Home » Archived » BIRT » Implementation of the zoom in a chart
Implementation of the zoom in a chart [message #1016368] |
Wed, 06 March 2013 04:20  |
Hello!
I am visualizing in a view (Eclipse, java, SWT) a BIRT Line Chart, amongst other things. Now I want to implement the zoom option. I have the rectangle of the selection but I am in a trouble to get the data that is in this rectangle(I have tried different things and I have search on internet for some days). Can someone guide me? Which are the steps that I should follow?
Thank you for your time!
Re: Implementation of the zoom in a chart [message #1016910 is a reply to message #1016878] |
Fri, 08 March 2013 03:05   |
I have the rectangle that I have implemented in the listener of the ChartViewer and to be able to generate the Char I have an ArrayList of the dataset. In the listener I don´t know how can I access to the information of the dataset.
Listener listener = new Listener() {
public void handleEvent(Event event) {
switch (event.type) {
case SWT.MouseDown:
mouseDownXCoor = event.x;
mouseDownYCoor = event.y;
drag = true;
break;
case SWT.MouseMove:
if (drag) {
mouseUpXCoor = event.x;
mouseUpYCoor = event.y;
lineChartViewer.redraw();
break;
case SWT.MouseUp:
drag = false;
break;
case SWT.Paint:
if (drag) {
GC gc = event.gc;
gc.setBackground(Display.getDefault().getSystemColor(SWT.COLOR_BLACK));
gc.setAlpha(128);
int minX = Math.min(mouseDownXCoor, mouseUpXCoor);
int minY = Math.min(mouseDownYCoor, mouseUpYCoor);
int maxX = Math.max(mouseDownXCoor, mouseUpXCoor);
int maxY = Math.max(mouseDownYCoor, mouseUpYCoor);
int width = maxX - minX;
int height = maxY - minY;
gc.fillRectangle(minX, minY, width, height);
break;
lineChartViewer.addListener(SWT.MouseDown, listener);
lineChartViewer.addListener(SWT.MouseMove, listener);
lineChartViewer.addListener(SWT.MouseUp, listener);
lineChartViewer.addListener(SWT.Paint, listener);
This is the listener part where I create the rectangle. Thanks!!
[Updated on: Wed, 13 March 2013 05:50] by Moderator
Re: Implementation of the zoom in a chart [message #1027367 is a reply to message #1027133] |
Tue, 26 March 2013 18:33  |
When you use that type of trigger the class needs to implement ICallBackNotifier and you need to set the update notifier for the device renderer like:
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER, this );
Look at this example
package my.swt.live.viewer;
import org.eclipse.birt.chart.computation.DataPointHints;
import org.eclipse.birt.chart.device.ICallBackNotifier;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.event.StructureSource;
import org.eclipse.birt.chart.event.WrappedStructureSource;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.CallBackValue;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LineAttributes;
import org.eclipse.birt.chart.model.attribute.LineStyle;
import org.eclipse.birt.chart.model.attribute.Marker;
import org.eclipse.birt.chart.model.attribute.MarkerType;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.RiserType;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.CallBackValueImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.chart.util.PluginSettings;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.MessageBox;
import org.eclipse.swt.widgets.Shell;
public class SwtLiveChartViewer extends Composite implements
PaintListener,
ICallBackNotifier
private boolean bNeedsGeneration = true;
private IDeviceRenderer idr = null;
private Chart cm = null;
private GeneratedChartState gcs = null;
public static SwtLiveChartViewer c3dViewer;
* Used in building the chart for the first time
private boolean bFirstPaint = true;
public Chart getDesignTimeModel( )
return cm;
public void regenerateChart( )
redraw( );
public Chart getRunTimeModel( )
return gcs.getChartModel( );
public void repaintChart( )
redraw( );
public Object peerInstance()
return this;
public void callback( Object event, Object source, CallBackValue value )
Object obj1 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getBaseValue();
Object obj2 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getOrthogonalValue().toString();
Object obj3 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getSeriesValue();
double xval = ((DataPointHints)((WrappedStructureSource)source).getSource()).getLocation().getX();
double yval = ((DataPointHints)((WrappedStructureSource)source).getSource()).getLocation().getY();
StructureSource structuredSource = (StructureSource) source;
DataPointHints dph = (DataPointHints) structuredSource.getSource();
Object obj4 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getSeriesValue();
MessageBox mb = new MessageBox ( this.getShell( ) );
mb.setMessage( xval + "," + yval);
mb.open( );
* execute application
* @param args
public static void main( String[] args )
Display display = Display.getDefault( );
Shell shell = new Shell( display );
shell.setSize( 600, 400 );
shell.setLayout( new GridLayout( ) );
c3dViewer = new SwtLiveChartViewer( shell, SWT.NO_BACKGROUND );
c3dViewer.setLayoutData( new GridData( GridData.FILL_BOTH ) );
c3dViewer.addPaintListener( c3dViewer );
shell.open( );
while ( !shell.isDisposed( ) )
if ( !display.readAndDispatch( ) )
display.sleep( );
display.dispose( );
* Constructor
SwtLiveChartViewer( Composite parent, int style )
super( parent, style );
PlatformConfig config = new PlatformConfig();
config.setProperty( "STANDALONE", "true" ); //$NON-NLS-1$//$NON-NLS-2$
final PluginSettings ps = PluginSettings.instance( config );
try
idr = ps.getDevice( "dv.SWT" );//$NON-NLS-1$
catch ( ChartException ex )
ex.printStackTrace( );
cm = createLiveChart( );
public static final Chart createLiveChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
//Plot
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
Plot p = cwaBar.getPlot( );
p.getClientArea( ).setBackground( ColorDefinitionImpl.create( 255,
255,
225 ) );
//Legend
Legend lg = cwaBar.getLegend( );
LineAttributes lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).setLeft( 10 );
lg.getInsets( ).setRight( 10 );
//Title
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Live Chart Demo" );//$NON-NLS-1$
//X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.MIN_LITERAL );
xAxisPrimary.getTitle( )
.getCaption( )
.setValue( "Category Text X-Axis" );//$NON-NLS-1$
xAxisPrimary.setTitlePosition( Position.BELOW_LITERAL );
xAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 75 );
xAxisPrimary.setLabelPosition( Position.BELOW_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
.getLineAttributes( )
.setStyle( LineStyle.DOTTED_LITERAL );
.setColor( ColorDefinitionImpl.create( 64, 64, 64 ) );
xAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
//Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getLabel( ).getCaption( ).setValue( "Price Axis" );//$NON-NLS-1$
yAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 37 );
yAxisPrimary.setLabelPosition( Position.LEFT_LITERAL );
yAxisPrimary.setTitlePosition( Position.LEFT_LITERAL );
yAxisPrimary.getTitle( ).getCaption( ).setValue( "Linear Value Y-Axis" );//$NON-NLS-1$
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
.setColor( ColorDefinitionImpl.RED( ) );
yAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
//X-Series
Series seCategory = SeriesImpl.create( );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
//Y-Series (1)
BarSeries bs1 = (BarSeries) BarSeriesImpl.create( );
bs1.setSeriesIdentifier( "Unit Price" );//$NON-NLS-1$
bs1.setRiserOutline( null );
bs1.setRiser( RiserType.RECTANGLE_LITERAL );
//bs1.getTriggers( ).add(
// TriggerImpl.create( TriggerCondition.MOUSE_CLICK_LITERAL,
// ActionImpl.create( ActionType.TOGGLE_VISIBILITY_LITERAL, SeriesValueImpl.create("not used" ) ) ) );
//Trigger tr1 = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
// ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
// TooltipValueImpl.create(200, null)));
bs1.getTriggers( ).add( TriggerImpl.create( TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create( ActionType.CALL_BACK_LITERAL,
CallBackValueImpl.create( String.valueOf( bs1.getSeriesIdentifier( ) ) ) ) ) );
//bs1.getTriggers().add(tr1);
//Y-Series (2)
LineSeries ls1 = (LineSeries) LineSeriesImpl.create( );
ls1.setSeriesIdentifier( "Quantity" );//$NON-NLS-1$
ls1.getLineAttributes( ).setColor( ColorDefinitionImpl.GREEN( ) );
for ( int i = 0; i < ls1.getMarkers( ).size( ); i++ )
( (Marker) ls1.getMarkers( ).get( i ) ).setType( MarkerType.BOX_LITERAL );
ls1.setCurve( true );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeriesPalette( ).shift( -1 );
sdY.getSeries( ).add( bs1 );
sdY.getSeries( ).add( ls1 );
// Update data
updateDataSet( cwaBar );
return cwaBar;
static final void updateDataSet( ChartWithAxes cwaBar )
// Associate with Data Set
TextDataSet categoryValues = TextDataSetImpl.create( sa );
NumberDataSet seriesOneValues = NumberDataSetImpl.create( da1 );
NumberDataSet seriesTwoValues = NumberDataSetImpl.create( da2 );
// X-Axis
SeriesDefinition sdX = (SeriesDefinition) xAxisPrimary.getSeriesDefinitions( )
.get( 0 );
( (Series) sdX.getSeries( ).get( 0 ) ).setDataSet( categoryValues );
// Y-Axis
SeriesDefinition sdY = (SeriesDefinition) yAxisPrimary.getSeriesDefinitions( )
.get( 0 );
( (Series) sdY.getSeries( ).get( 0 ) ).setDataSet( seriesOneValues );
( (Series) sdY.getSeries( ).get( 1 ) ).setDataSet( seriesTwoValues );
//Live Date Set
private static final String[] sa = {
"One", "Two", "Three", "Four", "Five",//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
"Six", "Seven", "Eight", "Nine", "Ten"};//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
private static final double[] da1 = {
56.99,
352.95,
-201.95,
299.95,
-95.95,
25.45,
129.33,
-26.5,
43.5,
122
private static final double[] da2 = {
20, 35, 59, 105, 150, -37, -65, -99, -145, -185
public final void paintControl( PaintEvent e )
Rectangle d = this.getClientArea( );
Image imgChart = new Image( this.getDisplay( ), d );
GC gcImage = new GC( imgChart );
//Look at IDeviceRenderer.java for all properties
//like DPI_RESOLUTION
//FILE_IDENTIFIER
//FORMAT_IDENTIFIER
//UPDATE_NOTIFIER
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, gcImage );
Bounds bo = BoundsImpl.create( 0, 0, d.width, d.height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
if ( bNeedsGeneration )
bNeedsGeneration = false;
try
gcs = gr.build( idr.getDisplayServer( ),
cm,
bo,
null,
null,
null );
catch ( ChartException ce )
ce.printStackTrace( );
if ( bFirstPaint )
bFirstPaint = false;
try
gr.render( idr, gcs );
GC gc = e.gc;
gc.drawImage( imgChart, d.x, d.y );
Current Time: Sat Jul 19 00:22:13 EDT 2025
Powered by FUDForum. Page generated in 0.07274 seconds
