Home » Archived » BIRT » Fix color for series in bar chart
Fix color for series in bar chart [message #1027046] Tue, 26 March 2013 09:59 Go to next message
I have a bar chart that shows for each month data that is split into three categories:
  • within specification
  • within specification after adj.
  • out of specification
It can happen that one of these categories is not present for several months.
Therefore it could happen that for a status the bar color could change.
But I want to have a fixed color theme e.g.
  • within specification = blue
  • within specification after adj. = yellow
  • out of specification = red
Is this somehow possible?
Next is the order of the bars. I am only able to sort them after the name. I would like to also sort them like the first list...
Anyone an idea?
  • Attachment: Snap16.jpg
    (Size: 28.10KB, Downloaded 482 times)
Re: Fix color for series in bar chart [message #1027391 is a reply to message #1027046] Tue, 26 March 2013 19:16 Go to previous messageGo to next message
You can set the color using a script similar to:
function beforeDrawDataPoint(dph, fill, icsc)
val = dph.getBaseDisplayValue();
if (val == "within specification"){
fill.set(255, 0, 0);
You should be able to change the order by putting in a custom expression on the sort expression for the optional grouping category.
Re: Fix color for series in bar chart [message #1027951 is a reply to message #1027046] Wed, 27 March 2013 12:32 Go to previous messageGo to next message
hmm this is not working for flash charts. I'll try it with a normal one..
Re: Fix color for series in bar chart [message #1028071 is a reply to message #1027951] Wed, 27 March 2013 16:02 Go to previous messageGo to next message
Daniel
For flash you will need to do something like:
if( fcdph.getDataPointHints().getBaseValue() == "S12_3148" ){
fill.setRed(255);
fill.setBlue(0);
fill.setGreen(0);
BTW have you seen this post?
http://birtworld.blogspot.com/2010/08/birt-flash-and-gadget-scripting.html
Re: Fix color for series in bar chart [message #1033557 is a reply to message #1028071] Thu, 04 April 2013 07:12 Go to previous messageGo to next message
thanks! I will give it a try!
Re: Fix color for series in bar chart [message #1033572 is a reply to message #1027046] Thu, 04 April 2013 07:38 Go to previous messageGo to next message
Ok,
just tried it with a normal chart.
I had to change things a little, because I want to change the color depending on the series:
That works for me:
function beforeDrawDataPoint( dph, fill, icsc )
	test = dph.getBaseValue();
	test2 = dph.getSeriesDisplayValue();
	if (test2 == 'within specification'){
		fill.set(255,255,0);
	else {
		fill.set(255,0,0);
ps: I have one more issue. The legend of the series still shows the old color. Is there a possible way to change that one also?
  • Attachment: Snap30.jpg
    (Size: 17.18KB, Downloaded 525 times)
[Updated on: Thu, 04 April 2013 07:48] by Moderator
Re: Fix color for series in bar chart [message #1033661 is a reply to message #1033572] Thu, 04 April 2013 09:43 Go to previous message
just solved it:
function beforeDrawLegendItem( lerh, bounds, icsc )
	var label = lerh.getLabel().getCaption().getValue();
	if( label == "within specification")
		lerh.getFill().set(0,158,227);
	else if (label == 'within specification after adj.')
		lerh.getFill().set(247,234,72);
	else if (label == 'out of specification')
		lerh.getFill().set(227,41,9);
	else if (label == 'unknown')
		lerh.getFill().set(255,0,128);
Previous Topic:Choose database and populate combo box
Next Topic:Drill Through-Do BIRT API provide any support to Extract Info about child report from Parent report?
Current Time: Wed Jul 23 11:31:49 EDT 2025
Powered by FUDForum. Page generated in 0.04817 seconds
