Home » Modeling » TMF (Xtext) » Auto convert keywords to uppercase while typing
Auto convert keywords to uppercase while typing [message #1027805] Wed, 27 March 2013 08:36 Go to next message
is it possible to get all keywords automatically converted to uppercase while typing it in MyDSL Eclipse Editor?
f.e. after i typed the keyword 'entity' and then whitespace after it, it should be automatically converted into 'ENTITY'.
Thank you!
Re: Auto convert keywords to uppercase while typing [message #1027810 is a reply to message #1027805] Wed, 27 March 2013 08:41 Go to previous messageGo to next message
you may have a look at
org.eclipse.xtext.ui.editor.autoedit.DefaultAutoEditStrategyProvider
Re: Auto convert keywords to uppercase while typing [message #1027868 is a reply to message #1027810] Wed, 27 March 2013 10:26 Go to previous messageGo to next message
Hi Christian,
thank you for quick response.
Next 2 questions:
1. Have i to implement my own "public class KeywordEditStrategy extends AbstractEditStrategy implements ISourceViewerAware { ..." using "protected void internalCustomizeDocumentCommand(IDocument document, DocumentCommand command)" to make all keywords (command.text) uppercase?
2. How can i get all keywords form my grammar ( perhaps i need something like "GrammarUtil.getAllKeywords(???)" )
Re: Auto convert keywords to uppercase while typing [message #1027875 is a reply to message #1027868] Wed, 27 March 2013 10:38 Go to previous messageGo to next message
(1)why not subclassing DefaultAutoEditStrategyProvider.
(2) let IGrammarAccess be injected, ask it for grammar und use grammarutil
Re: Auto convert keywords to uppercase while typing [message #1027939 is a reply to message #1027875] Wed, 27 March 2013 12:17 Go to previous messageGo to next message
Hi Christian,
have an another idea. Can we somehow use the eclipse syntax coloring at this place? I mean it is already the place where all keywords will be correctly recognised, so we don't need to implement it again.
Re: Auto convert keywords to uppercase while typing [message #1027956 is a reply to message #1027939] Wed, 27 March 2013 12:35 Go to previous messageGo to next message
If you have font that is uppercase. Adjusting the
defaulthighlightingconfiguration (or something like that) should do
it.
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Auto convert keywords to uppercase while typing [message #1027984 is a reply to message #1027956] Wed, 27 March 2013 13:23 Go to previous messageGo to next message
Thank you for all the hints.
And the last question is, how can i get a token-Object (ILexerTokenRegion?) according to a specified <offset> in a IDocument-Object? Is this possible?
Re: Auto convert keywords to uppercase while typing [message #1028454 is a reply to message #1027984] Thu, 28 March 2013 05:19 Go to previous messageGo to next message
sorry, is it not possible or is too stupid to ask about this?
Re: Auto convert keywords to uppercase while typing [message #1028477 is a reply to message #1028454] Thu, 28 March 2013 05:55 Go to previous messageGo to next message
I don't know the answer
Re: Auto convert keywords to uppercase while typing [message #1028725 is a reply to message #1028477] Thu, 28 March 2013 12:55 Go to previous messageGo to next message
i founded 2 solutions, which is working fine to me.
NOTE: This is a basic version and can only recognise keywords separated by whitespaces.
Solution 1 ( quickier one ):
public class MyDslEditStrategyProvider extends DefaultAutoEditStrategyProvider {
	@Inject
	Provider<IGrammarAccess> iGrammar;
	private Set<String> kwds;
	protected void configure(IEditStrategyAcceptor acceptor) {
		kwds = GrammarUtil.getAllKeywords(iGrammar.get().getGrammar());
		IAutoEditStrategy strategy = new IAutoEditStrategy() {
			public void customizeDocumentCommand(IDocument document, DocumentCommand command) {
				if ( command.text.length() == 0 || command.text.charAt(0) > ' ') return;
				IRegion reg = ((XtextDocument) document).getLastDamage();
				try {
					String token = document.get(reg.getOffset(), reg.getLength());
					String uToken = token.toUpperCase();
					if ( uToken.equals(token) || !kwds.contains(uToken) ) return;
					document.replace(reg.getOffset(), reg.getLength(), uToken);
				} catch (Exception e) {}
		acceptor.accept(strategy, IDocument.DEFAULT_CONTENT_TYPE);
		super.configure(acceptor);
Solution 2 ( more stable ):
	@Inject
	Provider<ITokenScanner> iScanner;
	private ITokenScanner scanner;
	private TextAttribute kwdatt;
		scanner = iScanner.get();
		kwdatt = ((TokenScanner)scanner).getTextAttributeProvider().getAttribute("keyword");
				scanner.setRange(document, reg.getOffset(), reg.getLength());
				IToken tok = scanner.nextToken();
				if (!tok.getData().equals(kwdatt)) return;
				try {
					if ( uToken.equals(token) ) return;
Many thanks to Christian for support!
[Updated on: Thu, 28 March 2013 14:54] by Moderator
Re: Auto convert keywords to uppercase while typing [message #1699420 is a reply to message #1028725] Wed, 24 June 2015 04:50 Go to previous messageGo to next message
I tried making exactly the same as you did, but nothing happens. How can I trigger the auto edit to occur? It doesn't happen automatically. Am I missing something? What folder/package should it be placed in?
Re: Auto convert keywords to uppercase while typing [message #1699429 is a reply to message #1699420] Wed, 24 June 2015 05:46 Go to previous messageGo to next message
@ayman did you bind it in UIModule?
Re: Auto convert keywords to uppercase while typing [message #1699433 is a reply to message #1699429] Wed, 24 June 2015 06:13 Go to previous messageGo to next message
No. How can i?
Re: Auto convert keywords to uppercase while typing [message #1699437 is a reply to message #1699433] Wed, 24 June 2015 06:37 Go to previous messageGo to next message
        public Class<? extends DefaultAutoEditStrategyProvider>
	bindDefaultAutoEditStrategyProvider() {
	return MyDslEditStrategyProvider.class;
add this in MyDslUIModule.java
Re: Auto convert keywords to uppercase while typing [message #1699451 is a reply to message #1699437] Wed, 24 June 2015 08:18 Go to previous messageGo to next message
I have done this now. And still it is not working. What am I doing wrong?
Should the DefaultAutoEditStrategyProvider be in some specific package?
And what is the expected behavior? Will writing a keyword then a space after trigger it and boom it's capitalized? or wat?
Re: Auto convert keywords to uppercase while typing [message #1699455 is a reply to message #1699437] Wed, 24 June 2015 08:36 Go to previous messageGo to next message
I have done it. I had some logical error. Now the thing is can I trigger it on format? on Ctrl+Shift+F?
Re: Auto convert keywords to uppercase while typing [message #1699459 is a reply to message #1699455] Wed, 24 June 2015 08:43 Go to previous messageGo to next message
public Class<? extends AbstractEditStrategyProvider> bindAbstractEditStrategyProvider() {
works fine for me (upper case is done as you type)
Re: Auto convert keywords to uppercase while typing [message #1699461 is a reply to message #1699459] Wed, 24 June 2015 08:50 Go to previous messageGo to next message
@Christian
Does that make it on "Format" Ctrl+Shift+F?
Because that was what I wanted. I didn't really wanted it as I type but it is a plus.
[Updated on: Wed, 24 June 2015 08:51] by Moderator
Re: Auto convert keywords to uppercase while typing [message #1699462 is a reply to message #1699461] Wed, 24 June 2015 08:52 Go to previous messageGo to next message
No
in the greeting example i type
crtl+space
then select Hello,
then type space
or i Type letter by Letter Hello and then space
Re: Auto convert keywords to uppercase while typing [message #1699463 is a reply to message #1699462] Wed, 24 June 2015 08:54 Go to previous messageGo to next message
Great! Thanks.
Um, Would you help me with my question on stackoverflow? It's major for me.
Re: Auto convert keywords to uppercase while typing [message #1699467 is a reply to message #1699463] Wed, 24 June 2015 09:06 Go to previous messageGo to next message
which one?
Re: Auto convert keywords to uppercase while typing [message #1699470 is a reply to message #1699467] Wed, 24 June 2015 09:19 Go to previous messageGo to next message
It is related to comments. I know this has been addressed in formatting2. So would you help me with either ones?
http://stackoverflow.com/questions/31022234/xtext-comments-formatting
https://www.eclipse.org/forums/index.php/m/1699469/#msg_1699469
Re: Auto convert keywords to uppercase while typing [message #1722814 is a reply to message #1027805] Tue, 09 February 2016 06:20 Go to previous messageGo to next message
I need to install an autoedit provider to trigger formatting on enter key (new line). In the UI module I have:
	public Class<? extends DefaultAutoEditStrategyProvider> bindDefaultAutoEditStrategyProvider()
	    System.out.println("Returning autoedit strategy provider");
	    return MyDSLAutoEditStrategyProvider.class;
and MyDSLAutoEditStrategyProvider currently just prints a message:
public class MyDSLAutoEditStrategyProvider extends DefaultAutoEditStrategyProvider {
       public MyDSLAutoEditStrategyProvider () {
		System.out.println("Created");
		System.out.println("configure called");
I see the message "Returning autoedit strategy provider" but not the message from the constructor of MyDSL... or the configure method.
I wonder if there are API changes in XText 2.9.1 that prevent the creation and installation of the custom AutoEditStrategy class.
Re: Auto convert keywords to uppercase while typing [message #1722817 is a reply to message #1722814] Tue, 09 February 2016 06:42 Go to previous messageGo to next message
hi are you sure you use
return YourAutoEditStrategyProvider.class;
Re: Auto convert keywords to uppercase while typing [message #1722823 is a reply to message #1722817] Tue, 09 February 2016 07:21 Go to previous messageGo to next message
In the UI module I also had this binding:
which overshadowed the declaration
Not an obvious error since the two methods bind different classes of strategy providers which turn out to be the same because of the class hierarchy
Re: Auto convert keywords to uppercase while typing [message #1722825 is a reply to message #1722823] Tue, 09 February 2016 07:43 Go to previous messageGo to next message
so does it work with my signature or does it not?
Re: Auto convert keywords to uppercase while typing [message #1722827 is a reply to message #1722825] Tue, 09 February 2016 07:53 Go to previous message
It works with either signatures as long as there is only one of them.
Thank you
Previous Topic:Get text ID for a reference during linking?
Next Topic:Lexer problem
Current Time: Mon Jul 21 22:34:43 EDT 2025
Powered by FUDForum. Page generated in 0.75524 seconds
