on Eclipse 3.2.
Therefore I now have a concern regarding RSE because the latest RSE needs
Eclipse 3.3. Are you considering any maintenance branches for RSE on 3.2?
What options do you think I might have if I need to stay with Eclipse 3.2 as
my platform?
Thanx.
Uday
news:466E78AB.7080805@windriver.com...
> Hello Uday,
> milestones, we're only tagging the Mapfiles (in the org.eclipse.rse.build
> Cheers
> Martin
> Uday Kabe schrieb:
>> Martin,
>> check out RC2 from CVS and test it out. I did install S2_0M6a into my
>> Eclipse installation (i.e., not in my RCP product), and I did not see the
>> problem 1 I mentioned in my last post, however problem 3 seems to still
>> exist. I am keeping a eye on problem 2. The ultimate test for me will
>> be when I get the RSE code into my product but I still need to complete
>> my migration to 3.3 before I can do that.
>> with my code. That's why I had to add the LocalTransfer to the
>> SystemView's transfer types. The problem was that PluginTransferData's
>> callback was not being activated as expected. I had already spent a day
>> or two on this problem, after which I decided I didn't have time to
>> troubleshoot the issue further so I took the route of using LocalTransfer
>> which works just fine for me. My suggestion would be to get the
>> PluginTransferData mechanism to work. Per Eclipse docs, the use of
>> PluginTransferData should generalize DND for use with other views whose
>> implementors would provide the necessary callback.
>> Uday
> Martin Oberhuber
| Re: RCP status [message #10711 is a reply to message #10678] |
Wed, 13 June 2007 09:28   |
Uday --
Currently there are no plans to take RSE 2.0 and move it back to
Eclipse 3.2. There are several things that won't "go back" very well.
The SSH support, for example, depends on the latest JSCH jar and there
are several other issues. Unfortunately, the job is not trivial.
-- Dave Dykstal
On 2007-06-12 08:27:14 -0500, "Uday Kabe" <udaykabe@hotmail.com> said:
> Hi Martin,
> A little while ago, I downloaded Lotus Notes 8 beta 3 which is an RCP
> based application that uses Eclipse 3.2 as its foundation. It's
> possible that IBM may move to 3.3 by the time LN8 is released, but who
> knows.
> needs Eclipse 3.3. Are you considering any maintenance branches for
> RSE on 3.2? What options do you think I might have if I need to stay
> with Eclipse 3.2 as my platform?
> Thanx.
> Uday
>> Hello Uday,
>> Cheers
>> Martin
>> Uday Kabe schrieb:
>>> Martin,
>>> the problem 1 I mentioned in my last post, however problem 3 seems to
>>> still exist. I am keeping a eye on problem 2. The ultimate test for
>>> me will be when I get the RSE code into my product but I still need to
>>> complete my migration to 3.3 before I can do that.
>>> an EMF (Eclipse Modeling Framework) specific class which handles DND
>>> with IStructuredSelection data. RSE would end up with a dependency on
>>> the EMF plugins, probably not what you want at this point.
>>> PluginTransferData, but I had trouble getting RSE's implementation to
>>> work in combination with my code. That's why I had to add the
>>> LocalTransfer to the SystemView's transfer types. The problem was that
>>> PluginTransferData's callback was not being activated as expected. I
>>> had already spent a day or two on this problem, after which I decided I
>>> didn't have time to troubleshoot the issue further so I took the route
>>> of using LocalTransfer which works just fine for me. My suggestion
>>> would be to get the PluginTransferData mechanism to work. Per Eclipse
>>> docs, the use of PluginTransferData should generalize DND for use with
>>> other views whose implementors would provide the necessary callback.
>>> Uday
>> Martin Oberhuber
| Re: RCP status [message #11989 is a reply to message #10678] |
Tue, 26 June 2007 15:20  |
Hello Uday,
Option A is to just stick with RSE 1.0. We do not plan any backporting
of features.
As Dave has mentioned, the SSH configuration needs Eclipse 3.3, but
apart from that I'm not aware of any forced dependencies.
What kinds of connection types do you need? Chances are for those things
that you need, TM 2.0 "just works" on Eclipse 3.2 although it is not
officially supported. I think it would be worth a try grabbing the
latest source from CVS HEAD and checking if it builds against 3.2 and if
not, where the issues are.
Martin Oberhuber
Uday Kabe wrote:
> Hi Martin,
> my platform?
> Thanx.
> Uday
>> Hello Uday,
>> Cheers
>> Martin
>> Uday Kabe schrieb:
>>> Martin,
>>> Uday
>> Martin Oberhuber
| Re: RCP status [message #567871 is a reply to message #10285] |
Tue, 29 May 2007 12:46  |
Hello Dimtry,
or output error).
Martin Oberhuber
Dmitry Tomko wrote:
> Hello all.
| Re: RCP status [message #567919 is a reply to message #10318] |
Tue, 29 May 2007 13:06  |
Hello Martin.
stuff in RCP apps. At least I want to ask Uday to provide any sample code if
that's possible. Terminal component is not what I need, but rather all this
> Hello Dimtry,
> or output error).
> Martin Oberhuber
> Dmitry Tomko wrote:
>> Hello all.
>> cool stuff: view, registry...and so on - can I do this as RCP application
| Re: RCP status [message #567950 is a reply to message #10383] |
while.
Uday
> Hello Martin.
>> Hello Dimtry,
>> or output error).
>> Thanks,
>> Martin Oberhuber
>> Dmitry Tomko wrote:
>>> Hello all.
>>> TM ?
>>> application ?
| Re: RCP status [message #567974 is a reply to message #10418] |
Thanks Uday.
for a
> while.
application
indirectly)
preferences,
have had
lines of
handle
I start
and
as if
> Uday
Martin Oberhuber
| Re: RCP status [message #568095 is a reply to message #10450] |
Martin,
callback.
Uday
> Thanks Uday.
> for a
> > while.
> application
> indirectly)
> preferences,
> have had
> lines of
> handle
> I start
> and
> > subnode
> as if
> > Uday
> Martin Oberhuber
| Re: RCP status [message #568192 is a reply to message #10547] |
Hello Uday,
Cheers
Martin
Uday Kabe schrieb:
> Martin,
> callback.
> Uday
Martin Oberhuber
| Re: RCP status [message #568229 is a reply to message #10646] |
Hi Martin,
my platform?
Thanx.
Uday
> Hello Uday,
> Cheers
> Martin
> Uday Kabe schrieb:
>> Martin,
>> Uday
> Martin Oberhuber
| Re: RCP status [message #568245 is a reply to message #10678] |
Uday --
-- Dave Dykstal
> Hi Martin,
> knows.
> Thanx.
> Uday
>> Hello Uday,
>> Cheers
>> Martin
>> Uday Kabe schrieb:
>>> Martin,
>>> Uday
>> Martin Oberhuber
| Re: RCP status [message #568519 is a reply to message #10678] |
Hello Uday,
of features.
Martin Oberhuber
Uday Kabe wrote:
> Hi Martin,
> my platform?
> Thanx.
> Uday
>> Hello Uday,
>> Cheers
>> Martin
>> Uday Kabe schrieb:
>>> Martin,
>>> Uday
>> Martin Oberhuber
Current Time: Thu Nov 06 09:47:32 EST 2025
Powered by FUDForum. Page generated in 0.28972 seconds
