Home » Archived » Visual Editor (VE) » (newbie) Using VE to create Wizard pages
(newbie) Using VE to create Wizard pages [message #102712] |
Wed, 17 August 2005 16:13  |
Originally posted by: busch.roguewave.com
Hi Folks,
I just downloaded VE and started working with it to help speed up
development of a multi-page wizard plugin project. I've skimmed through
the tutorial here
http://www-128.ibm.com/developerworks/opensource/library/os- ecvisual/ and
got my wizard to display a panel just fine but it seems like I lose the
wizard functionality of Back Next Finish Cancel buttons as well as the
general wizard look and feel.
Am I doing something wrong? Is there a tutorial I can read to figure this
out?
Thanks!
Mike
Re: (newbie) Using VE to create Wizard pages [message #102778 is a reply to message #102712] |
Thu, 18 August 2005 10:19   |
Originally posted by: jdstinto.us.ibm.com
Hi Mike,
I have a few questions for you to help me understand your problem a
little better. Also it looks like that tutorial is pretty old (0.5
release time frame) we are up to 1.1, so you may actually find better
help inside of eclipse (Help->Help Contents->Visual Editor for Java User
Guide).
1) I looked through the tutorial as well, and I did not see any steps
creating a wizard, so the wizard you mention is the one you are trying
to create for your project, correct?
2) If so, When you say you lose the functionality of the Back, Next,
Finish, and Cancel buttons what does that entail. Each of these buttons
will need event listeners on them, and these will only work when running
your program (for instance Run As->Java Bean). During design time they
will be inactive.
3) When you say you lose the general look and feel what specifically is
this. I see you are dropping a panel, so it will not have the same
borders and looks as a frame, is that what you mean? If you mean
general Java look and feel check out Window->Preferences->Java->Visual
Editor and notice the Swing Look and feel box that you can select a
specific look and feel with.
If that's enough to get you going great, otherwise post back with some
follow up info and we'll see what we can do for you.
Good luck!
-Jon
> Hi Folks,
> the tutorial here
> out?
> Thanks!
> Mike
Re: (newbie) Using VE to create Wizard pages [message #102798 is a reply to message #102778] |
Thu, 18 August 2005 10:34   |
On Thu, 18 Aug 2005 10:19:12 -0400, Jonathan Stinton wrote:
Answers inline:
Correct. I started a new "Hello World" plugin and pointed the Action
class's run() method to instantiate my wizard class. The wizard class then
instantiates the wizard page classes.
> will be inactive.
Wizard pages bring a certain amount of "look and feel" as well as
functionality to the party. Just by extending the WizardPage class you
should automatically get a dialog with "Back" "Next" etc. buttons, and they
have default behavior.
When I follow that tutorial and drop a Shell on the canvas and instantiate
it in the createControl() method, it gives me a blank dialog with no wizard
functionality.
Specifically, wizard pages have an area below the title bar that contains a
description of what the page does as well as an icon. While I know I can
re-create this behavior, why should I have to when I should get it for
free?
I didn't see anything in the docs that addresses my questions but I'll go
back through them and see if I can find more.
Thanks!
Re: (newbie) Using VE to create Wizard pages [message #102801 is a reply to message #102798] |
Thu, 18 August 2005 11:12   |
Mike,
This explains a lot. You had mentioned panels and I figured you were
talking about Swing JPanels (based on the tutorial link) and hand
building the whole wizard.
What is really going is on it seems is that you are trying to create a
JFace Wizard. Unfortunately right now, we don't directly provde this
fuctionality. As of 1.1 we have Views and Editor, we hope by 1.2 to
provide full Wizard support.
The way around this for now is to create your custom composite with
everything you want in it, this will allow you to use the VE. Then in
another class extend WizardPage and use the provided fields you want
there. In your custom WizardPage you can embed your custom composite
[in the createControl method I believe you would use new
customComposite(parent, style)] and that should do the trick I think.
Let me know how it works, some of the other developers might have some
more help if you need it.
Jon
> Answers inline:
>>will be inactive.
> functionality.
> free?
> Thanks!
Re: (newbie) Using VE to create Wizard pages [message #102819 is a reply to message #102798] |
Thu, 18 August 2005 11:14  |
> functionality.
Shouldn't you instead make a Panel, and insert that in creteControl()?
Re: (newbie) Using VE to create Wizard pages [message #610330 is a reply to message #102712] |
Hi Mike,
Guide).
will be inactive.
Good luck!
-Jon
> Hi Folks,
> the tutorial here
> out?
> Thanks!
> Mike
Re: (newbie) Using VE to create Wizard pages [message #610331 is a reply to message #102778] |
Answers inline:
> will be inactive.
functionality.
free?
Thanks!
Re: (newbie) Using VE to create Wizard pages [message #610332 is a reply to message #102798] |
Mike,
Jon
> Answers inline:
>>will be inactive.
> functionality.
> free?
> Thanks!
Re: (newbie) Using VE to create Wizard pages [message #610333 is a reply to message #102798] |
> functionality.
Current Time: Sat Jul 19 04:09:48 EDT 2025
Powered by FUDForum. Page generated in 0.05764 seconds
