Home » Modeling » EMF » Exporting multiple XSD schemas to ecore programmatically
Exporting multiple XSD schemas to ecore programmatically [message #1023999] Mon, 25 March 2013 12:02 Go to next message
Hi All,
I am trying to export a group of interrelated XSD schemas to ecore programmatically(in order to get an ecore annotated with proper extended metadata for XML serialization). I am using the XSDEcoreBuilder but in the resulting ecore models, the external inheritance links are lost. I tried using the XSDEcoreBuilder.generate(collection<URI>) but I also wanted to try XSDEcoreBuilder.generate(XSDSchema) but this method returns void, I didn't understand how to use it.
If anyone have any idea, it would be very helpful.
Here is my code using XSDEcoreBuilder.generate(collection<URI>):
public void exportXSDToEcore(Collection<URI> sourceXSDFilePaths_p) {
XSDEcoreBuilder xsdEcoreBuilder = new XSDEcoreBuilder();
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xsd", new XSDResourceFactoryImpl());
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("genmodel", new EcoreResourceFactoryImpl());
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Collection<Object> eCorePackages = xsdEcoreBuilder.generate(sourceXSDFilePaths_p);
Resource resource = resourceSet.createResource(URI.createFileURI("metamodel.generated.ecore"));
for (Object element : eCorePackages) {
if (element instanceof EObject) {
resource.getContents().add((EObject) element);
try {
resource.save(null);
} catch (IOException e) {
e.printStackTrace();
Re: Exporting multiple XSD schemas to ecore programmatically [message #1024021 is a reply to message #1023999] Mon, 25 March 2013 12:54 Go to previous messageGo to next message
Skander,
Comments below.
On 25/03/2013 12:02 PM, Skander Turki wrote:
> Hi All,
What do you mean by the external inheritance links?
If you look at the implementations of these methods, you should get the
idea...
> Resource resource =
> try {
Re: Exporting multiple XSD schemas to ecore programmatically [message #1024029 is a reply to message #1024021] Mon, 25 March 2013 13:15 Go to previous messageGo to next message
By external inheritance links, I meant inheritance links from a model element to model elements that are not in the element's XSD but in another XSD of my XSD-family.
So I obtain one ecore file with as many packages as XSD schemas but the references between them are broken, like inheritances or cross-references that become (AnySimpleType) instead of the initial type in the XSD.
Re: Exporting multiple XSD schemas to ecore programmatically [message #1024036 is a reply to message #1024029] Mon, 25 March 2013 13:31 Go to previous messageGo to next message
Skander,
Comments below.
The exporter framework solves all these types of problem and you're
trying to handle all these same complexities with a different
implementation. All I can suggest is you look at how this works in the
IDE and use that as a basis because I don't have the time to help you
solve these same problems a second time.
> type in the XSD.
Re: Exporting multiple XSD schemas to ecore programmatically [message #1027696 is a reply to message #1024036] Wed, 27 March 2013 05:32 Go to previous message
I tried to look to what the plugins are doing when we use the wizard and I have found that they were using ModelImporter in org.eclipse.emf.importer, XSDImprter in org.eclipse.xsd.ecore.importer and ModelConverter in org.eclipse.emf.converter. I am trying the code inspired from the wizard. I'll post it as soon as I get it to work.
Previous Topic:Registering EMF EPackage for Xtext
Next Topic:Package: get EClass by name?
Current Time: Sat Jul 26 23:45:32 EDT 2025
Powered by FUDForum. Page generated in 0.08797 seconds
