Home » Eclipse Projects » Virgo » NoClassDefFoundError for javax.annotation.Priority
NoClassDefFoundError for javax.annotation.Priority [message #1023271] Sat, 23 March 2013 16:26 Go to next message
Hi, I'm trying to use Virgo with Jersey 2 but when I try to access to the rest service, the Jersey servlet throws this exception:
java.lang.NoClassDefFoundError: javax/annotation/Priority
	at org.glassfish.jersey.model.internal.RankedProvider.computeRank(RankedProvider.java:86)
	at org.glassfish.jersey.model.internal.RankedProvider.<init>(RankedProvider.java:79)
	at org.glassfish.jersey.internal.inject.Providers.getAllRankedProviders(Providers.java:223)
	at org.glassfish.jersey.server.ApplicationHandler.getProcessingProviders(ApplicationHandler.java:460)
	at org.glassfish.jersey.server.ApplicationHandler.initialize(ApplicationHandler.java:363)
	at org.glassfish.jersey.server.ApplicationHandler.access$500(ApplicationHandler.java:147)
	at org.glassfish.jersey.server.ApplicationHandler$3.run(ApplicationHandler.java:270)
	at org.glassfish.jersey.internal.Errors$2.call(Errors.java:249)
	at org.glassfish.jersey.internal.Errors$2.call(Errors.java:246)
I have read in this post that the cause of this kind of problems may be the configuration in java6-server.profile and org.eclipse.virgo.kernel.userregion.properties files. I have tried putting the next lines in these files without luck:
javax.annotation;version="0",\ in org.eclipse.virgo.kernel.userregion.properties under packageImports
javax.annotation,\ in java6-server.profile under org.osgi.framework.bootdelegation:q
Also I have tried to import this package in my bundle but it didn't work.
What's wrong with my bundles?
Thanks in advance.
Re: NoClassDefFoundError for javax.annotation.Priority [message #1023533 is a reply to message #1023271] Sun, 24 March 2013 09:34 Go to previous messageGo to next message
You have to provide this class by yourself.
It is neither part of the standard Java SE 6 API nor Java EE 6 API.
This is part of the Commons Annotations 1.2 MR which is part of Java EE 7 API which is expected at the end of the April this year.
http://java.net/projects/javaee-spec/pages/CommonAnnotations1_2MR
Violeta
[Updated on: Sun, 24 March 2013 09:38] by Moderator
Re: NoClassDefFoundError for javax.annotation.Priority [message #1023584 is a reply to message #1023533] Sun, 24 March 2013 12:42 Go to previous message
Hi Violetta,
Thanks for your answer. This commons annotations bundle is already loaded, I downloaded the file jax-rs-ri-2.0-m13-3.tar.gz from Jersey site and I created the next plan with the bundles in the tarball:
<plan name="jersey" version="2.0.0" scoped="false" atomic="true"
        xmlns="http://www.eclipse.org/virgo/schema/plan"
		xsi:schemaLocation="
		        http://www.eclipse.org/virgo/schema/plan/eclipse-virgo-plan.xsd">
	<artifact type="bundle" name="org.glassfish.hk2.external.asm-all-repackaged" version="[2.1.76, 3)" />
	<artifact type="bundle" name="org.glassfish.hk2.external.cglib" version="[2.1.76, 3)" />
	<artifact type="bundle" name="com.google.guava" version="[14.0.0, 15.0.0)" />
	<artifact type="bundle" name="org.glassfish.hk2.api" version="[2.1.76, 3)" />
	<artifact type="bundle" name="org.glassfish.hk2.utils" version="[2.1.76, 3)" />
	<artifact type="bundle" name="org.glassfish.hk2.external.javax.inject" version="[2.1.76, 3)" />
	<artifact type="bundle" name="javax.ws.rs.javax.ws.rs-api" version="[2.0.0, 3)" />
	<artifact type="bundle" name="org.glassfish.jersey.core.jersey-client" version="[2.0.0, 3)" />
	<artifact type="bundle" name="org.glassfish.jersey.core.jersey-common" version="[2.0.0, 3)" />
	<artifact type="bundle" name="org.glassfish.jersey.containers.jersey-container-servlet" version="[2.0.0, 3)" />
	<artifact type="bundle" name="org.glassfish.jersey.containers.jersey-container-servlet-core" version="[2.0.0, 3)" />
	<artifact type="bundle" name="org.glassfish.jersey.core.jersey-server" version="[2.0.0, 3)" />
	<artifact type="bundle" name="org.glassfish.hk2.osgi-resource-locator" version="[1.0.1, 2)" />
	<artifact type="bundle" name="javax.validation.api" version="[1.1.0, 2)" />
	<artifact type="bundle" name="javax.annotation-api" version="[1.1.99, 2)" />
	<artifact type="bundle" name="javax.servlet-api" version="[3.0.0, 4)" />
</plan>
I've tried downgrade the version of Jersey by using the 1.17 but I received the next exception when I ask for the RESTful resource:
com.sun.jersey.core.spi.scanning.ScannerException: The URI scheme bundleentry of the URI bundleentry://149.fwk650188911/WEB-INF/classes/jersey/test/RestService.class is not supported. Package scanning deployment is not supported for such URIs.
Try using a different deployment mechanism such as explicitly declaring root resource and provider classes using an extension of javax.ws.rs.core.Application
I just wanted to export my blueprint services by using JAX-RS (the implementation no matter) in Virgo Jetty Server, but this process is becoming painful.
I really appreciate any example with JAX-RS (Jersey or CXF) in Virgo Jetty Server.
Thanks in advance,
Eduardo Fernández.
Previous Topic:LDAP over SSL keystore
Next Topic:Spring data
Current Time: Wed Jul 23 08:52:02 EDT 2025
Powered by FUDForum. Page generated in 0.04338 seconds
