Home » Eclipse Projects » Eclipse Platform » Textbox resize strange behavior
Textbox resize strange behavior [message #1023921] Mon, 25 March 2013 09:11
Hi! I extracted following Snippet for reproduction. For me it seems like an eclipse/swt bug but maybe somebody knows more.
The Problem occurs when i enter a text in the textbox. Than i start to resize the window horizontally so that the text gets hidden. Now when i resize the window to a bigger size again, sometimes the text is missing or only shown half depending on the speed of the resize/mouse move. The Problem there is that the cursor in the textbox is not set right (to the end or beginning of the text).
This doesn't happen if in the "Windows Desktop Settings/Themes -> Effects -> Show window content when resizing" is turned off. Sorry i only have a german Windows Version so i can't say the exact english name of the option.
By the way i am working with WinXP professional and eclipse 3.6
Maybe somebody has an idea or suggestion how to work around this limitation.
Thanks and best regards
Weinma
package test;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.jface.layout.GridLayoutFactory;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class TextTestMain {
	 * @param args
		final Display display = new Display();
		Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
			public void run() {
				Shell shell = new Shell(display);
				createControl(shell);
				shell.open();
				while (!shell.isDisposed()) {
					if (!display.readAndDispatch())
					    display.sleep();
		display.dispose();
	private static void createControl(Shell shell) {
		shell.setLayout(new FillLayout());
		Composite parent = new Composite(shell,SWT.BORDER);
		GridLayoutFactory.fillDefaults().numColumns(3).applyTo(parent);
		Label label = new Label(parent, SWT.NONE);
		label.setText("asdklsadflkaösdlföknaslökdfnlökwadnfölan");
		GridDataFactory.fillDefaults().grab(true, true).applyTo(label);
		Text text = new Text(parent,SWT.BORDER);
		GridDataFactory.fillDefaults().grab(true, true).applyTo(text);
		Label label1 = new Label(parent, SWT.NONE);
		label1.setText("blablablabla");
		GridDataFactory.fillDefaults().applyTo(label1);
		shell.pack();
Previous Topic:Eclipse with Processing
Next Topic:menucontribution appears only in one perspective
Current Time: Sun Jul 20 20:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
