EVL [message #1023868] |
Mon, 25 March 2013 06:36  |
Dear All,
I am having some problem with validating graphical editor I created with EuGeNia. I repeated the tutorial in [1], and it worked except that it didnt give me the option for a quick fix.
I tried same with a usecase_diagram graphical editor I created with EuGeNia, but it didnt work. The validation for the usecase_diagram is similar to the EVL in [1] and [2], i.e. check that each Actor has a name, each Usecase starts with a capital letter, and the Link must link the same e.g. Usecase to Usecase or Actor to Actor. I simply coppied the code in [1] and pasted into my usecase.evl, but changed the e-classs to suit my .emf file, e.g. instead of Folder I put Actor, in adding the extensions I made sure that I replaced filesystem with usecase. However this did not work.
Please I need some help, may be I am not getting it right. I have also seen the Screencast in [2].
[1] http://www.eclipse.org/epsilon/doc/articles/evl-gmf-integration/
[2] http://www.eclipse.org/epsilon/cinema/
Joshua
Re: EVL [message #1036666 is a reply to message #1036344] |
Mon, 08 April 2013 13:13  |
According to Dimitris, it may be due to setting up the markerType extension incorrectly. Did you check his instructions?
If you have, and it still doesn't work for you, please send us a project that we can try out to see if it's a bug in Epsilon or some other issue in your code or plugin.xml.
FUDForum. Page generated in 0.11878 seconds
