Home » Modeling » ATL » Can my idea work?
Can my idea work? [message #1028264] Wed, 27 March 2013 23:03 Go to next message
In my ATL project.I want to use UML metemodel as my input metamodel and I also want to use model file(.uml file) generated by Papyrus as my input model file .
Can my idea work ?
Thank you very much !
Look forward to your reply!
Re: Can my idea work? [message #1028373 is a reply to message #1028264] Thu, 28 March 2013 03:11 Go to previous messageGo to next message
Yes, because Papyrus models conforms UML metamodel
Re: Can my idea work? [message #1028380 is a reply to message #1028373] Thu, 28 March 2013 03:24 Go to previous messageGo to next message
I encouter some questions.I will give you some code about model file generated by Papyrus.
<uml:Model xmi:version="20110701" xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML" xmi:id="_vNMBYJPNEeKDxonErf88qQ" name="model">
  <packagedElement xmi:type="uml:Activity" xmi:id="_vNNPgJPNEeKDxonErf88qQ" name="Activity1" node="_4gWO0JPNEeKDxonErf88qQ _71K1kJPNEeKDxonErf88qQ _-8DuAJPNEeKDxonErf88qQ _LnPAIJPOEeKDxonErf88qQ">
    <edge xmi:type="uml:ControlFlow" xmi:id="_ANKJgJPOEeKDxonErf88qQ" name="ControlFlow1" source="_4gWO0JPNEeKDxonErf88qQ" target="_71K1kJPNEeKDxonErf88qQ">
      <guard xmi:type="uml:LiteralBoolean" xmi:id="_ANLXoJPOEeKDxonErf88qQ" value="true"/>
      <weight xmi:type="uml:LiteralInteger" xmi:id="_ANLXoZPOEeKDxonErf88qQ"/>
    </edge>
    <edge xmi:type="uml:ControlFlow" xmi:id="_BQmjgJPOEeKDxonErf88qQ" name="ControlFlow2" source="_LnPAIJPOEeKDxonErf88qQ" target="_-8DuAJPNEeKDxonErf88qQ">
      <guard xmi:type="uml:LiteralBoolean" xmi:id="_BQnxoJPOEeKDxonErf88qQ" value="true"/>
      <weight xmi:type="uml:LiteralInteger" xmi:id="_BQnxoZPOEeKDxonErf88qQ"/>
    </edge>
    <edge xmi:type="uml:ControlFlow" xmi:id="_PaTpIJPOEeKDxonErf88qQ" name="ControlFlow3" source="_71K1kJPNEeKDxonErf88qQ" target="_LnPAIJPOEeKDxonErf88qQ">
      <guard xmi:type="uml:LiteralBoolean" xmi:id="_PaUQMJPOEeKDxonErf88qQ" value="true"/>
      <weight xmi:type="uml:LiteralInteger" xmi:id="_PaU3QJPOEeKDxonErf88qQ"/>
    </edge>
    <node xmi:type="uml:InitialNode" xmi:id="_4gWO0JPNEeKDxonErf88qQ" name="InitialNode1" outgoing="_ANKJgJPOEeKDxonErf88qQ"/>
    <node xmi:type="uml:OpaqueAction" xmi:id="_71K1kJPNEeKDxonErf88qQ" name="eat" outgoing="_PaTpIJPOEeKDxonErf88qQ" incoming="_ANKJgJPOEeKDxonErf88qQ"/>
    <node xmi:type="uml:ActivityFinalNode" xmi:id="_-8DuAJPNEeKDxonErf88qQ" name="ActivityFinalNode1" incoming="_BQmjgJPOEeKDxonErf88qQ"/>
    <node xmi:type="uml:OpaqueAction" xmi:id="_LnPAIJPOEeKDxonErf88qQ" name="sleep" outgoing="_BQmjgJPOEeKDxonErf88qQ" incoming="_PaTpIJPOEeKDxonErf88qQ"/>
  </packagedElement>
</uml:Model>
I know that node,edge,weight and guard are references,but I can not find their attributes such as type,id,name in UML Metamodel.
In ATL rules , I need to transform them to Corresponding attributes.
Look forward to your reply !
Re: Can my idea work? [message #1028385 is a reply to message #1028380] Thu, 28 March 2013 03:35 Go to previous messageGo to next message
what do you mean with "I cannot find their attributes"??
They appear in the xmi you sent, and if you write an ATL rule for sure that you can access them, like
node:UML!OpaqueAction
node.name
Another idea: you can match for its parent type (I guess "Node") .. and then use things like oclIsTypeOf
Do you really need the id? because I think it is an internal representation of the xmi, so, if you work with the UML you dont care...
hope it helps!
Re: Can my idea work? [message #1028407 is a reply to message #1028385] Thu, 28 March 2013 04:05 Go to previous messageGo to next message
If I want to tranform UMLActivity to PetriNet and I hava define my PetriNet metamodel.I want to use UML metemodel .
rule InitialNode
from
s:
Activities!Node(s.type='uml:InitialNode')
to
t1:
PetriNets!Place
name <- s.name,
id <- s.id,
type <- s.type+'+Place'
Are there some errors in my rule.
Re: Can my idea work? [message #1028410 is a reply to message #1028407] Thu, 28 March 2013 04:07 Go to previous messageGo to next message
yes, because "type" is not a string
Re: Can my idea work? [message #1028415 is a reply to message #1028410] Thu, 28 March 2013 04:16 Go to previous messageGo to next message
Thank you very much!
I need the type of node .Can you tell me how to modify it?
I want to make friends with you .Can you give me your email or other quick way for communication?
Re: Can my idea work? [message #1028433 is a reply to message #1028410] Thu, 28 March 2013 04:46 Go to previous messageGo to next message
Dear Federico Toledo,
Thank You Very Much !
Re: Can my idea work? [message #1028440 is a reply to message #1028433] Thu, 28 March 2013 04:58 Go to previous messageGo to next message
what about something like
rule rule1 {
from
s: UML:InitialNode
to
t1: MMOUT:NewTypeYouNeed (
name <- s.name,
by this way the target objet type is "MMOUT:NewTypeYouNeed"
I think it is better to continue sharing ideas an questions in the forum, more people with different levels of expertise, more availability, better validation of ideas, etc...
Re: Can my idea work? [message #1028466 is a reply to message #1028440] Thu, 28 March 2013 05:40 Go to previous messageGo to next message
I am confused that InitialNode is a class element in UML mtamodel ,but it becomes
an attribute value of type attribute in model file (.um file)generated by Papyrus .
Outgoing and incoming are references like node and edge ,but they appear in node element ?
Re: Can my idea work? [message #1028472 is a reply to message #1028466] Thu, 28 March 2013 05:46 Go to previous messageGo to next message
Sorry .. I can't help, I never see the xmi... and I think you shouldnt if you want to follow Model-driven approaches ... unless you are building a tool where you have to write the uml file ... but even in this case, you have APIs to avoid the task of understand the xmi represnentation ...
Re: Can my idea work? [message #1028543 is a reply to message #1028472] Thu, 28 March 2013 07:48 Go to previous messageGo to next message
Do you know how to find the metamodel of MARTE?
Re: Can my idea work? [message #1028560 is a reply to message #1028543] Thu, 28 March 2013 08:21 Go to previous messageGo to next message
you're welcome
about MARTE, sorry, no idea
Re: Can my idea work? [message #1028619 is a reply to message #1028560] Thu, 28 March 2013 10:05 Go to previous messageGo to next message
I am sorry to disturb you again .
  rule PackageableElement
	from
	    s: UML!PackageableElement
	to
	    t1: PetriNets!PetriNet
			name <- s.name
rule InitialNode
	from
	    s:
	      UML!InitialNode
	to
	    t1:
	    	PetriNets!Place
			 name <- s.name
But my output file :
  <PetriNet name="model"/>
  <PetriNet name="Activity1"/>
  <PetriNet/>
  <PetriNet/>
  <PetriNet/>
  <PetriNet/>
  <PetriNet/>
  <PetriNet/>
  <Place name="InitialNode1"/>
I want to get the file is:
Look forward to your reply .
Re: Can my idea work? [message #1028641 is a reply to message #1028619] Thu, 28 March 2013 10:42 Go to previous message
Eclipse newsgroups provide help to users with difficulties.
They are not intended for users who decline to learn basic debugging
facilities.
Ed Willink
> from s: UML!PackageableElement
> to
> name <- s.name
> rule InitialNode
> from
> s:
> UML!InitialNode
> to
> t1:
> PetriNets!Place
> name <- s.name
> <PetriNet/>
> <PetriNet/>
> <PetriNet/>
> <PetriNet/>
> <PetriNet/>
> <PetriNet/>
Previous Topic:how to implement the for instruction
Next Topic:How can I get the MARTE Metamodel
Current Time: Sun Jul 27 22:22:25 EDT 2025
Powered by FUDForum. Page generated in 0.06416 seconds
