Home » Modeling » Graphiti » adding anchors to connections?
adding anchors to connections? [message #1022256] Thu, 21 March 2013 10:56 Go to next message
Hey,
i want to start a connection at the middle of another connection.
Is it possible to add anchors to a connection?
Or are there any limitations in graphiti i should now about?
Re: adding anchors to connections? [message #1022320 is a reply to message #1022256] Thu, 21 March 2013 13:07 Go to previous messageGo to next message
On 21.03.13 07.56, Annika Wießgügel wrote:
> Hey,
I also need this in a feature that is supposed to create a fork where
there was only a connection. I want to have an anchor on the middle of
the connection, that can be used as a starting point for another connection.
A connection is an anchor container, so it is possible to add it.
However, I've not been able to use that anchor as the starting point for
a connection, nor make it visible.
Well, there seems to be, but I'm not sure it is intentional or just
something that's not implemented, yet. Hope to see an "official" answer
to this question.
Hallvard
Re: adding anchors to connections? [message #1022629 is a reply to message #1022320] Fri, 22 March 2013 05:02 Go to previous messageGo to next message
This has been available for a long time now (https://bugs.eclipse.org/bugs/show_bug.cgi?id=326396), please see the Sketch example for a working example. The relevant section is in the AbstractSketchCreateSimpleConnectionFeature#create method.
The trick is that you don't add an anchor to an existing connection, but a brand new shape in the middle of it.
Re: adding anchors to connections? [message #1024022 is a reply to message #1022629] Mon, 25 March 2013 12:51 Go to previous messageGo to next message
This trick does not utilize the fact that connections are anchor
containers, which was what the question was about. But I agree that the
trick is nice. I did something similar myself, but created the
connection point using a separate double-click feature. It is better to
do it in the create connection feature, like in the example.
Hallvard
Re: adding anchors to connections? [message #1027016 is a reply to message #1024022] Tue, 26 March 2013 09:09 Go to previous message
To answer that last open question: anchors in connections are currently not
supported by Graphiti.
Michael
Previous Topic:Beginner Question
Next Topic:Select Shapes over the SelectTool
Current Time: Sat Jul 26 02:51:51 EDT 2025
Powered by FUDForum. Page generated in 0.06573 seconds
