Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TENEO] using createSQLQuery
[TENEO] using createSQLQuery [message #102505] |
Tue, 13 November 2007 15:15  |
I have a teneo annotated ecore model and I have been able to
successfully make HQL queries such as:
session.createQuery("from GeneralCodeItem")
However, if I try to use a SQL query such as:
session.createSQLQuery("select value, description, short_description
from general_code_item").addEntity("GeneralCodeItem")
I get
64606777 [main] INFO org.hibernate.type.StringType - could not read
column value from result set: "VALUE"; Invalid column name
After debugging, I've determined the source of the problem in an
additional set of quotes. The result set has a column VALUE, but
hibernate is looking for "VALUE". When I look in the mapping file, I
see backticks in the column name which I presume is the source of the
extra quotes:
<id name="value" type="java.lang.String">
<column not-null="true" unique="false" name="`VALUE`"/>
</id>
All my column names have backticks. What is the reason for this and is
there anything I can do about it? I have the following workaround, but
it is very verbose and defeats the purpose of having the teneo mappings:
session.createSQLQuery("select {gc}.value {gc.value}, {gc}.description
{gc.description}, {gc}.short_description {gc.shortDescription} from
general_code_item {gc}").addEntity("gc", "GeneralCodeItem")
Thanks!
Will
Re: [TENEO] using createSQLQuery [message #102546 is a reply to message #102505] |
Tue, 13 November 2007 16:52   |
Hi Will,
The mapping has backticks because then hibernate will quote the names when issueing real sql
statements. This allows for example column names or table names which are sql keywords (for example
index).
Can you try a backticked sql query, something like this:
session.createSQLQuery("select `VALUE` from general_code_item").addEntity("GeneralCodeItem")
btw, for my curiosity why don't you use a hql? Because then afaics this issue does not occur.
gr. Martin
> I get
> extra quotes:
> </id>
> Thanks!
> Will
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] using createSQLQuery [message #102555 is a reply to message #102546] |
Tue, 13 November 2007 17:10   |
Thanks for the reply Martin.
When I use backticks, I get an "Invalid character" exception.
The reason I'm not using HQL is that the query is actually much more
complicated :) I need to use unmapped columns in the where clause and
subselects against other tables. In particular (if you care),
description and short_description can have translations in other tables.
Also, the rows are also effective dated. I wanted to hide this
complexity from my EMF model and thought this would be the best ways to
achieve that.
For the post, I just boiled it down to the simplest case.
Any other suggestions?
Thanks again,
Will
Martin Taal wrote:
> Hi Will,
> when issueing real sql statements. This allows for example column names
> or table names which are sql keywords (for example index).
> gr. Martin
>> I get
>> extra quotes:
>> </id>
>> is there anything I can do about it? I have the following workaround,
>> but it is very verbose and defeats the purpose of having the teneo
>> mappings:
>> Thanks!
>> Will
Re: [TENEO] using createSQLQuery [message #102584 is a reply to message #102555] |
Tue, 13 November 2007 18:33   |
I tested it and it seems a hibernate issue to me. I can also see that hibernate tries to get a
backticked column name from the resultset. Backticking in the mapping file is allowed so this sql
query should not be a problem.
I tested without backticking and then the query works fine.
As a workaround to prevent the backticking you can do the following:
- override the MappingContext class and then this method:
protected String trunc(String truncName, boolean truncPrefix) {
- the standard implementation method will return a backticked string, the easiest is call the
superclass then to strip the backticks off, or ofcourse you can override the complete method
- register your subclass of MappingContext as an extension (before initializing the datastore), see
here:
http://www.elver.org/hibernate/extensions.html
The extension point is the MappingContext.class.
gr. Martin
> achieve that.
> Thanks again,
> Will
> Martin Taal wrote:
>> Hi Will,
>> names or table names which are sql keywords (for example index).
>> gr. Martin
>>> I get
>>> extra quotes:
>>> </id>
>>> workaround, but it is very verbose and defeats the purpose of having
>>> the teneo mappings:
>>> {gc}.description {gc.description}, {gc}.short_description
>>> {gc.shortDescription} from general_code_item {gc}").addEntity("gc",
>>> "GeneralCodeItem")
>>> Thanks!
>>> Will
The Netherlands
Re: [TENEO] using createSQLQuery [message #102878 is a reply to message #102584] |
Thu, 15 November 2007 18:28   |
Thanks for looking into it. I found this
http://opensource.atlassian.com/projects/hibernate/browse/HH H-1093 so
apparently it is a bug. Their workaround is to have an explicit
<return-property> for the affected property, which is essentially the
more verbose syntax I was using.
It would be cleaner for my purposes to actually use the <sql-query> and
<return-property> elements in the hibernate mapping xml, which leads me
to the question of whether it is possible to merge elements into the
teneo generated hibernate mapping xml at runtime. I know I can just
make the modifications and create a static hibernate.hbm.xml, but that
seems like it would be harder to maintain if the ecore changes.
I've searched the newsgroup and the evler.org help but didn't see
anything about this.
-Will
> hibernate tries to get a backticked column name from the resultset.
> Backticking in the mapping file is allowed so this sql query should not
> be a problem.
> the easiest is call the superclass then to strip the backticks off, or
> initializing the datastore), see here:
> gr. Martin
>> tables. Also, the rows are also effective dated. I wanted to hide
>> this complexity from my EMF model and thought this would be the best
>> ways to achieve that.
>> Thanks again,
>> Will
>> Martin Taal wrote:
>>> Hi Will,
>>> gr. Martin
>>>> I get
>>>> read column value from result set: "VALUE"; Invalid column name
>>>> I see backticks in the column name which I presume is the source of
>>>> the extra quotes:
>>>> </id>
>>>> the teneo mappings:
>>>> "GeneralCodeItem")
>>>> Thanks!
>>>> Will
Re: [TENEO] using createSQLQuery [message #102984 is a reply to message #102878] |
Fri, 16 November 2007 08:52  |
There are a number of classes in the org.eclipse.emf.teneo.hibernate.mapper package which you can
override with your own implementation. Each of these classes handles one specific aspect of the
mapping. See here on how to plug your own classes into the system:
Did you try to remove the backticks from the mapping (see a few posts back in this thread)?
gr. Martin
> -Will
>> not be a problem.
>> gr. Martin
>>> and subselects against other tables. In particular (if you care),
>>> Thanks again,
>>> Will
>>> Martin Taal wrote:
>>>> Hi Will,
>>>> names when issueing real sql statements. This allows for example
>>>> column names or table names which are sql keywords (for example index).
>>>> gr. Martin
>>>>> short_description from
>>>>> I get
>>>>> the extra quotes:
>>>>> </id>
>>>>> and is there anything I can do about it? I have the following
>>>>> "GeneralCodeItem")
>>>>> Thanks!
>>>>> Will
The Netherlands
Re: [TENEO] using createSQLQuery [message #612501 is a reply to message #102505] |
Hi Will,
index).
gr. Martin
> I get
> extra quotes:
> </id>
> Thanks!
> Will
The Netherlands
Re: [TENEO] using createSQLQuery [message #612503 is a reply to message #102546] |
achieve that.
Thanks again,
Will
Martin Taal wrote:
> Hi Will,
> gr. Martin
>> I get
>> extra quotes:
>> </id>
>> mappings:
>> Thanks!
>> Will
Re: [TENEO] using createSQLQuery [message #612507 is a reply to message #102555] |
here:
gr. Martin
> achieve that.
> Thanks again,
> Will
> Martin Taal wrote:
>> Hi Will,
>> gr. Martin
>>> I get
>>> extra quotes:
>>> </id>
>>> the teneo mappings:
>>> "GeneralCodeItem")
>>> Thanks!
>>> Will
The Netherlands
Re: [TENEO] using createSQLQuery [message #612552 is a reply to message #102584] |
-Will
> be a problem.
> gr. Martin
>> Thanks again,
>> Will
>> Martin Taal wrote:
>>> Hi Will,
>>> gr. Martin
>>>> I get
>>>> the extra quotes:
>>>> </id>
>>>> the teneo mappings:
>>>> "GeneralCodeItem")
>>>> Thanks!
>>>> Will
Re: [TENEO] using createSQLQuery [message #612565 is a reply to message #102878] |
gr. Martin
> -Will
>> not be a problem.
>> gr. Martin
>>> Thanks again,
>>> Will
>>> Martin Taal wrote:
>>>> Hi Will,
>>>> gr. Martin
>>>>> I get
>>>>> the extra quotes:
>>>>> </id>
>>>>> "GeneralCodeItem")
>>>>> Thanks!
>>>>> Will
The Netherlands
Current Time: Sat Jul 19 08:03:39 EDT 2025
Powered by FUDForum. Page generated in 0.04280 seconds
