Re: after upgrade from 2.2.0 to 2.3.1: unwanted .gitignore files in SVN projects plus poor performan [message #1027304 is a reply to message #1024536] |
Tue, 26 March 2013 16:47  |
Frank Neblung skrev 2013-03-26 09.26:
> OK, here are some thread dumps.
> dump1 and dump2 were taken when autobuild was on. Eclipse was responsive during the time of dump1, but was not on dump2.
> Then I turned off autobuild and took dump3 and dump4. The problem with unreponsiveness remained the same (dump3 responsive, dump4 not).
> I experience unresponsiveness only when changing files in Git-controlled projects.
> When changing SVN-controlled files Eclipse remains responsive even when autobuild is on and massive recompilation and static analysis takes place.
In the dump2 dump I see nothing that EGit does that makes things slow, but I do see findbugs
which sometimes takes it's toll. In dump4 I don't see egit at all, but he JDT decorators are active.
If you still suspect EGit, turn off the "refresh workspace when index changes" and see if that has
any effect.
-- robin
FUDForum. Page generated in 0.09912 seconds
