Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Questions regarding the generated Testdata and other stuff
[Texo] Questions regarding the generated Testdata and other stuff [message #1028002] Wed, 27 March 2013 13:55 Go to next message
I. Prefix:
These are some questions that I originally asked Martin Taal via email and he suggested to post them here for all to see. I have a couple of ecores that have EClasses with self-referencing bi-directional references in them. I ran into a couple of issues which got resolved with the help of Marting Taal. To demonstrate my issues I manipulated the default example project, and the following questions will reference this project.
Basically my setup is this (one reference is a containment, the other is its opposite a container)
EClass Resource
--EReference: isPartOfResource: Resource
--EReference: oppositeIsPartOfResource: Resource
--EAttribute: name: String
I took the default Library example project and expanded the EClass Book so that it has a reference to the EClass Resource (you can get the example project here). I deployed it on Tomcat and generated Tetsdata.
II. The actual questions/ notes
Maybe those are "bugs" or maybe all of this is expected:
1. Is it expected that only one Book has a Reference to the Resource in the testdata? I assume this will be not a problem in reality and is only "an issue" (if you may call it that) of the datagenerator.
2. Is it expected that despite Resources are being created in the datageneration step I cannot see an Entry for "Resource" in the "Types list for EPackage library" html site? See here and here of what I mean by this.
3. I really don't understand the html-view for Instances of EClasses (see here). At the bottom it says isPartofResource and on the right side of this isPartofResource ([name id of one Resource]) and below that a link to another Resource.
At first I thought that maybe this would portrait the isPartOfResource and the opposite Reference, but that's not the case.
Compare the html view of the Resource with id 18 and the corresponding json data (see here for the json)
The References are like this:
Resource 18
--isPartofResource 17
----17 isPartofResource 10
------10 isPartofResource 9
In the htmlview of Resource 18 (see again here) it says "isPartofResource ( nullum ea - 10 )" and below a link to Resource 9. Resource 9 is a pretty random object because 9 itself is part of another Resource.
3.1 Why does the wscall respond with the whole information of 17 and 10 and only with the proxy for 9?
3.2 Why does it display the isPartofResource like it does in the html-view? That's what confuses me the most.
3.3 Why get all OppositeIsPartOfResource-referenced Resources shown as proxies and the isPartofResource-referenced Resources not?
3.4 Why is the OppositeIsPartOfResource not shown in the html-view?
So are those bugs, am I doing something wrong, or am I understanding sth wrong?
Micha
Re: [Texo] Questions regarding the generated Testdata and other stuff [message #1028062 is a reply to message #1028002] Wed, 27 March 2013 15:47 Go to previous messageGo to next message
Hi Micha-Jamie,
See the replies inline.
gr. Martin
On 03/27/2013 06:55 PM, Micha-Jamie Guthmann wrote:
> I. Prefix: These are some questions that I originally asked Martin Taal via email and he suggested to post them here for
> EClass Resource
> Resource (you can get the example project http://dl.dropbox.com/u/6568643/texopics/manipulatedtexowebexample.zip). I
> II. The actual questions/ notes Maybe those are "bugs" or maybe all of this is expected:
MT>> The test data generation works with any ecore model so it is sometimes smart and sometimes less smart...
> http://dl.dropbox.com/u/6568643/texopics/1_generated_objects.png and
> http://dl.dropbox.com/u/6568643/texopics/2_Types_list.png of what I mean by this.
MT>> The resource in your example is part of another epackage, you have to add the resource to the epackage
registration, see the TexoWebExampleContextListener class in the demo project, there you can find the Library package
registration. Add one for the resource model also.
> http://dl.dropbox.com/u/6568643/texopics/3_htmlview_of_resource.png). At the bottom it says isPartofResource and on the
> case. Compare the html view of the Resource with id 18 and the corresponding json data (see
> http://dl.dropbox.com/u/6568643/texopics/4_json_of_resource.png for the json)
> Resource 18
> In the htmlview of Resource 18 (see again http://dl.dropbox.com/u/6568643/texopics/3_htmlview_of_resource.png) it says
MT>> Hmm yes it seems that the xslt templates can not handle this model completely. These xslt templates are really ment
only for simple demo purposes...
MT>> You can select for how many levels the childs are read, the default is 2, try with the parameter childLevels set to
10 or so.
MT> seems to be a bug in the xslt template.
> Resources not?
MT>> The non-containment references are all send back as proxies while the containment/children upto a certain level are
included in the json/xml
MT>> Not sure myself, this seems to be a real bug, I don't see it in the xml either, can you enter a bugzilla for this one?
Can you also enter bugzillas for the xslt/template issues? You can also enter a single bugzilla for both the templates
and the opposite xml reference. I have the example project, so no need to attach the example project.
> Best regards,
> Micha
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Questions regarding the generated Testdata and other stuff [message #1031166 is a reply to message #1028062] Mon, 01 April 2013 05:31 Go to previous messageGo to next message
Hi Micha,
I published a new build which solves the template issue. The reason that the opposite resource ereference is not
serialized in xml is that it seems that container references are not serialized as the container-containment association
is reflected in the xml structure.
Maybe Ed or others know how to explicitly serialize the parent/container ereference. Please ask on the EMF newsgroup if
relevant for you.
gr. Martin
On 03/27/2013 08:47 PM, Martin Taal wrote:
> Hi Micha-Jamie,
> gr. Martin
>> EClass Resource
>> Resource 18
> 10 or so.
>> Resources not?
>> Best regards,
>> Micha
The Netherlands
Re: [Texo] Questions regarding the generated Testdata and other stuff [message #1031183 is a reply to message #1031166] Mon, 01 April 2013 06:13 Go to previous messageGo to next message
Martin,
A container reference is only serialized for a root object and then only
if it is cross resource contained by another object and the container
reference itself isn't marked transient.
On 01/04/2013 11:31 AM, Martin Taal wrote:
> Hi Micha,
> that the opposite resource ereference is not serialized in xml is that
> container-containment association is reflected in the xml structure.
> relevant for you.
> gr. Martin
>> Hi Micha-Jamie,
>> gr. Martin
>>> this project.
>>> EClass Resource
>>> I
>>> mean by this.
>>> (see
>>> the json)
>>> Resource 18
>>> it says
>> 10 or so.
>>> Resources not?
>>> sth wrong?
>>> Best regards,
>>> Micha
Re: [Texo] Questions regarding the generated Testdata and other stuff [message #1031985 is a reply to message #1028002] Tue, 02 April 2013 08:42 Go to previous messageGo to next message
Thanks again.
I've noticed one further minor thing. If I generate test data with both packages registered, I don't see all instances of EClass Resource in the html view.
See this:
1. generate test data with the library package creates 13 Resources
https://dl.dropbox.com/u/6568643/texopics/generated_test_data_library.png
2. only 1 instance is shown for EClass Resource
https://dl.dropbox.com/u/6568643/texopics/instances_resource1.png
3. generate test data with the resourcemodel creates 3 Resources
https://dl.dropbox.com/u/6568643/texopics/generated_test_data_resource.png
4. now 2 are beeing shown
https://dl.dropbox.com/u/6568643/texopics/instances_resource2.png
Looking at the json I noticed that the Resources that are beeing shown both have the OppositeIsPartOfResource set to null.
Is this expected? (Disclaimer: I have not used your new build, testing that out next)
Micha
Re: [Texo] Questions regarding the generated Testdata and other stuff [message #1031994 is a reply to message #1031985] Tue, 02 April 2013 08:57 Go to previous message
Hi Micha,
Yes I guess the resources being shown are root resources, so they are not contained in anything else. This probably
happens in the xml serialization on the server side.
gr. Martin
On 04/02/2013 02:42 PM, Micha-Jamie Guthmann wrote:
> Thanks again.
> See this: 1. generate test data with the library package creates 13 Resources
> null. Is this expected? (Disclaimer: I have not used your new build, testing that out next)
> Best regards,
> Micha
The Netherlands
Previous Topic:[Texo] Resolve proxies
Next Topic:[Texo] Persist already deleted objects
Current Time: Sun Jul 27 16:28:36 EDT 2025
Powered by FUDForum. Page generated in 0.03479 seconds
