[EGL] Interfaces and Generalizations [message #1028034] |
Wed, 27 March 2013 14:53  |
I'm accessing an element (Class) to obtain information. Its generalization works perfectly:
var hierarchy = self.generalization;
Then I try something similar with interfaces, I've checked the EMF EPackage Registry View and, if I'm not wrong, it should be something like this:
var interfaces= self.interfaceRealization;
But it doesn't work.
I get this error (ChildClass doesn't use interfaces):
Quote:Property 'InterfaceRealization' not found in object org.eclipse.uml2.uml.internal.impl.ClassImpl [name: ChildClass, visibility: <unset>] [isLeaf: false, isAbstract: false, isFinalSpecialization: false] [isActive: false]
Cause: Property 'InterfaceRealization' not found in object org.eclipse.uml2.uml.internal.impl.ClassImpl [name: ChildClass, visibility: <unset>] [isLeaf: false, isAbstract: false, isFinalSpecialization: false] [isActive: false]
Could anyone help me?
Thanks in advance.
Cheers.
FUDForum. Page generated in 0.04180 seconds
