Home » Modeling » Compare » Ignoring Elements completely in custom Match and Diff Engine
Ignoring Elements completely in custom Match and Diff Engine [message #901012] Thu, 09 August 2012 07:59 Go to next message
I am working on a custmization to compare java models discovered using the MoDisco tooling.
Such models can contain class declarations etc. from packages which I am not interested in. So I would like to ignore all elements and possible changes from classes, interfaces, etc. in those packages.
Up to know, I implemented such a filter in the processUnmatchedElements() of a custom DiffEngine extending the GenericDiffEngine.
I also handle those elements within a custom MatchEngine and there are other methods in the custom DiffEngine I will have to adapt to filter diffs of JavaModel elements from specific packages.
However, I was wondering if there is a method I could adapt to specify model elements which should be completely ignored to
1) not have to implement filters in a lot of methods scattered around the code
2) improve performance by filtering them right at the beginning of the process.
Thanks a lot
Benjamin
Re: Ignoring Elements completely in custom Match and Diff Engine [message #903325 is a reply to message #901012] Thu, 23 August 2012 03:50 Go to previous messageGo to next message
Hi Benjamin,
EMF Compare 1.* did not provide any easy mean to filter out elements entirely. What you are currently doing is the easiest way to do so.
The current development effort focuses on EMF Compare 2.0; and this version will be much more simple in terms of customization. If you are not too far in your customization, and mainly use EMF Compare for models with identifiers (XMI ID or ID attributes), you might want to start with this version instead. It will be what we contribute to Kepler in the Eclipse yearly release for 2013, and it breaks most APIs since it is a total re-thought of the comparison process.
If you do give a chance to EMF Compare 2, what you need to provide is an implementation of the IComparisonScope that removes the elements you do not wish compared. You can then pass this on to EMFCompare.compare().
Laurent Goubet
Obeo
Re: Ignoring Elements completely in custom Match and Diff Engine [message #1027240 is a reply to message #901012] Tue, 26 March 2013 14:43 Go to previous messageGo to next message
Could you provide a code snippet that shows how to filter out an element in the IComparisonScope implementation for this scenario?
Jaime
Re: Ignoring Elements completely in custom Match and Diff Engine [message #1032584 is a reply to message #1027240] Wed, 03 April 2013 03:16 Go to previous message
Jaime,
Please ask your questions in a separate thread... and describe what you want (what could "this scenario" be?).
You might also want to look at the IComparisonScope javadoc and existing implementations... For example the FilterComparisonScope that simply asks you for a predicate to filter objects.
Laurent Goubet
Obeo
Previous Topic:Configuring EMF Compare
Next Topic:org.eclipse.emf.compare.edit might be in the wrong feature
Current Time: Sun Jul 27 14:13:28 EDT 2025
Powered by FUDForum. Page generated in 0.04047 seconds
